Old 10-10-2008, 01:02 PM   #1
Semih166
Semih166's Avatar
Default 98 Civic bad smell from air
There is bad smell coming from the vents when i turn the air or heater on, does anybody know what the problem might be? Water in the canals maybe ?
Semih166 is offline   Reply With Quote
Old 10-10-2008, 01:08 PM   #2
slo_hatch
slo_hatch's Avatar
Default Re: 98 Civic bad smell from air (Semih166)
dead rat/mouse Click the image to open in full size.
02 SS ap1- Spoon|RSG|Enkei|
98 ej6 hatch- the DD
slo_hatch is offline   Reply With Quote
Old 10-10-2008, 01:48 PM   #3
jap.cars.rule
jap.cars.rule's Avatar
Girlfriend's underwear?
jap.cars.rule is offline   Reply With Quote
Old 10-10-2008, 02:01 PM   #4
grandtheftlunchbox
grandtheftlunchbox's Avatar
Send a message via AIM to grandtheftlunchbox
Algae and **** is clogged up in the evaporator drain causing water to sit inside the box and start smelling bad. Stick a long pipe cleaner up into the drain tube that comes out from under the car (the one that drips water when you have your A/C on) and it should clear that sucker out. just stay out of the way when you clean it out because nasty green water will probably splash everywhere. afterwards spray some air freshener into the cowl in front of the windsheild and crank the A/C. Click the image to open in full size.
Rockin' the DOHC D.
grandtheftlunchbox is offline   Reply With Quote
Old 10-10-2008, 02:36 PM   #5
biggie1805
biggie1805's Avatar
yea bro.... you might just have your headers craked.....you need to weld them and stop the air from coming out...your air vent are in front of your headers so if its coming through your vent make shure envrything is tight or check if your headers are cracked...
biggie1805 is offline   Reply With Quote
Old 10-10-2008, 04:04 PM   #6
Radim
Radim's Avatar
iTrader Rating: (4)
Default Re: 98 Civic bad smell from air (biggie1805)
It's probably some mold, my brother's TC had the same problem he installed a cabin air filter(Doesn't come with one from factory) and it doesn't smell anymore.
Don't know if 98 Civics have cabin air filters though.
EDIT: If you want to test for a cracked header, put a little seafoam in the brake booster. Found a leak in my 89 Hatch that way. Click the image to open in full size.
http://www.facebook.com/pages/Projec...06534682732095
Add PMG on Facebook!
Radim is offline   Reply With Quote
Old 10-10-2008, 04:48 PM   #7
tx_ej8_49
tx_ej8_49's Avatar
Send a message via AIM to tx_ej8_49
Probably not a cracked header if it doesn't smell like exhaust. The smell is most likey something dead/decomposing (sp?) under the dash or in the engine bay, or the drain hose is clogged and water has back up into the evaporator and is no stagnant goo.
tx_ej8_49 is offline   Reply With Quote
98, air, animal, bad, civic, coming, dead, exhaust, heater, honda, smell, smelly, vent, vents, weird
