b16a2 sputtering shutting off
Old 10-08-2008, 12:06 PM
04silvep3's Avatar
Default b16a2 sputtering shutting off
ok well iv had the car for about 5 months with the swap NEVER had this problem before if i eas off from a dead stop after like 3000 rpm its sputters until around 5000 then shutts off but it catches itself at 1500 rpm and does the same in second but only at certain times does anyone have any idea whats going on
Old 10-08-2008, 02:01 PM
04silvep3's Avatar
anyone?
Old 10-08-2008, 05:59 PM
z6hatchboy's Avatar
Possible igniter coil, try a new dizzy
Old 10-08-2008, 06:00 PM
z6hatchboy's Avatar
check for codes too
Old 10-08-2008, 07:24 PM
ttm_sales's Avatar
You should check for fuel issues, possibly bad pump or fuel filter issue.
Old 10-08-2008, 08:46 PM
04silvep3's Avatar
ok well no codes as as far as the rest ill try fuel pump is only 4 months old an its only wen im driving in first or second
Old 10-08-2008, 08:58 PM
Ctown2Ctown's Avatar
Default Re: (04silvep3)
sounds kinda like a map sensor problem or an ignition problem to me <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by z6hatchboy &raquo;</TD></TR><TR><TD CLASS="quote">Possible igniter coil, try a new dizzy</TD></TR></TABLE> this man speaks the truth. break out the old voltmeter, and get the factory voltage table for the map sensor from honda, and check it the old fashioned way.
Old 10-09-2008, 07:38 AM
04silvep3's Avatar
well i checked the spark with a spark tester an its sparking just fine i can try another map sensor but wuddnt any of this throw a code?
Old 10-12-2008, 06:47 PM
04silvep3's Avatar
ok well would this have anything to do with my IACV i just checked my codes again today and now i have a code 14 for IACV any idea?
Old 10-12-2008, 06:55 PM
DCFerris's Avatar
yeah that would make the rpms to jump around. what you could do is take off your iacv and clean it and check the o rings to make sure there still good and see if it helps any just go down to an auto part store and buy carb cleaner and spray it down
Old 10-12-2008, 07:05 PM
04silvep3's Avatar
but it wud make the car shut off an come back like that?
Old 10-13-2008, 05:36 AM
04silvep3's Avatar
Default Re: b16a2 sputtering shutting off (04silvep3)
Old 10-14-2008, 03:01 AM
DCFerris's Avatar
i dont think it would make it shut off like that but its not gonna hurt any if you do check out you IACV but thats just thinking
Old 10-15-2008, 06:43 AM
04silvep3's Avatar
replaced the iacv no difference still doin it
Old 10-16-2008, 08:52 PM
04silvep3's Avatar
update got some new codes now
p1456 manufacturer control auxiliary emissions controls
p0170 fuel trim malfunction
Old 10-16-2008, 08:53 PM
04silvep3's Avatar
anyone know what this is its driving me nuts
Old 10-16-2008, 09:28 PM
Honda-Pilot's Avatar
Make sure the TPS and MAP sensors arn't broken from shipping the motor.
Once it throws a CEL, check for the codes before you shut the motor off.
The P1456 is EVAP leak, usually the gas cap is lose.
Old 10-16-2008, 09:43 PM
04silvep3's Avatar
gas cap is fine the tps is good i gotta check the map an i cant figure out that fuel trim malfuntion
Old 10-16-2008, 09:49 PM
The fuel trim problem is probably a result of your missfire, it's not the actual problem.
Until you get a code, your on a wild goose chaise. You should be looking for a code reguarding CKP, MAP, TPS, CMP, or TDC.
Old 10-17-2008, 04:05 PM
04silvep3's Avatar
well my car dosnt misfire i guess il startby changing the map cuz everything else is new
Old 10-17-2008, 04:24 PM
That's an expensive guess. I'd test it first. Hook your volt meter up to the signal wire and slowly create vacuum with your vacuum guage. The voltage should increase slowly as you add vacuum. If there is a voltage spike somewhere, then the sensor is bad. You should be doing this with the key on engine off and the connector connected. This test is best done with a scope, where you can actually watch to voltage increase. Good luck!
Old 10-19-2008, 04:54 PM
04silvep3's Avatar
well i swapped the ecu and now the car dosnt shut off or sputter so im gunna need a new ecu
crave13k
09-02-2011 11:33 PM
1SlowSiHB
12-21-2009 04:47 AM
ScandalousCivic
05-10-2005 06:20 PM
The G2 Racer
11-06-2002 03:29 AM
Quick Reply: b16a2 sputtering shutting off
