Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda Prelude
Old 10-09-2008, 08:12 AM   #1
GibsonNO!
GibsonNO!'s Avatar
Default Oil Leak
I have an oil leak on my car coming from the drivers side of the engine. I was wondering where this car normally leaks oil in this area from and I know to look around the area requires removing the valve cover and other various covers. Just wondering if anyone else has done this and how much work is involved before I go in to explore the leak further. The leak is a constant drip in a 97 prelude base.
GibsonNO! is offline   Reply With Quote
Old 10-09-2008, 08:38 AM   #2
VTecLude1994
VTecLude1994's Avatar
iTrader Rating: (1)
Send a message via AIM to VTecLude1994
Default Re: Oil Leak (GibsonNO!)
I'd say cam seals. If so just plan on doing a timing belt job.
Originally Posted by rich045
its Christmas, do you have to be that uptight? maybe i should ask santa to get you laid...
VTecLude1994 is offline   Reply With Quote
Old 10-09-2008, 09:33 AM   #3
ROM_lude
ROM_lude's Avatar
i have the same prob
so when u get an answer let me know Click the image to open in full size.
ROM_lude is offline   Reply With Quote
Old 10-09-2008, 02:36 PM   #4
jzobie1
jzobie1's Avatar
Default Re: Oil Leak (ROM_lude)
Try the valve cover, they love to leak and make it look like other things are leaking. Mine leaked out the back corner of the valve cover into the timing belt cover along the seam and I could not trace it up from the oil pan because of that. I eventually replaced the valve cover gasket and all was well.
1996 Audi A4 2.8QM
1993 Prelude Si 4WS---Sold http://images.honda-tech.com/set1/smile/emsad.gif
1982 Honda CB900F---Sold
2000 Kawasaki Ninja ZX-6R
Originally Posted by Rguy
It's about God damned time North Dakota contributed to something in this nation.
jzobie1 is offline   Reply With Quote
Old 10-09-2008, 04:07 PM   #5
teambk8
teambk8's Avatar
Default Re: Oil Leak (jzobie1)
do those then clean the engine bay and see if it still leaks. I believe there are kits out there where you can put some stuff in your oil to make it viewable with a uv light or those yellow glasses or something... I would replace the valve cover gasket (or inspect it and use some sealant on it when u put the cover back on depending on your budget) then clean and inspect... good luck. If it turns out to be the cam seals, do the timing belt and tensioner while you are at it.
teambk8 is offline   Reply With Quote
Old 10-10-2008, 04:47 AM   #6
mattsnooz
mattsnooz's Avatar
Default Re: Oil Leak (teambk8)
yeah, oil and timing belt is a bad combo. Thats a new motor usually! Or rebuild Click the image to open in full size.
h23, the stroke is long, and strong, and she wants to get the friction on.
http://www.comfortcurtains.totalwarehouse.com
mattsnooz is offline   Reply With Quote
Old 10-10-2008, 07:42 AM   #7
slammed95lude
slammed95lude's Avatar
Default Re: Oil Leak (mattsnooz)
try right where the filter attaches there is a gasket on the back of the cooler towards the block....it leaks on every H22
1995 Honda Prelude SE - JDM as F#%&
1995 Honda Prelude SI - back to stock and ready to sell
1950 Chevy 5 window pickup - all original
slammed95lude is offline   Reply With Quote
Old 10-10-2008, 08:22 PM   #8
ShoofIsLudin
ShoofIsLudin's Avatar
Send a message via AIM to ShoofIsLudin
the oil cooler is in the center of the block. It usually drips onto the exhaust, pressure switch and/or o2 sensor if its the oil cooler o-ring (not gasket)
Definately check the valve cover, and try to trace the leak.
I'd make sure ur oil pan bolts and nuts are snugged up, and make sure ur drain bolt on the oil pan isn't leaking.
ShoofIsLudin is offline   Reply With Quote
Old 10-17-2008, 08:00 AM   #9
GibsonNO!
GibsonNO!'s Avatar
Default Re: (ShoofIsLudin)
Oil cooler gasket replaced, oil pan removed checked for leaks and cracks turned out good, oil pan re-installed new gasket, I also retapped the oil plug for a slightly larger bolt since the jackass before me thought silicone would fix a stripped oil plug. That's what I have down so far to narrow down my search. Has anyone replaced cam seals I was just wondering the amount of time it takes I'm in school and would like to know if this is a weekend job or wait until x-mas when I have more time since I need my car to get to campus.
Old 10-17-2008, 09:36 AM   #10
vinuneuro
vinuneuro's Avatar
Send a message via AIM to vinuneuro
Default Re: (GibsonNO!)
It's the equivalent of a timing belt job, plus having to remove the cam gears from the cams.
vinuneuro is offline   Reply With Quote
Old 10-22-2008, 06:19 AM   #11
jzobie1
jzobie1's Avatar
Default Re: (vinuneuro)
Dude, seriously, before you start ripping your motor apart more spend 10 minutes and $10 replacing the valve cover gasket.
1996 Audi A4 2.8QM
1995, 2003, back, block, distributor, exhaust, filter, honda, leak, leaking, leaks, odyssey, oil, prelude, pressure, switch
