1990 civic hatch
Old 04-15-2013, 12:48 AM
Steveramirez21's Avatar
Default 1990 civic hatch
I have 1990 civic hatchback dx I try to start it but the battery starts drain. What can I do to start my car
Old 04-15-2013, 04:48 PM
hondacraze16's Avatar
Default Re: 1990 civic hatch
I would get a multimeter and start troubleshooting. See where you have a short that is draining your battery. Need a good set of power schematics. good luck bud.
Old 04-15-2013, 05:11 PM
jdm_rb20's Avatar
I'd start by charging and testing the battery. If the battery is bad, it's going to lose it's charge after being parked for a short time or parked over night.
Old 05-11-2013, 09:02 AM
i found the solution but now my car will only crank but wont start i check main relay and it clicks but dont know if is the fuel pump
Old 05-11-2013, 09:40 AM
Hendersonpronk's Avatar
Turn the key to the run position, you should here the fuel pump start running. If not, then you have a fuel pump issue.
sl0waccord
03-03-2012 03:13 PM
fog raw
01-28-2012 06:52 AM
alpinekllr
01-13-2009 12:35 PM
deftones0817
07-14-2005 08:17 AM
clintwsi
12-26-2003 02:58 PM
Quick Reply: 1990 civic hatch
