Old 11-24-2008, 09:27 AM   #1
04silvep3
04silvep3's Avatar
Send a message via AIM to 04silvep3
Default 99-00 Civic Fog Light Install
ok guys i have a 99 civic ex coupe im trying to install some ebay fogs but i cant figure out which port on the fuse box to plug the output into any ideas?
Sorry for the bad camera picture
1990 Honda CRX *Its a Single Cam I swear
1993 Ex GSR Eg Coupe *Traded*
1999 Ek Coupe Save The SOHC [ I ♥ my EK ]
04silvep3 is offline   Reply With Quote
Old 11-24-2008, 09:54 AM   #2
Mashimaro
Mashimaro's Avatar
iTrader Rating: (1)
didn't the ebay instructions have a picture of which one to plug into? i can't remember, it's been over a year since i installed a set on a friend's car.
worst comes to worst, try it and see if you get power or not. if you don't, try another one.
Toda Power
Mashimaro is offline   Reply With Quote
Old 11-24-2008, 09:57 AM   #3
00b20vtecoupe
00b20vtecoupe's Avatar
haha ebay instructions^
92 gutted hatch, full cage...fully built b20/vtec...226whp/154ft lbs. current project
2008 yamaha r6 raven track bike...
1998 jeep grand cherokee 5.9 limited liftedddd winter beaterrrr...
00b20vtecoupe is offline   Reply With Quote
Old 11-24-2008, 10:14 AM   #4
04silvep3
04silvep3's Avatar
bout them from a friend lost the instructions what were do i wire the power into?
Old 11-24-2008, 10:59 AM   #5
04silvep3
04silvep3's Avatar
ok i got most of the wiring done i just gotta find were to plug the switch output that needs to go out to the fogs on the fuse box
Old 11-24-2008, 11:02 AM   #6
Mashimaro
Mashimaro's Avatar
iTrader Rating: (1)
just try each one till you get one that works. you won't fry anything if that's what you're worried about.
Toda Power
Old 11-24-2008, 11:06 AM   #7
04silvep3
04silvep3's Avatar
i did but none of them seem to turn the lights on
Old 11-24-2008, 11:24 AM   #8
Mashimaro
Mashimaro's Avatar
iTrader Rating: (1)
have you checked all your ground points first? is your lightswitch for the headlights turned on for lowbeam?
Toda Power
Old 11-24-2008, 12:05 PM   #9
04silvep3
04silvep3's Avatar
yes everythings fin i have power from out the output of the relay but wen i touch the power to anyone one of thos ports i dunt get power at the fog light connector under the hood
Old 11-24-2008, 12:09 PM   #10
b16a1eg6
1995 Honda Civic
b16a1eg6's Avatar
Send a message via AIM to b16a1eg6
http://www.hondaautomotiveparts.com/.../19796_01.html
1995 Hatch-B18C
1997 Coupe-OEM
2004 Titan-Better than a minivan
b16a1eg6 is offline   Reply With Quote
Old 11-24-2008, 01:04 PM   #11
04silvep3
04silvep3's Avatar
Originally Posted by b16a1eg6 View Post
there ebay fogs honda oem is different then that dosnt have the harness in the steering column
Old 11-24-2008, 01:08 PM   #12
Frost7177
Frost7177's Avatar
Send a message via AIM to Frost7177
put it in the third one thats constant power.
Frost7177 is offline   Reply With Quote
Old 11-24-2008, 01:15 PM   #13
04silvep3
04silvep3's Avatar
ok i know that but im trying to find the port that goes to the wire under the hood for the fog lights to plug into
Old 11-24-2008, 02:46 PM   #14
04silvep3
04silvep3's Avatar
bump
Old 11-24-2008, 04:02 PM   #15
MilanoRedEk99
MilanoRedEk99's Avatar
Is the relay clicking when you turn them on? I had the same issue with mine and it turned out to be a bad relay and blown bulbs. I have the depo ones from egay.
MilanoRedEk99 is offline   Reply With Quote
Old 11-24-2008, 04:05 PM   #16
04silvep3
04silvep3's Avatar
ok the relay click everythings installed i just gotta figure out were the wire that supposed to plug into the factory fog light wire under the hood is under the dash
Old 11-24-2008, 04:12 PM   #17
MilanoRedEk99
Wait are you talking about the wire that has a female connector at the end that hooks up to the wire which I believe that both of them are red and it has a male connector, and the the brown plug goes on the 4th slot on the fuse box. Can you try and take a picture of the plug you are talking about???
Old 11-24-2008, 04:18 PM   #18
04silvep3
04silvep3's Avatar
ok on the fog light switch harness theres 4 wires a ground a + for the switch light a + for the fog lights and the brown female connector for the main feed to the fog lights its supposed to connect some were in the car that leads to the out side wiring
Old 11-24-2008, 05:32 PM   #19
04silvep3
04silvep3's Avatar
bump
Old 11-24-2008, 05:48 PM   #20
gsrturbo-ek
gsrturbo-ek's Avatar
the third one lookin left to right
ej8 squad #289
97 cgp ej8 totalled ,96 cgp ej8 sold,98 ford escort gone, EM1 fpb weekend toy, 06 CRV SE daily
gsrturbo-ek is offline   Reply With Quote
Old 11-24-2008, 08:19 PM   #21
jdmferioej6
jdmferioej6's Avatar
i have mine in the number 5 spot they work just fine
jdmferioej6 is offline   Reply With Quote
Old 11-25-2008, 10:31 AM   #22
04silvep3
04silvep3's Avatar
number 5?
and this is supposed to be for the power that goes outside to the fog lights not the feed
Old 11-25-2008, 10:56 AM   #23
04silvep3
04silvep3's Avatar
and for thos who dunt know what im talking about im looking for the wire inside the car that supplies the factory fog light wiring this plug under the hood
Old 11-25-2008, 12:14 PM   #24
gsrturbo-ek
i think that plug is just taped to the harness behind the fusebox with blue tape
ej8 squad #289
Old 11-25-2008, 01:00 PM   #25
MilanoRedEk99
^ what he said, and you only use that plug with oem fogs don't need to use it with the depo ones.
00, 1999, 99, 9900, civic, ek, fog, honda, install, installation, installing, light, lights, template, video
