Go Back   Honda-Tech > Honda and Acura Technical Forums > Suspension & Brakes
Old 10-11-2008, 05:10 AM   #1
PhatRoyale
PhatRoyale's Avatar
Default Lowering spring settling time?
I just had a brand new set of lowering springs installed on the car two days ago and notice that it's a bit higher in the rear than it was before....
Does anyone know how long lowering springs normally take to settle in to their maximum drop?
Should I add weight to the other three corners of the car to even out or speed up the process?
PhatRoyale is offline   Reply With Quote
Old 10-11-2008, 11:46 AM   #2
alphalanos
2000 Honda S2000
alphalanos's Avatar
Send a message via AIM to alphalanos
Default Re: Lowering spring settling time? (PhatRoyale)
What kind of springs? It should not be higher at all if they are lowering springs. Maybe they mixed them up or forgot to compress the suspension when tightening bushings.
2000 Honda S2000
alphalanos is offline   Reply With Quote
Old 10-12-2008, 05:16 AM   #3
PhatRoyale
PhatRoyale's Avatar
They're Espelir springs.
To elaborate, I measured everything out and it worked out to be:
Front driver side: 2 finger gap
Front passenger side: 1 finger gap
Rear driver side: 2 finger gap
Rear passenger side: 3 finger gap
My question is will these gaps even out over time?
How many miles would I have to put on them before I notice a difference?
Old 10-12-2008, 05:46 AM   #4
PatrickGSR94
1994 Acura Integra
PatrickGSR94's Avatar
iTrader Rating: (1)
Send a message via AIM to PatrickGSR94
Springs do not settle or sag. If they do then they're either broken or cheap POS's.
What most people think of as "spring's settling" is actually the suspension bushings stretching or even tearing. You need to tighten all control arm bushings at ride height whenever ride height is changed. Take your wheels back off, loosen all the control arm bushings, put a jack under each corner and raise the suspension up to load it, and then tighten each bushing back to factory torque spec.
Please do not PM me with technical questions. Create a thread in the appropriate forum.
H-T OG member #8927 class of '02 ● Koni + GC InstallHID retrofit club
member #0001
PatrickGSR94 is offline   Reply With Quote
Old 10-12-2008, 10:31 AM   #5
vtecvoodoo
vtecvoodoo's Avatar
Send a message via AIM to vtecvoodoo
Default Re: (PhatRoyale)
Yes! The finger measuring system!
www.Eibach.com "Horsepower For The Turns"
vtecvoodoo is offline   Reply With Quote
Old 10-12-2008, 10:53 AM   #6
PIC Performance
PIC Performance's Avatar
Send a message via AIM to PIC Performance
Honestly... measuring with your fingers? Come on. Come OOOONNNNN.
http://www.officemax.com/omax/...ry_Id=
PIC Performance is offline   Reply With Quote
Old 10-12-2008, 08:35 PM   #7
PhatRoyale
PhatRoyale's Avatar
Thanks to those who actually had the patience to deal with a n00bish question and offer useful advice.
The measurement was meant to be a rough point of reference, but my point is that there is definitely a noticeable difference.
Old 10-13-2008, 12:27 PM   #8
TunerN00b
TunerN00b's Avatar
Fenders can move slightly.
A better reference point would be to measure from the ground to the side jack points, both the front and rear.
Additionally, the car will be a little uneven. It wasn't perfectly level stock, and won't be after lowering, its just more visible with the smaller fender gaps.
This is correct. Failing to "clock" the bushings correctly could result in a higher ride height until the bushings rotate/wear/tear on their own.
The only bushings you can't clock like this are the large trailing arm bushings. You need to press those out, rotate, and reinstall, to set to the new ride height.
I didn't bother with those (TA), just the rest, and my car didn't settle. Those large TA bushings do seem to be wearing faster than the rest, though whether thats due to how they deform under use or my failing to clock them, I can't say.
TunerN00b is offline   Reply With Quote
asd, drop, espelir, honda, hr, long, loosening, lowering, set, settle, settling, spring, springs, tech, time
