Seatbelt Sensor SRS light
Old 10-26-2008, 05:40 PM
alexisthemovie's Avatar
Default Seatbelt Sensor SRS light
The SRS light has been on in my dad's 2001 EX for a few thousand miles now. He took it to a mechanic who traced the light back to the sensor in the driver seatbelt. This sensor is supposed to lock up the seatbelt when the airbag is deployed in an accident.
Does anyone know if this (safety issue) is covered under some sort of lifetime warranty? The car currently has about 125k miles.
Old 10-27-2008, 10:48 AM
ballinboosi's Avatar
Default Re: Seatbelt Sensor SRS light (alexisthemovie)
you can reset the light or take it to honda and they will charge you to reset it.
Old 10-27-2008, 01:25 PM
Why would I reset the light if it's just going to come back again? It's a safety issue here, not just an annoying CEL or something.
Old 10-28-2008, 01:08 PM
Perfectionist's Avatar
I believe it is covered by a lifetime warranty. You could call your local Honda service department and tell them what your mechanic traced the problem to and ask if it's covered.
Old 10-28-2008, 06:16 PM
jdm em2's Avatar
i juss had this problem there is a thread for it to.. but take it to the dealer and they will replace it.. i got it for FREE! so.. ya its in ur seat belt
Old 11-04-2008, 01:54 AM
Jasper DMX's Avatar
Default Re: Seatbelt Sensor SRS light (jdm em2)
mine, is odyssey. it will the same ? just change the buckle seat belt ?
Old 11-04-2008, 09:48 AM
Forgot to update this thread...
my dad took it to the dealership and had it fixed for free under lifetime warranty.
Make sure that the seatbelt is your problem or you will be charged for the work.
Old 11-18-2008, 07:48 AM
FitITGirl's Avatar
Icon2 SRS light honda civic EX 2001 bad seat belt buckle
I read the post about the SRS light being ON in Honda CIVIC. I have a similar problem on my Honda CIVIC EX 2001 with about 90,000 miles in it. The SRS light is ON and I took it to the Honda dealer who did a diagnostic testing for $85 and then came up and told that the driver seat belt has a bad buckle and the seat belt has to be replaced. He was estimating $250 for the parts and labor. When I looked for it in the internet I found your post which is closely depicting my scenario and you had mentioned that seat belts have life time warranty and it has to be replaced for free.
Do you think replacing the seat belt is still covered? I would think my Honda dealer should know that but I am beginning to think that they are cheating me. Is there an official Honda website that I can go to find this information? I need to be able to talk to them with some official information.
Can someone help me with this?
Thanks in Advance.
Old 12-28-2008, 07:52 PM
gerdaland's Avatar
Default Air Bag Light On..?
I have a 2005 civic ex 4dr. when i first got it, the seat belt bell drove me crazy. i unplugged the sensor under the seat and was satisfied for about 10 miles when the seat belt and air bag light were bothering me. after i plugged it back in and put my seat belt on, the air bag light was still there. is this normal? i was gonna reset the battery to see if that does it, but i figured id check here 1st, anybody else had this happen?
Old 12-28-2008, 07:58 PM
themachinist's Avatar
Location: Big desert next to Cali, United States of America
Default Re: Air Bag Light On..?
What you are going to have to do is unplug the sensor again and then go pop the hood and unplug your battery. Now after you unplug the battery you can go plug the sensor back in and then hook the battery back up. Make sure you have your radio code btw.
Old 12-30-2008, 12:47 AM
Jasper DMX's Avatar
updating my case. bought the buckle switch for my odyssey for only $90 (dealer ask me for about $250), and then, try do DIY, before that just unplug from old buckle switch and plug into new buckle switch, and then the SRS light STILL ON !!! (tried both seat).
so should we RESET the ECU after change the buckle siwtch or not ?
thanks
Old 12-30-2008, 12:49 AM
Jasper DMX's Avatar
Default Re: SRS light honda civic EX 2001 bad seat belt buckle
Thanks in Advance.
try to do service at non dealer mechanic and ask them what happen with the SRS light.
they shouldn't changed you for ecu diagnostic and see what happen.
Old 12-30-2008, 11:27 PM
Jasper DMX's Avatar
last update :
change my buckle switch -- SRS still on
and do the RESET srs with this instuctions :
http://www.geocities.com/myintegra96/srs.html
final result : SRS light gone !!!
so my conclusion :
1. try to do reset first,
if not works (because of ....read last words in instructions :
- Make sure you have the right connector and that a module or some other part of the SRS system is not malfunctioning. ) do :
2. change buckle switch at driver side (often to use) and do the reset again.
if still not works, hmmmm.... bring to Honda dealer and prepare $$$
good luck
Old 12-05-2011, 09:13 PM
b0yg0tskills's Avatar
wait, I know this is a super super super old thread, but is it right that honda still charges me for running a diagnostic on the srs system?
Old 12-07-2011, 08:03 AM
g35silversurfer's Avatar
I have the same SRS problem. reset it like a dozen times, light still stays on.
Also I have to slam my my drivers seatbelt into the buckle to get it to latch. I'm guessing my SRS is on because of the buckle issue like many others.
I just called my local honda dealership.
basically they scan my SRS system for free. if it ends up being the faulty seatbelt they fix it, for free
if they scan it and it turns out to be something else that isn't covered under warranty like a impact sensor, then they tell me what it is and we go from there.
still no charge.
Old 12-07-2011, 03:57 PM
I think it's slightly more so the people who don't ask the right questions up front about being charged, are the ones who do get charged.
and the ones who ask the right questions don't get haggled.
Old 12-08-2011, 05:00 PM
dr_spock's Avatar
Is that life time warranty in the USA only?
Old 12-10-2011, 06:20 PM
exb18c1's Avatar
I have never heard about it here in Quebec.They charge for anything.The problem above is very common thing on 2000 and up Hondas.There is a dirt getting stuffed inside a buckle switch or a contact points getting worn down.It has a specific code ,so don't think that all the SRS light would be the same thing!However it worth a try just shooting some brake cleaner inside the buckle and clearing the codes,you might get lucky.If not -change it!!Everutime the SRS light is on IT WILL NOT ALLOW FOR DEPLOYMENT OF AN AIR BAG!!!!.So just for safety of you and your family change the damn thing!It is not more expensive than life.
Old 12-10-2011, 09:04 PM
eviee1973's Avatar
Yes those purchased cars distributed through American Honda get a lifetime warranty on seatbelts, it might be a federal law in the USA. No such luck for those of us who purchased cars distributed through Honda Canada Inc.
Old 12-12-2011, 09:36 AM
GriFFIthS's Avatar
Honda Canada only offers a 10 year to 160,000 km warrenty on the seatbelts and SRS system.
Old 12-15-2011, 08:44 AM
.:RBluHatch's Avatar
Honda America covers the buckle and seatbelt under the lifetime warranty, the only thing you might have to pay for is the diag.
Old 12-15-2011, 08:46 AM
I didnt have to pay a penny for the diagnostics/parts/labor
Old 12-15-2011, 09:03 AM
Me either. They fixed the buckle, pretensioner, and harness from the guy that neglected my ep before I had it. thumbs up to Pearson Honda in RVA.
Old 12-16-2011, 10:07 AM
Eee2003's Avatar
I just had my 2003 Honda Element at 122,000 Kms checked for SRS Air bag warning on in a Honda dealer. Charged $110+tax for Diag. I have been told the driver side buckle sensor is not working. The OPDS is 09-3(This is the code I requested). The dealer asking $247.56 for the parts and $275 for the labour. Total comes $522.56. The Diag fee will be waived if I do it there. I asked if it is covered under life time time warranty. Answer is no. I am still wondering. I am in Canada btw.
Any seggestions? How about DIY? Thanks!
Old 12-16-2011, 01:03 PM
space_eyes's Avatar
mine went on about 3-4 months ago... I haven't checked to see which seat belt yet but yeah, not covered in canada as a tb notice... stupid i think... best be is look online for seat belt assembly, car-parts, ebay etc... find yourself a good price... as for a DIY, should be in hanes i think... its online or $15 at c-tire...
Quick Reply: Seatbelt Sensor SRS light
