Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda Civic (2006 - Current)
Old 10-26-2008, 06:31 AM   #1
Dimazz
Default 2006 Honda Civic SI Torque Specs
Hello,
2006 Honda Civic SI Coupe
Could somebody with the service manual look up a couple of specs for me please. Or if somebody knows where to download and or reference the manual online a link would work too.
I need the torque specs for the FLCA to the subframe, both bushings. Brake caliper to knuckle. Lower ball joint to knuckle. Tierod to knuckle. Knuckle to strut. Wheel lug nuts.
All of this is for the front.
Thanks in advance!
Dimazz is offline   Reply With Quote
Old 10-26-2008, 07:41 AM   #2
FijiBlueFG2
You mad bro?
2008 Honda Civic
FijiBlueFG2's Avatar
Default Re: 2006 Honda Civic SI Torque Specs (Dimazz)
The dealer will tell you it is about 139ft/tq
In reality, probably closer to 120ft/tq
72 virgins can never stop a war, but 100,000 hookers can beat the Marine Corps.
FijiBlueFG2 is offline   Reply With Quote
Old 10-26-2008, 08:48 AM   #3
Dimazz
Default Re: 2006 Honda Civic SI Torque Specs (FijiBlueFG2)
What is that spec for?
Old 10-26-2008, 09:24 AM   #4
SIVIC 3
SIVIC 3's Avatar
^for the k20z3, i assume. thats what you asked about.
i put down 143 ft/lbs. but im i/h/e etc.. Click the image to open in full size.
07 NHBP FA5 - current
05 CBR 600RR - current
FA SQUAD MEMBER #129
SIVIC 3 is offline   Reply With Quote
Old 10-26-2008, 10:38 AM   #5
Nexx
Nexx's Avatar
Originally Posted by slomofo View Post
I've never had or wanted Dicks, does it taste as bad as my wife says it does?
Nexx is offline   Reply With Quote
Old 10-26-2008, 10:55 AM   #6
i-VTEC_DOHC
i-VTEC_DOHC's Avatar
i think for the lug nuts its around 70-80 i think?
FG SQUAD #1 / NOTHING ON MY CAR IS FOR SALE UNTIL MAY 16TH!!!!!
i-VTEC_DOHC is offline   Reply With Quote
Old 10-26-2008, 11:01 AM   #7
SIVIC 3
SIVIC 3's Avatar
Default Re: (SIVIC 3)
Hello,
Thanks in advance!
Old 10-26-2008, 01:16 PM   #8
RICO_
NO MERCY!
RICO_'s Avatar
Wheel lug nut specs are 80ft./lbs for all wheels. Not sure about the rest of the specs though.
My advice.....drive to a HOnda dealership and around back to the actual service shop entrance and see if you can speak to a technician directly. If they're cool enough they'll look it up for you on the spot.
"May God have mercy upon my enemies, because I won't."
--- General George S. Patton
RICO_ is offline   Reply With Quote
Old 10-26-2008, 03:00 PM   #9
Blk06Si
Blk06Si's Avatar
Send a message via AIM to Blk06Si
Front side of the lower arm mounting bolt-61
Rear side of the lower arm mounting bolt-47
The flange bolt and the self-locking nuts from the lower arm-43
Caliper to knuckle-80
Info taken from Honda interactive network. Same source technicians use. Hope this helps. Click the image to open in full size.
Blk06Si is offline   Reply With Quote
2006, 2008, acura, bolt, brake, calipers, civic, front, honda, lug, settings, si, spec, specs, torqe, torque
