Old 09-28-2008, 01:20 PM   #1
schlabobble
schlabobble's Avatar
Default 94 Honda EX Surging Idle
I just bought this car for 1100. When it is idleing it surging from 1000 to about 2000 over and over. I took it to get a diagnosis and there was no codes. They then told me that the unging had been swapped. It has a different Vtec engine in it. What should i check??? 94 Honda EX Vtec
schlabobble is offline   Reply With Quote
Old 09-28-2008, 01:27 PM   #2
Bozo_JDM
Bozo_JDM's Avatar
start with finding out what engine you have and if the ecu is the right one
Bozo_JDM is offline   Reply With Quote
Old 09-28-2008, 02:14 PM   #3
schlabobble
Default Re: (Bozo_JDM)
How do I find what engine it is?
Old 09-28-2008, 02:51 PM   #4
sony224422
sony224422's Avatar
Default Re: (schlabobble)
take a picture of it and post it. Or, theres a little ID plate on the block.. it should be facing you. I think they are over the tranny.. so look on the left right under where the head meets the block.
Look for f22xx,f23xx or h22xx, h23xx. those would be the most common to find. the xx's should be numbers depending on what it is.
96 accord lx- converted into 5spd ex http://is.rely.net/1-92-29998-l-1gbM...AmVuBW3hGg.gif
93 civic CX (project car)- Sold
1997 dodge ram 1500 sport 4x4 extended cab
360 magnum
sony224422 is offline   Reply With Quote
Old 09-28-2008, 03:41 PM   #5
Bozo_JDM
Bozo_JDM's Avatar
once you found wat engine and if everything checks out alright check the throttle body somtimes you get carbon build up and that can also cause the surging idle
Old 09-28-2008, 03:50 PM   #6
gqstatus05
gqstatus05's Avatar
Bedtime Ownage
Send a message via AIM to gqstatus05
It could be your IACV, idle air control valve or you could have a Vacuum leak. They sell a leak solution (carb cleaner, go to autozone, napa, etc) to find where the leak is coming from. It blows smoke through the lines and you are only supposed to see it come out of the exhaust. If it comes out of anywhere else in your hood then that's your leak. Hope this helps.
Cars: 96 Accord LX/1990 Nissan 300ZX/98 Accord EX VTEC
gqstatus05 is offline   Reply With Quote
Old 09-28-2008, 03:50 PM   #7
pinggoy
1995 Honda Del Sol
pinggoy's Avatar
Default Re: 94 Honda EX Surging Idle (schlabobble)
i have the same problem. but i have the f22b1 engine, check you intake filter for clogs, fast idle thermo valve ( check FAQ) also check iacv for carbon buildup and spray some carb cleaner on throttle body..
on my case it is still surging. so i just bought a new iavc hopefuly it will arrive anytime soon...
1995 Honda Del Sol
Frosty White
Looking for B16A
pinggoy is offline   Reply With Quote
Old 09-28-2008, 03:53 PM   #8
gqstatus05
gqstatus05's Avatar
Bedtime Ownage
Default Re: 94 Honda EX Surging Idle (pinggoy)
I'm fixing the same exact problem first thing tomorrow.
Old 09-28-2008, 06:04 PM   #9
lunarone
lunarone's Avatar
Send a message via AIM to lunarone
Default Re: 94 Honda EX Surging Idle (gqstatus05)
Make sure throttle cables are adjusted right, too. In one case, someone adjusted my cables too tightly and it caused this problem. Fixed by giving 1 inch tension.
lunarone is offline   Reply With Quote
Old 09-29-2008, 07:49 AM   #10
Hondaman56
Hondaman56's Avatar
Location: Filthadelphia City of Brothers and Love, PA, USA
Easy fix, replace the thermostat. My 94 did this and it drove me nuts until I figured it out. The water temp sensor is being confused because the thermostat is not controlling the water flow properly. This messes with the idle control valve. You'll find the thermostat is stuck open.
2005 Honda Accord EX, 2000 Honda CR-V EX
1999 Honda Accord EX, 1994 Honda Accord LX
1992 Honda Civic EX
Hondaman56 is offline   Reply With Quote
Old 09-29-2008, 08:44 AM   #11
schlabobble
Alright i will try all of the above and hopefully it works. I'll keep everyone posted and get some pics up
Old 09-29-2008, 03:27 PM   #12
gqstatus05
gqstatus05's Avatar
Bedtime Ownage
Man I got up early this morning and did a tune up dizzy cap and rotor, spark plugs, wires, filter, checked and filled all fluids, PLO change and oil filter. Same issue with the rpms. I removed my iacv and in the two holes some jerkoff stiluffed them with aluminium foil. I removed I an sprayed carb cleaner on it. The iacv was damaged at the part where you add the sensor the plastic part had a crack in it. I put it back on and same ****. Maybe tomorrow if I have time I will check for vacuum leak and then go shopping for another iacv. Found them for $125-130. It's aleatning experience though this has been my first job. I don't know if it's due to the motor motor being swapped it's a D16y8 maybe wrong ecu was put in?
Old 09-30-2008, 04:51 PM   #13
schlabobble
So here is the engine. there is a little somehing i found disconnected.
The engine is F22B 3105576
I cannot find where it plugs in!!!
Old 10-01-2008, 11:46 AM   #14
gentek1145
gentek1145's Avatar
iTrader Rating: (1)
Get it fixed yet?
SCW Performance : Dallas' ONLY DIY Performance Garage!
www.s2carbonworks.com
Originally Posted by skittle_107 View Post
more then you can afford pal, Ferrari
gentek1145 is offline   Reply With Quote
Old 10-01-2008, 12:07 PM   #15
schlabobble
Default Re: (gentek1145)
No i didnt. I still cant figure out where that sensor goes in this pic.... any ideas?
Old 10-02-2008, 08:53 AM   #16
schlabobble
anyone have any ideas???
Old 10-04-2008, 09:56 PM   #17
schlabobble
someone please help
Old 10-05-2008, 08:58 AM   #18
gqstatus05
gqstatus05's Avatar
Bedtime Ownage
you and me are on the same boat buddy. I have a hose that doesn't connect to anything and RPMs just bounce around. So annoying. I wish I would have bought another Accord. People there seem to know alot more than people in the Civic Section. I have a 96 Accord as well, I'm always in that section.... Sucks.
Old 10-06-2008, 04:56 PM   #19
schlabobble
No one knows where that goes?? Damn... This suck.... please.... I need help
Old 10-06-2008, 08:13 PM   #20
SOHCMAN
SOHCMAN's Avatar
Its hard to tell from the pic, but that looks like it comes from the fuel injector harness. As in should it be plugged into one of your fuel injectors? The only other thing I can think of that would be right around the injectors is a air injection system that might have had a sensor or solenoid plugged into that. (not sure what engine it is or it it did use a air injection system)
Sorry dude, looks like the PO jerry rigged the crap out of that car. I think I read something in the FAQ about if the intake manifold was changed to a manifold without air injection, you would have 4 small holes right next to where the intake runners meet the engine head. You could have a vacuum leak there? The holes would need filled with JB weld or other suitable substance to block them off...
Good luck!
sohc
94' LX Accord 5-Speed F22B2
SOHCMAN is offline   Reply With Quote
Old 01-11-2009, 01:53 PM   #21
SLOWPOLK
its the IAC valve plug for the original f22b1 vac set up.
SLOWPOLK is offline   Reply With Quote
02, 1990, 1994, 2002, 94, accord, causing, civic, control, honda, iavc, idle, idling, surging, thermostat, valve
