Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda Civic (2006 - Current)
Old 10-23-2008, 06:08 AM   #1
z6hatchboy
z6hatchboy's Avatar
Default tire pressure sensor, reset?
My gf has a 08' civic and her tire was low so she put so air in it, and the light is still on. Im straight eg so i dont know if it has a manual reset or what. I know scion do, but thats a scion. Thanks.
flickr Nikon D700, 92 hatch (traded), 95 coupe (traded)
z6hatchboy is offline   Reply With Quote
Old 10-23-2008, 06:18 AM   #2
06BlackSi #45
06BlackSi #45's Avatar
Send a message via AIM to 06BlackSi #45
Default Re: tire pressure sensor, reset? (z6hatchboy)
The only way to get the light to turn off is make sure pressure is correct on all tires. If the light continues to stay on it will be a sensor problem.
Travis Stikeleather
2006 Civic Si -Daily Driver-, 1999 Civic Si -Sold-, 1994 Acura Integra -Sold-
1983 Civic 1500 4 Door -Still have, K20 project car-
06BlackSi #45 is offline   Reply With Quote
Old 10-23-2008, 08:38 AM   #3
ekb16
ekb16's Avatar
iTrader Rating: (1)
Send a message via AIM to ekb16
if its just a Low pressure indicator (!) then just add air up to 34psi in all the tires and drive the car for a bit and it should go back off..if its the TPMS light then there is a mechanical problem wit the sensors or something else
B.A.R. member as of 3/18/09 JDM gsr in 98 hatch
Voches: chickwithastick,93allmotorcoupe,jomama,punoy69,Tom theman70
ekb16 is offline   Reply With Quote
Old 10-23-2008, 09:23 AM   #4
scott0
scott0's Avatar
Send a message via AIM to scott0
Default Re: (ekb16)
unfortunately the only way to reset the TPMS light is to go to a dealer.
if its only the low tire pressure light that is on make sure the tires have the peoper amount of air. if it stays on it will need to go to a dealer to get the TPMS monitors re calibrated.
-Scott0
scott0 is offline   Reply With Quote
Old 10-23-2008, 01:00 PM   #5
av911
av911's Avatar
Default Re: (scott0)
http://www.8thcivic.com/forums....html
av911 is offline   Reply With Quote
Old 10-24-2008, 06:40 PM   #6
Blk06Si
Blk06Si's Avatar
Send a message via AIM to Blk06Si
Set the tires at 32 PSI. Check for nails in all 4 tires. If there are no nails found and light is still on after you have at least hit 25 mph then you will need to reset the Tire Pressure Monitor Sensor. Bleed the air pressure from the tires to at least 18 psi. It's gotta bleed at least 3 psi within 15 seconds for the sensor to reset itself. Easier and quicker way to reset them is to buy a tire valve remover to let all the air out of the four tires and then refill them. Or you can always take it to a dealer to do what I explained. Hope that helps Click the image to open in full size.
Blk06Si is offline   Reply With Quote
09, 2008, accord, checking, civic, crv, honda, indicating, light, pressure, reset, resetting, sensor, sensors, stays, tire
