Go Back   Honda-Tech > Honda and Acura Technical Forums > Welding/Fabrication
Old 10-02-2008, 11:49 AM   #1
JDMCRX
JDMCRX's Avatar
iTrader Rating: (2)
Send a message via ICQ to JDMCRX
Default Mig welder argon gas setting?? Anyone?
I borrowed my buddies licoin sp-135 and i need to know what to set the CFM to. just doing 20gu steel welding.
1999 Acura 1.6EL turbo D16Y8 300whp 2002 Suzuki Grand Vitara with H27 1995 Honda Civic SI Build thred http://honda-tech.com/showthread.php?t=23987711994 Honda Accord Wagon Build thread http://honda-tech.com/showthread.php...9#post36883659
JDMCRX is offline   Reply With Quote
Old 10-02-2008, 12:12 PM   #2
MilwaukeeMotorwerks
MilwaukeeMotorwerks's Avatar
run 15-20
Milwaukee Motorwerks
MilwaukeeMotorwerks is offline   Reply With Quote
Old 10-03-2008, 08:58 PM   #3
postman
postman's Avatar
postmankilla
Default Re: (MilwaukeeMotorwerks)
you should be running mix gas
postman is offline   Reply With Quote
Old 10-04-2008, 09:44 AM   #4
JDMCRX
JDMCRX's Avatar
iTrader Rating: (2)
Default Re: (postman)
Yeah i know im just doing body work. My tig uses argon so im just gonna use that.
Im doing a tiny bit of body work should be ok with the argon tho ?
Old 10-04-2008, 09:57 AM   #5
ExVtec
ExVtec's Avatar
Default Re: (JDMCRX)
It will work. Seems like the "ideal" mix is 75/25 argon/cO2
15-20 seems to work great for most mild steel apps.
[sold] 99 Si (boosted) 450whp / 325wtq - 57 trim Stock Sleeves
[current] 05 Berlina Black S2k - 700whp / 503wtq - PT6265 Built motor.
ExVtec is offline   Reply With Quote
Old 10-04-2008, 01:51 PM   #6
9295EJ-t
9295EJ-t's Avatar
iTrader Rating: (1)
argon wont work well at all.. you need a mixed gas... 75/25..
as far as cfm settings, anywhere from 15-30cfm, depending on the wind factor, will work...
Welder/Fabricator @ MaseEngineering
www.maseengineering.com
9295EJ-t is offline   Reply With Quote
Old 10-04-2008, 04:20 PM   #7
fastcody1
fastcody1's Avatar
Default Re: (9295EJ-t)
just like the mix wont work with the tig
93 si agp hatch 334whp@20lbs ls stock everything 11.88@117
93 del Sol 478hp sold and missed 11.70@125.9
fastcody1 is offline   Reply With Quote
Old 10-04-2008, 09:24 PM   #8
ExVtec
ExVtec's Avatar
I have heard of people using mig gas mixtures on tig before b/c thats all they had. It wasn't perfect but it was better than nothing...is this not the case?
Old 10-05-2008, 07:38 AM   #9
JDMCRX
JDMCRX's Avatar
iTrader Rating: (2)
Default Re: (ExVtec)
Or would i be better using the flux core wire??
Old 10-06-2008, 05:42 AM   #10
9295EJ-t
9295EJ-t's Avatar
iTrader Rating: (1)
just dont try welding with straight argon if gravity is gonna be pullin on the molten bead while welding..
like an overhead, or vertical bead.. flat should be okay... it just might lack penetration.
Old 10-06-2008, 07:07 AM   #11
JDMCRX
JDMCRX's Avatar
iTrader Rating: (2)
Yeah the argon was not pentrating properly. I just used the flux core wire splatters a bit but penitrates well. Ill just grind it down a bit on both sides. and prime and paint better.
7525, argon, buying, cfm, gas, mig, ottawa, setting, settings, steel, tig, welder, welders, welding, wont, work
