Old 11-06-2008, 03:43 PM   #1
obuhmyuh
1995 Honda Del Sol
obuhmyuh's Avatar
Send a message via ICQ to obuhmyuh Send a message via AIM to obuhmyuh
Default ignition output signal CEL #15
hey guys i had a code 9 the other day CYP sensor (cyl 1 sensor), so i bought and installed a new dizzy from AZ and i was driving home and my car just shut off and a code 15 popped up. I think there may be a wiring problem near my ecu, so i checked those wires out and fixed a couple.
Cliff notes:
95 del sol si (jdm sohc vtec JDMd15b obd1)
car wont start (but will everyonce in a while when i tinker with the wires but shuts off
CEL #15 ignition output signal
anyone have some expertise?
95 del sol si jdm d15b sohc VTEC, megan-racing headers, cat back-2.5" magnaflow, CAI, CROWER cam, skunk2 cam gear, BLOX IM, rebuilt head, ground control coilovers/tokica illumina's, jdm rear swaybar 23mm, black asr rear subframe brace, tuned at Church auto.
obuhmyuh is offline   Reply With Quote
Old 11-07-2008, 01:19 PM   #2
obuhmyuh
1995 Honda Del Sol
obuhmyuh's Avatar
Default Re: ignition output signal CEL #15 (obuhmyuh)
bump
Old 11-07-2008, 01:31 PM   #3
RonJ@HT
Raising the bar
2000 Honda Civic
My Garage
RonJ@HT's Avatar
Here's where to concentrate:
1) The igniter may be bad.
2) The Yel/Grn wire between the igniter and ECU may be bad (open or short).
3) The Blk/Yel wire between distributor 2P connector and ignition switch may be bad. There should be battery voltage with the key turned to ON(II).
Old 11-07-2008, 01:34 PM   #4
obuhmyuh
1995 Honda Del Sol
obuhmyuh's Avatar
Default Re: ignition output signal CEL #15 (RonJ@HT)
yeah all of my wires are hacked to bits around that area by my ECU. I tried using a different ECU as well...
sounds like im going to need a mutimeter, i checked for power at the yellow/green wire using a lightbulb and ground and it looks like theres power there (maybe insufficient though???), i literally had just replaced the dizzy when this **** happened and i was driving away from autozone, so im not thinkin its the dizzy too much since its new...
Old 11-08-2008, 01:06 AM   #5
obuhmyuh
1995 Honda Del Sol
obuhmyuh's Avatar
ttt
Old 11-09-2008, 07:45 AM   #6
obuhmyuh
1995 Honda Del Sol
obuhmyuh's Avatar
bumppp
Old 11-09-2008, 04:54 PM   #7
LS94tegra
LS94tegra's Avatar
iTrader Rating: (2)
hey did you ever figure this out? my buddy has the same problem but he has no spark, and throwing code 15.
My seller vouch threadhttp://www.honda-tech.com/zerothread/2140401
http://www.givescottadollar.com <---My new website
LS94tegra is offline   Reply With Quote
Old 11-09-2008, 11:46 PM   #8
obuhmyuh
1995 Honda Del Sol
obuhmyuh's Avatar
Default Re: ignition output signal CEL #15 (LS94tegra)
not yet, could use some help though...
Old 07-16-2009, 03:31 PM   #9
moknoy
moknoy's Avatar
Send a message via AIM to moknoy Send a message via Yahoo to moknoy
I am having this problem now with my civic. Necro but answers will be great!
moknoy is offline   Reply With Quote
Old 07-30-2009, 09:28 PM   #10
hialeahzbg
hialeahzbg's Avatar
Send a message via AIM to hialeahzbg
i have the same problem....ive changed the dizzy and ecu and still...im getting no spark...
SOHC my DOHC
hialeahzbg is offline   Reply With Quote
Old 07-30-2009, 09:35 PM   #11
RonJ@HT
Raising the bar
2000 Honda Civic
My Garage
RonJ@HT's Avatar
Is the CEL on?
Does the Blk/Yel wire in the distributor have battery voltage with the key in ON(II)?
Does the Yel/Grn wire running between the igniter unit and ECU have continuity? What voltage does this wire have at the igniter unit with the key in ON(II)?
Old 07-31-2009, 09:11 AM   #12
hialeahzbg
hialeahzbg's Avatar
Originally Posted by RonJ@HT View Post
Is the CEL on?
the cars at a friends house and hes working on it but he hasnt been about to figure anything out...ima text him what u wrote...what if the blk/yel wire in the dizzy has voltage?
SOHC my DOHC
Old 07-31-2009, 09:18 AM   #13
hialeahzbg
hialeahzbg's Avatar
ok he said it does not have power...
SOHC my DOHC
Old 07-31-2009, 09:25 AM   #14
RonJ@HT
Raising the bar
2000 Honda Civic
My Garage
RonJ@HT's Avatar
No power with the key in ON(II), right?
If so, the Blk/Yel wire is broken somewhere between the distributor connector and the ignition switch OR the ignition switch is bad. Have him check those two possibilities.
Old 07-31-2009, 10:40 AM   #15
hialeahzbg
hialeahzbg's Avatar
AwEsome... I'll have him look at it.. Anything else it could be?
SOHC my DOHC
Old 07-31-2009, 10:46 AM   #16
RonJ@HT
Raising the bar
2000 Honda Civic
My Garage
RonJ@HT's Avatar
What year? Did he already inspect the Blk/Yel wire pins in the distributor connectors for damage? Does the windshield washer motor work?
Old 07-31-2009, 11:34 AM   #17
hialeahzbg
hialeahzbg's Avatar
It's a 95 rhd sir eg6
SOHC my DOHC
Old 07-31-2009, 11:39 AM   #18
RonJ@HT
Raising the bar
2000 Honda Civic
My Garage
RonJ@HT's Avatar
Okay. Any answers for the other two questions?
Old 07-31-2009, 11:42 AM   #19
hialeahzbg
hialeahzbg's Avatar
He's gonna get home like 3 hours... I texted him wat u wrote...
SOHC my DOHC
Old 07-31-2009, 11:43 AM   #20
hialeahzbg
hialeahzbg's Avatar
Can u pm me ur number so we can call u?
SOHC my DOHC
Old 08-01-2009, 09:52 PM   #21
hialeahzbg
hialeahzbg's Avatar
Thanks!!! it fixed my problem!!!
SOHC my DOHC
Old 08-01-2009, 10:04 PM   #22
RonJ@HT
Raising the bar
2000 Honda Civic
My Garage
RonJ@HT's Avatar
Great. What was the solution?
Old 08-03-2009, 06:49 AM   #23
hialeahzbg
hialeahzbg's Avatar
bly/ylw was ripped somewhere between the ecu plugs...
SOHC my DOHC
Old 12-28-2009, 10:37 AM   #24
eaddagwan
eaddagwan's Avatar
good stuff, im having the same issue here, hopefully i can see about just replacing the black/yellow wire all the way through. any advise going into it?
eaddagwan is offline   Reply With Quote
Old 06-30-2010, 10:12 AM   #25
killa94
hey i have the same problem...ive checked the blk/ylw wire and it has a current but am not sure how to test the igniter
killa94 is offline   Reply With Quote
15, 88, 94, accord, acura, cel, civic, code, crx, honda, ignition, ignitor, integra, output, si, signal
Similar Threads
1998 CR-V -Crank, No start Pulling hair out ! jonney66 Honda Element & CR-V 2 05-06-2014 01:24 PM
95 Civic Ex - shaky acceleration, low idle, 3 CEL codes JCORTES Honda Civic/Del Sol (1992 - 2000) 17 10-28-2013 08:06 AM
Cel code 15 Hyunbs Honda Civic/Del Sol (1992 - 2000) 4 10-25-2013 01:40 PM
93 Accord Ex shuts off randomly Daccordex Honda Accord (1990 - 2002) 5 09-10-2013 03:18 PM
95 hatch cel code 15 rollinhonda3 Honda Civic/Del Sol (1992 - 2000) 1 02-10-2013 06:14 PM
