Proper Torque for Wheel Lugs? (searched)
Old 11-03-2008, 08:33 AM
GriFFIthS's Avatar
Default Proper Torque for Wheel Lugs? (searched)
so i've been searching around and i cant seem to find the proper Torque specs for my 01 civic dx, i dont have my manual so i cant check that, i've been told its 80 ft/lbs, also have been told that its 90ft/lbs.
can someone please let me know the actual spec, also if possible i need to get a socket for my torque wrench but i dont know the size, been told its 5/8 inch that i need.
any help would be great, thanks
Old 11-03-2008, 08:53 AM
Sanji
toyomatt84's Avatar
80 lb/ft (110 Nm)
I believe the standard lug nut requires a 21mm socket.
Old 11-03-2008, 09:01 AM
GriFFIthS's Avatar
Thank you, thats exactly what i needed.
cheers
Old 11-03-2008, 09:44 AM
Boilermaker1's Avatar
Default Re: (toyomatt84)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toyomatt84 &raquo;</TD></TR><TR><TD CLASS="quote">
I believe the standard lug nut requires a 21mm socket.</TD></TR></TABLE>
Its a 19mm socket.
Old 11-03-2008, 11:55 AM
Sanji
toyomatt84's Avatar
Default Re: (Boilermaker1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boilermaker1 &raquo;</TD></TR><TR><TD CLASS="quote">
Its a 19mm socket.</TD></TR></TABLE>
I couldn't remember the number, my mistake.
I've never had a set of OEM lug nuts for my car anyways.
Old 11-11-2008, 09:41 PM
ejLday's Avatar
Default Re: Proper Torque for Wheel Lugs? (GriFFIthS)
80 ft/lb
Old 11-12-2008, 04:03 PM
batac_boy's Avatar
Default Re: Proper Torque for Wheel Lugs? (ejLday)
ok what's really good to use a Torque stick or a Torque wrench?
Modified by batac_boy at 5:16 PM 11/12/2008
Old 11-12-2008, 05:52 PM
Sanji
toyomatt84's Avatar
Default Re: Proper Torque for Wheel Lugs? (batac_boy)
Torque wrench.
Old 11-12-2008, 06:01 PM
Function>Fashion
Harlowe's Avatar
Default FV-QR
Don't forget anti-seize!
I used to break studs all the time from over-tightening my lugs, then a good friend of mine (fventura03 ) taught me to tighten them as much as you can with your hands, if you don't have a torque wrench. Don't stand on the tire iron and stuff, hahaha.
Old 11-13-2008, 10:37 PM
FijiBlueHero's Avatar
Can toyomatt84 or anybody confirm on the method posted by Harlowe. I want to do a tire rotation and I just want to know if that method is safe so i can do it. The only tool I have is the lug wrench that came with the jack in the Car. Thank you .
Old 11-13-2008, 10:40 PM
Sanji
toyomatt84's Avatar
Default Re: (FijiBlueHero)
I'll confirm his method. Ideally, you'd want a torque wrench, but anti-seize and a tire iron will work nicely. You do not need to put all your weight into tightening the lug nuts. Just simple arm strength will suffice.
816d16
08-15-2020 04:41 PM
2008fijibluesi
Honda Civic (2006 - 2015)
05-05-2008 04:57 PM
Tippyman
11-13-2006 04:59 PM
Dee
05-22-2006 04:20 PM
Tex Blackwell
06-19-2004 09:50 PM
Quick Reply: Proper Torque for Wheel Lugs? (searched)
