> Honda CRX / EF Civic
New! Use your Facebook to securely log into this site, click logo to login
Old 10-12-2008, 09:07 PM   #1
vtecn8ive
vtecn8ive's Avatar
Send a message via ICQ to vtecn8ive Send a message via AIM to vtecn8ive
Default Seat options for 1990 Civic Ex?
I recently picked up a 90 Civic Ex as my college car.
Its got the pimp Red interior
In the future FUTURE I would like to swap it all out for black interior. I have seen in the past 94-01 Integra Seats in the Civic front and back!! I was wondering if anyone is familiar with this swap.
If you have, how high did you sit in them? Hopefully lower!
Thanks,
Shane
Modified by vtecn8ive at 11:42 PM 10/13/2008
91 Civic Rt4wd+d15z1
90 Crx HF stock+some goodies Vouches
vtecn8ive is offline   Reply With Quote
Old 10-13-2008, 05:08 PM   #2
jdqcivicp72
jdqcivicp72's Avatar
Send a message via AIM to jdqcivicp72
Default Re: Seat options for 1990 Civic Ex? (vtecn8ive)
i got a 91LX with driver side 98 gsr seats. all bolts in but the rear left bracket sticks out by an inch i uses a fat washer and a open end lug nut with a extended 12mm bolt. took out the gsr buckle and used the 91 sedan power seat belt and buckle had to drill the holes bigger inorder for the 17mm bolt to bolt back into the gsr seat. so yes im using 4 bolts if you want DA seats just use your ef brackets.
94 EJ coupe EX a/c, p/s 91 ED sedan LX a/c, p/s
jdqcivicp72 is offline   Reply With Quote
Old 10-13-2008, 05:09 PM   #3
jdqcivicp72
Default Re: Seat options for 1990 Civic Ex? (jdqcivicp72)
heres the rear
Old 10-13-2008, 05:11 PM   #4
jdqcivicp72
they sit higher then my crx seats check out efcivicsedan.myfreeforum.org theres some pics there too
Old 10-13-2008, 05:31 PM   #5
vtecn8ive
vtecn8ive's Avatar
Thanks man. I appreciate it. Pics help a bunch!
Old 10-13-2008, 07:29 PM   #6
dem0nk1d
dem0nk1d's Avatar
Send a message via AIM to dem0nk1d
what about rear seats?
95 EG Civic (R.i.P T-Boned)
89 EF Sedan (Current Project)
"keep a full interior and still be fast!!!! leave the stripped interiors to the real racecars!!!!" -sikefcrx89
"don't be a ricer! keep your bumper support kids, it might save your life." -dem0nk1d
dem0nk1d is offline   Reply With Quote
Old 10-13-2008, 08:44 PM   #7
vtecn8ive
vtecn8ive's Avatar
Default Re: (dem0nk1d)
Woot 4000 post!
Anyways this is the car I first saw this swap going on in:
http://www.hondamarketplace.co...83776
I tried contacting the seller (i knew owner before this guy) but have yet to get an answer. hopefully he gets back to me.
Old 10-14-2008, 12:20 AM   #8
UKDMEP3
UKDMEP3's Avatar
i heard EP seats fit EF chassis jus word of mouth havnt tried it yet
UKDMEP3 is offline   Reply With Quote
Old 10-14-2008, 05:52 AM   #9
vtecn8ive
vtecn8ive's Avatar
Default Re: (UKDMEP3)
I'm pretty sure thats for the Crx/Civic hatch and thats with the seat pan swap method. I was actually trying to avoid the seat pan method, as I've done similar before.
In the past i've installed Del Sol seats in Civic Hatch (ef) and I actually ended up welding and test fitting etc.
I just want something simple this time around.
Old 10-14-2008, 07:59 AM   #10
jdqcivicp72
did the crx seat with sedan brackets cut n weld, don't recommend eventually it'll break plus they sit closer to hand brake. power seat belt rub against both upper seat and lower.
Old 10-14-2008, 11:17 AM   #11
mario_pic
mario_pic's Avatar
use eney 91 civic seat i used a 91 si seat and did a pan swap the best part is the the passenger seat becomes the driver seat if u got a ef sedan woot got a mint driver now and a passenger is simple to find after words
CARFAX reports.
mario_pic is offline   Reply With Quote
Old 11-11-2008, 12:02 AM   #12
crx-90
crx-90's Avatar
i was wondering if the civic 2000 si seats fit?
crx-90 is offline   Reply With Quote
Old 11-11-2008, 01:02 AM   #13
therotaryrocket
therotaryrocket's Avatar
In the FAQ it looks like most of the guides show swapping out the seat pans, just transfer the foam and fabric onto your original seat pan. I think this will work for many different seats, however I remember hearing the integra's backrest is at a weird angle or something after matching it to the civic's seat pan?
Anyhow, I want to find the seats out of an 88-91 Prelude (Si?), I like their style and they feel nice to me! (pretty good side bolsters from what I remember).
therotaryrocket is offline   Reply With Quote
Old 11-11-2008, 01:05 PM   #14
vtecn8ive
vtecn8ive's Avatar
Default Re: (therotaryrocket)
I actually have a spare set of Prelude seats out of that year you are referring too. However, they were intended for a Civic years ago and have been sitting since. I'm debating trying to get them to work in the Sedan or not.
Old 11-16-2008, 02:03 AM   #15
crx-90
crx-90's Avatar
well... i would like to know if the em1 si seat will fit without any mods..? please let me know... thanks
Old 11-16-2008, 03:21 AM   #16
vtecn8ive
vtecn8ive's Avatar
Default Re: (crx-90)
?? start your own thread rather then thread jacking.
Bookmarks
1990civic, 8891, 90, civic, crx, ef, gsr, lx, options, seat, sedan
Site Guidelines - Contact Us - Honda-Tech.com -
Top
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
