Old 10-27-2008, 10:19 PM   #1
supermotothud
supermotothud's Avatar
Default Engine oil leaking from the transmission??? (Pics inside)
A few days ago i thought i had a rear main seal leak on my 96 Accord EX Automatic tranny (170k miles)
I cleaned the bottom of the motor and transmission.
Removed the transmission, and noticed that the inside the transmission housing where the driveplate and the torque converter were...it was clean. No oil leaks no drips, no lines of oil...nada.
So i put everything back together. double checked some more, cleaned some more, and i think i know where my engine oil is leaking from..but why?
The oil seems to be leaking from the part of the transmission where the driveshaft is inserted.
It only leaks on the drivers side of the transmission, and I have included a link to a picture album.
It is coming from the hole where you insert the drivers side drive shaft.
And YES it is engine oil, not transmission fluid.
Is there a seal there? why is it engine oil? could i still have a leaky rear main seal?
Click the image to open in full size.[/url]
From the picture...you can see the trail of engine oil leaking out
more pics..
http://picasaweb.google.com/Ro...lLeak#
1996 Honda Accord EX, 2 dr coupe, leather, automatic.....i bought for 2 Grand. Its a daily beater. Toys: OME Lifted & Kenne Bell Supercharged 2000 Jeep Grand Cherokee..and a 1968 Camaro Convertible.
supermotothud is offline   Reply With Quote
Old 10-28-2008, 04:59 AM   #2
P_Adams
P_Adams's Avatar
Default Re: Engine oil leaking from the transmission??? (supermotothud)
It appears to be leaking from the Output Shaft seal. This can be accessed with the removal of the offending axle. The seal mounts in the transmission / differential case.
P
#1 '97 CD7 SE Accord Coupe San Marino Red / #2 '96 CD7 LX Accord Coupe Arctic White / #3 '96 EJ8 EX Civic Coupe Black / #4 '88 LXi Coupe (spare)
One more "What's the Top Speed..." thread and I think I'll flame someone
P_Adams is offline   Reply With Quote
Old 10-28-2008, 05:45 AM   #3
dtapia
2000 Honda Civic
dtapia's Avatar
Send a message via AIM to dtapia
Default Re: Engine oil leaking from the transmission??? (P_Adams)
P
x2 looks like dirty atf. which also can look like engine oil Click the image to open in full size.
MASTER ACURA TECH and HONDA TECH
26 years with HONDA/ACURA
dtapia is offline   Reply With Quote
Old 10-28-2008, 05:29 PM   #4
hondadude
hondadude's Avatar
In pic #8 you can see the oil is coming from up above; check dist Oring and oil press sending unit.
If it's a Vtec engine the solenoid is mounted to the head right above that area.
The best thing to do is get a couple cheap cans of spray brake clean, blast down the entire area/back of block etc.
Spray around with Dr Scholls foot powder spray, then go for a drive...recheck
Year and model Helps get better info
My crystal ball is out of service,and
I failed Clairvoyance 101 class
hondadude is offline   Reply With Quote
Old 10-28-2008, 07:30 PM   #5
slomofo
GDD Member
1991 Geo Metro Type-R
slomofo's Avatar
iTrader Rating: (1)
solbrothers xtrac1 George Knighton ILcrxsi1 uncle_ben markspan6243
Send a message via ICQ to slomofo Send a message via AIM to slomofo Send a message via MSN to slomofo Send a message via Yahoo to slomofo Send a message via Skype™ to slomofo
Output shaft seal and possibly input shaft/rear main as well.
Maximum parts cost: $30.00
Maximum time to be spent: 3 hours.
Most likely scenario: $15.00 and 45 minutes.
Originally Posted by turbohatch96y7 View Post
I love a good creampie!
slomofo is offline   Reply With Quote
Old 02-28-2009, 07:13 PM   #6
Bad_dude
Send a message via AIM to Bad_dude
Default Re: Engine oil leaking from the transmission??? (Pics inside)
Did you ever found out what was really leaking?
Thanks.
Bad_dude is offline   Reply With Quote
Old 09-01-2009, 09:28 PM   #7
cody777
I have this same problem and its 100 % motor oil not transmission fluid. just swapped the motor and its leakin freash oil from the same spot
My car is a 94 accord ex auto
cody777 is offline   Reply With Quote
Old 09-02-2009, 02:47 AM   #8
YeuEmMaiMai
just be careful when replacing the offending seal, nick that new one and you will be at it again.......
YeuEmMaiMai is offline   Reply With Quote
Old 09-02-2009, 10:01 AM   #9
spongecop
I had the exact same problem on my 95. fresh oil running down the transmission. It was the VTEC or spool valve. remove the three bolts and replace the seals...its an easy, cheap fix. If it was dirty oil then I would look else where. I replaced my axle seals mistakingly thinking its was tranny fluid only...actually I had a mixture of the two...my luck.
Funny, the Honda tech kept insisting it was a cam seal. was suprised when I told them it was a spool valve...seems at the dealer those never leak.
spongecop is offline   Reply With Quote
Old 09-03-2009, 12:43 PM   #10
cody777
Mines not coming outta the vtec selinoid its commin from exactly were the tread starters is leakin. I cant tell what it is
68, 96, accord, camaro, civic, engine, honda, inside, leaking, oil, output, seal, shaft, spray, transmission, white
