Wheel lock nut removal missing key
Old 11-02-2008, 07:09 PM
MrMike's Avatar
Default Wheel lock nut removal missing key
Question for you guys. How do i get a set of honda/McGuard style wheel lock nuts off without the key? Over the summer i got a flat and accidentally left the key on the side of the road. I tried the vice grip method and was only able to remove one of the 4 lock nuts. Do you guys know of any specialty tools that will be able to take off these nuts? I know theres gotta be some kind of specialty took out there but i'm not sure where to find it. I need to rotate my tires now that it is raining. Thanks.
I have these.
My setup for shiIts and giggles.
[IMG][/IMG]
Old 11-02-2008, 10:09 PM
ekb16's Avatar
if those r the OEM style lock lug nuts u can go to ur local dealership and have them order u a new key...they got a master key set..if ur plannin on gettin new lock lug nuts then a few sockets and hammer will work just as good
Old 11-03-2008, 04:43 AM
Psychoteen101's Avatar
Those lockers are pretty typical. You can go to a tire shop and they should have them. But be aware, they are probably gonna charge you a rediculous amount. I bought one and it costed $26
Old 11-03-2008, 04:55 AM
srmofo's Avatar
Default Re: (Psychoteen101)
you need a wheel lock removal socket....sears sells them as well as every major tool manufacturer....they will destroy the locks, but those things are worthless anyways, if they want your wheels they are just gonna steal the car....I havent worked at a shop yet that has wheel lock keys, if you know the mcgaurd number you can probaly find a replacement key
Old 11-03-2008, 06:37 PM
MrMike's Avatar
Default Re: (srmofo)
Found this on harbor freight. Probably gonna give them a try.
http://www.harborfreight.com/c...96296
Old 11-04-2008, 06:53 AM
Eddie1980's Avatar
You can try the removal tool if you like but in my experience they are too large to fit in the holes of most alloys.
Seriously as stated, tight multi fit socket and a short extension bar + big hammer. Works for me every time.
Ideally a impact wrench but if you don't have one then just try snatching it with an extension bar.
Old 11-05-2008, 03:55 PM
NJIN BUILDR's Avatar
Default Re: Wheel lock nut removal missing key (MrMike)
I've seen people weld a nut onto them and wrench them off.
Old 11-05-2008, 05:48 PM
MenaceL.A.671's Avatar
Default Re: (ekb16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekb16 &raquo;</TD></TR><TR><TD CLASS="quote">if those r the OEM style lock lug nuts u can go to ur local dealership and have them order u a new key...they got a master key set..if ur plannin on gettin new lock lug nuts then a few sockets and hammer will work just as good</TD></TR></TABLE>
Old 11-05-2008, 07:05 PM
iwanttokillgod's Avatar
Default Re: (MenaceL.A.671)
hammer a four way lug wrench on it thats always works well for me
Old 11-06-2008, 12:42 PM
SlowReaction's Avatar
Default Re: (iwanttokillgod)
Hammer a 19mm 12 point socket. That worked for me.
Old 11-06-2008, 09:44 PM
1988_96hb's Avatar
Default Re: Wheel lock nut removal missing key (NJIN BUILDR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">I've seen people weld a nut onto them and wrench them off.</TD></TR></TABLE>
ive seen that or the used a cuttoff wheel to cut a spot for a flathead screw driver and use the flat head side of a four way.
Old 01-27-2016, 06:36 AM
fer21's Avatar
Old 07-01-2016, 08:29 AM
89civicdx's Avatar
for these honda ones try a 20mm and impact seems to work but 12 point is probably better
Lambert714
04-05-2018 07:23 PM
keep it 100
06-11-2011 01:05 PM
Petah
01-14-2009 02:20 PM
Boricuanology
02-10-2007 10:26 PM
turbotime
17
11-03-2003 04:39 PM
Quick Reply: Wheel lock nut removal missing key
