My car wont lock or unlock
i have a clifford 50.5x for my car. so i went to work today and armed my car, then what happens is that my battery in the remote died. so i ran to the nearest store that had aaa bateries. i bought 2 and then put one in my key. then went back to my car and tried to unlock it. nothing happens, so i try it again and then it beeps that it is out of range. it beeped out of range like 1 time after i pressed lock or unlock like 5 times. so what i do is i unlock it and press the bypass switch because i had to go work at another store. so right now on the key it says the car is unlock, but not it wont lock. does anyone know how to fix it?
Old Fart
Same question^^^
Does the alarm arm and disarm?
The remote may be "out of sync" with the system, to re-sync the remote press the lock button several times...
code hopping
The receiver and transmitters use a mathematical formula called an algorithm to change their code each time the transmitter is used.
This technology has been developed to increase the security
of the unit.
The control unit knows what the next codes should be.
This helps to keep the transmitter “in sync” with the control unit even if you use the remote control out of range of the vehicle.
However, if the remote has been pressed many times out of range of the vehicle, or the battery has been removed, it may fall out of sync with the control unit and fail to operate the system.
To re-sync the remote simply press [lock] several times within range of the vehicle.
The alarm will automatically re-sync and respond to the transmitters normally. from page 40 0f owners guide. 94
code hopping
of the unit.
What type of vehicle, make and model? I ask because I just diagnosed/repaired a 91 Civic lock issue no more than a week ago, it was a faulty molex pin in the drivers door that supplied power to the lock module. Its a very frequent problem for Hondas with the molexed door harnesses, which is just about every model made.
Kirk R
Kirk R
okay heres an update:
i tried syncing it by pressing lock a couple times and still nothing happens.
i drive a 94 integra rs. the car did not come with power locks but i had one installed on the driver side.
Location: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Bob, your going to need to reprogram the controler to the alarm. This will fix that problem. Let's get this one fix and move to the next. Pm me ur number and ill walk you thru it
Re: My car wont lock or unlock
i figured it out. i had to do the relearn procedure with the driver door open. odd but it worked. thanks for txt'in me earlier wrx-killer
Kirk R
Kirk R
noyb
01-25-2009 06:24 AM
thechromecoyote
07-03-2007 08:00 AM
knockout
11-24-2005 10:53 PM
