Go Back   Honda-Tech > Community Forums > General Discussion and Debate > Electronics, Gaming & Photography
Old 10-22-2008, 12:38 PM   #1
Archidictus
Unceasing Measure
2011 Chevrolet Cruze
Archidictus's Avatar
https://www.facebook.com/michael.gould.355
Send a message via AIM to Archidictus
Default "Insufficient memory available to complete the operation"
This is relatively time-sensitive, so any answers I can get would be wonderful.
To preface this - I've already restarted, rebooted, unplugged and otherwise let my computer cool down.
So I'm working in Adobe Illustrator (here at work) and need to export several files as JPEGs. This has never been a problem before, as the laptop I use is rather powerful and has plenty of space, however, while I can still save changes to the illustrator document (huge file), the program is coming up with this window:
whenever I attempt to export anything (as jpeg, gif, bmp, etc.). This just started happening after I allowed the computer to reboot at the behest of Windows [freak]-Updater. The operating system is XP and the computer has been running fine until this.
Any suggestions?
This is only happening in Illustrator (the program I need right now). I can export and save things just fine in other programs.
But now the summer's dreams are bent like grain against the scythe, and memories of blissful days, they fall like leaves.
Archidictus is offline   Reply With Quote
Old 10-22-2008, 03:21 PM   #2
qhondak
qhondak's Avatar
i can think of two things. You dont have enough virtual memory, or have have too many applications opened. try closing some applications before exporting those files.
qhondak is offline   Reply With Quote
Old 10-22-2008, 04:43 PM   #3
The GreenD16
2008 Honda Accord
The GreenD16's Avatar
Default Re: "Insufficient memory available to complete the operation" (Archidictus)
How big of files are we talking about? How big of a page file do you have setup? How much RAM?
The GreenD16 is offline   Reply With Quote
Old 10-22-2008, 07:40 PM   #4
egsleepercivic
egsleepercivic's Avatar
if all this started happening after an update I would sart with a system restore first, prior to the update, if problem persist, then start check memory, pagefile, and file size etc.. like others have mentioned
gl
WTB : Complete gsr/type r short block Florida, will take long block if price is right
egsleepercivic is offline   Reply With Quote
Old 10-23-2008, 05:22 AM   #5
Archidictus
Unceasing Measure
Default Re: (qhondak)
Neither of those - I tried them before I made the post. This problem just started occurring, and it happens regardless of the number of programs open.
I was working off an 8.02 Meg file, exporting no more than a few hundred Kbs at a time - nothing different than I had been doing all day. RAM is over 1000 (hasn't changed since the problem started), page file is very large.
gl
I'm probably going to roll it back now, since the tech support guy couldn't figure it out Click the image to open in full size.
Thanks for all the help, fellas Click the image to open in full size.
Old 10-23-2008, 10:58 AM   #6
Tim2179
eight equals equals equals D
1963 Buick Riviera
Tim2179's Avatar
iTrader Rating: (2)
Stumpjumper Pro
Default Re: (Archidictus)
Which version of AI are you using? I have AI 8, AI 10 and CS, but I prefer working in 8 since it's a lot faster than the newer versions.
AI files are usually pretty small (compared to PS files). Do you have linked or embedded images in your AI file? Embedded images will increase you file size and also use more memory. Linked images will decrease your file size.
You can dump your unused swatches and brushes to reduce your file size. (typically these libraries add about 300kb to all your files)
For a temporary fix, you might want to take a screen capture and save that as a jpeg.
Usually if I get an AI memory error, I can close a few programs and it will work, but I'll have to restart AI too.
Save $25 when you sign up for Ting mobile: tingreferral.wordpress.com -- I get $25 too, so DO EET!
Tim2179 is offline   Reply With Quote
Old 10-26-2008, 05:28 PM   #7
iam7head
iam7head's Avatar
Default Re: (Tim2179)
i use to run cs2 and it's doing that to me all the time(one gb rams on XP professional), crashing while saving, memory going thru the roof, etc
go search up adobe to see if your version of Ai have a known problem with accessing rams.(they probably do but the solution is often just to get the newest ai =/ )
<---running cs3 with 6 gb rams and x4 cores
Honda s2000 Ap1 00' Silverstone(153lb-ft of torqueless wonders)
Mazda Miata Mx-5 90' BMWjetblack(116hp of ball-less fury)
iam7head is offline   Reply With Quote
6gb, adobe, ai, ap1, available, complete, cs3, export, exporting, illustrator, insufficient, jpeg, memory, operation, save
