Old 12-05-2008, 07:20 AM   #1
kornerk12
kornerk12's Avatar
Default Cam gear removal
Well I am about to replace my cam seal. How do i hold the cam while i break loose the bolt holding the cam gear onto the camshaft ? I know i could use an impact but i know that is not the proper way.
kornerk12 is offline   Reply With Quote
Old 12-05-2008, 07:31 AM   #2
jweller
2006 Subaru Legacy Outback
My Garage
jweller's Avatar
Send a message via AIM to jweller
I've always left the timing belt on and the plugs in. engine compression has always been enough to hold it to break the bolt free. If the timing belt is off, then hold the cam gear still with a strap wrench.
2009-2013- The 4 longest years in American history.
99 accord coupe I4 5-spd
08.5 Mazdaspeed3 GT
jweller is offline   Reply With Quote
Old 12-05-2008, 07:51 AM   #3
kornerk12
kornerk12's Avatar
theres no place on the camshaft where u can put an align ket or something to hold the camshaft ? I know on some h series there is
Old 12-05-2008, 11:48 AM   #4
hondadude
hondadude's Avatar
With the valve cover off, put a small pry bar between the spokes of the cam gear, brace off the head.
Year and model Helps get better info
My crystal ball is out of service,and
I failed Clairvoyance 101 class
hondadude is offline   Reply With Quote
1990, cam, camshaft, gear, gears, h22, h22a, hold, honda, integra, removal, remove, sprocket, sprokcet, subaru, tool
