Old 11-05-2008, 12:10 PM   #1
Boostn B20
Default car jerks
previously i had this problem where my car only jerk from 1500-about 1700rpm though 1-3 gears, that mysteriously went away. now im having an issue where it jerks while im driving. i can take off fine, go thru all gears, then about 5 mins. driving it will start jerking back and forth, almost like it's starving for gas. i have fuel. i know how to drive, what could this be?
Boostn B20 is offline   Reply With Quote
Old 11-05-2008, 02:00 PM   #2
redcoats1976
redcoats1976's Avatar
sorry,thought this was a thread about people that dont like hondas...
redcoats1976 is offline   Reply With Quote
Old 11-05-2008, 02:58 PM   #3
slacks
slacks's Avatar
Send a message via AIM to slacks
Default Re: car jerks (Boostn B20)
i think you mean "bogging" ... sounds like you could use a tune up
any check engine lights?
slacks is offline   Reply With Quote
Old 11-05-2008, 03:00 PM   #4
INCNTRL4
INCNTRL4's Avatar
Send a message via AIM to INCNTRL4
Default Re: car jerks (slacks)
me too Click the image to open in full size.
I'd say check your fuel filter, prolly gummed up. also doesnt hurt to do a full tune up.
93' del Sol
11.72 @ 123mph
95 Civic SI - 476whp - Much More Boost in 2011 with a fresh rebuild!!
INCNTRL4 is offline   Reply With Quote
Old 11-05-2008, 04:10 PM   #5
Boostn B20
jajaja. thas funny. cause i looked at it jus now in my profile list of threads and i was thinkin, i din subscribe to any thread about car jerks.jajaja. took me a min to member.
Old 11-05-2008, 06:29 PM   #6
jdm702
jdm702's Avatar
mine does the same exact thing !!!!!!! but only 1st to 2nd it jerks hard but i can feel the lag on other gears it went away for some time but now its back !!! whats the problem ???!!!
jdm702 is offline   Reply With Quote
Old 11-06-2008, 09:00 AM   #7
civbomb
civbomb's Avatar
i have the same problem, have you checked the spark plugs? i had one busted and it helped. put a new set it, turns out on of them were faulty, now its a lot better
civbomb is offline   Reply With Quote
Old 11-06-2008, 09:23 AM   #8
Shocka1998LX
Shocka1998LX's Avatar
Send a message via ICQ to Shocka1998LX Send a message via AIM to Shocka1998LX
do a full tune up, and fix any engine codes you have... check your map sensor and iacv too just for the hell of it
Team EJ6 #141, 2000 Ford Explorer Sport w/ 20% Tint, Hornet 564T Alarm w/ Pager and Remote Start, Kicker ZX Series 1000.1 Mono Amplifier, Fi Car Audio BL 12", Rockford Fosgate 2 farad capacitor, Rockford Fosgate Prime R300-4, RE Audio 5x7's
Shocka1998LX is offline   Reply With Quote
Old 11-06-2008, 11:35 AM   #9
Boostn B20
ight. can someone help me out here. thing is im a lil bit limited on cash, so i wann try to pin point wat the highest possibilty of it is first. as i was drving, i went first up to 2200 rpm, shift second, felt a lil bit of bog(falling on it's face feeling) but picked up, went up to 2000 rpm shifted 3rd, and then it jus completely fell on it's face, took about 5 seconds for it to pick up again. and if i keep goin in some severe cases, i have to stop, go back to first, and go thru the gears until it happens again. is this more likely.....fuel related, ignition related (plugs/wires), maybe dizzy?, others?
Old 11-06-2008, 11:37 AM   #10
EJ8_Enthusiast
EJ8_Enthusiast's Avatar
you think maybe you are shifting too early?
00 Civic EX R.I.P
04 RSX Base model no mods! (except cold air intake)
EJ8_Enthusiast is offline   Reply With Quote
Old 11-06-2008, 11:48 AM   #11
Boostn B20
yea. i kno that. but i kno how to drive too. it's a dif. feeling than wen u i guess under accelerate...it's jus like it loses every bit of power. like it stutters to get back up
Old 11-06-2008, 02:16 PM   #12
Jonknee
Default Re: (Boostn B20)
Are you in limp mode? do you have an eld code? any ecu codes.
For sale: D series Itbs, never used full bolt on kit.
Jonknee is offline   Reply With Quote
Old 11-06-2008, 02:34 PM   #13
Boostn B20
nah, no codes, i dun think?...limp mode?
Old 11-06-2008, 03:19 PM   #14
EJ1 LS guy
EJ1 LS guy's Avatar
Sir_Ty_Rocks
Send a message via AIM to EJ1 LS guy
maybe you should try taking it further...to like 4000k 1-4.....and then see if it jerks at all.....
my homie had a similar problem and it was his fuel filter....just needed cleaning.....
Originally Posted by DirtyxSanchez View Post
Has anyone really been far even as decided to use even go want to do look more like?
EJ1 LS guy is offline   Reply With Quote
Old 11-06-2008, 04:36 PM   #15
Boostn B20
i cud do that. but first i wud have to pass 3000 rpm, and like i stated before, wen im in 3rd, at around 2000 rpm, it starts dyin out.
Old 11-07-2008, 06:14 AM   #16
Boostn B20
UPDATE:
i was driving/testing, and tried passing 3000rpm in second, the car wud not let me, it started dying out around 2500rpm. so i figured jus keep the pedal smashed down, hoping it wud pick up, but it doesn't, it goes down and feels like it's gonna choke/die out. but i heard something while this was happening, it let out a kinda big pop from the exhaust, like bad a/f ratio pops(i think). that said, can anybody give me a starting point as to where i shud start first. and my gauge doesn't really work, the gas or mph don't work, but i remember i have seen the check engine light come on before...it's not on now tho.
Old 11-07-2008, 07:44 AM   #17
Boostn B20
sorry for not posting all these updates together. car was at idle, i depressed the gas pedal the way down, got up to 5krpm, let off and hit the gas again, car stuttered and wud not pass 3krpm, so i continued depress the pedal, and the car went almost to a shut off point, as soon as i let off the gas pedal, it picks up to 2k rpm, before it goes to a normal idle.cud this be a fuel filter, or jus a fuel clog. i don't have an aftermarket intake, but i removed the bottom trap while i was doing some work earlier.
Old 11-07-2008, 08:39 AM   #18
Boostn B20
any one????
Old 11-07-2008, 09:58 AM   #19
fryguy190
1992 Honda Civic
My Garage
fryguy190's Avatar
Andrewcfryer
Send a message via AIM to fryguy190 Send a message via MSN to fryguy190 Send a message via Yahoo to fryguy190
Default Re: (civbomb)
first check the fuel filters... in the bay and in the tank.... check ur plugs, wires, mainly a good solid tune up...
Motto: stand for somthing, or live for nothing. you choose.
92 Civic Hatch CX single-jingle "for now"
fryguy190 is offline   Reply With Quote
Old 11-07-2008, 10:09 AM   #20
Boostn B20
y wud it back fire like it did.
Old 11-07-2008, 10:22 AM   #21
tienzien
tienzien's Avatar
your timing could be off, mine acted like that when i first installed my motor and it was timing issues. my friend hit a hard bump his timing belt jump a tooth and did the same thing.did you hit any unusal large bump lately? if you know how to do it... i would say check it out. timing adjustment would only take around an hour or so when we did it. good luck
tienzien is offline   Reply With Quote
Old 11-07-2008, 10:31 AM   #22
Boostn B20
i was worried bout that. wen i set the timing, i lined up the cam to it's marks, but the crank pulley, is that set on the red mark in between the two lines, or on the white mark
lll or ll
i took it to my boy's garage. and he set it, but on the way home, i heard alot of valve lashing i guess(high dings in the valvetrain at lower rpms and higher gears) and it started losing out power like what i mentioned above about 20 mins into the drive home, so wen i got home, i set the timing back to the red mark on the crank pulley, i don't get any of the valvetrain noises now, but it still loses out on the power like previously mentioned
Old 11-07-2008, 08:17 PM   #23
tienzien
tienzien's Avatar
i believe that the red mark between the 3 line is for your ignition timing. well i dont know whats the other ones called but its a single mark that stand alone. thats the right mark to set the crank to.
Old 11-07-2008, 08:25 PM   #24
Jonknee
Default Re: (tienzien)
Single mark is your TDC , thats how you align your camshaft in relation to your crank pulley. Ignition timing is a different story which has to do with those other marks.
Old 11-08-2008, 05:55 AM   #25
Boostn B20
i set the timing back to the single mark and aligned the camshaft, and the problem is still consistent. nothing really changed?
3000rpm, b20, back, car, distributor, driving, empty, forced, im, installed, jerk, jerking, jerks, jolts, shift, started, stereo, tank, timing
