h23 maf
h23 maf
Can somebody put up a picture of the maf wiring mine is all messed up the three wires are different colors on eac hside so im all confused.
Re: h23 maf (whatan00b)
The wire was cut in to basically and I have to halfs one half on the clop its self has 3 wires blue and white colored and the other wires are red yellow and blue and white I need some assitance.
Re: h23 maf (Acidcrakker)
Thanks bro. That would be uber helpfull to have small hoosier towns don't know what honda are unfortanitly.
Ok I've got it wired up now and it runs the same i m sure I wired it up wrong the first time. Could that of killed the sensor? I've replaced the ecu with my spare same results. Should I check the spark plugs to see if they got fouled up?
The swap is next month. I was just trying to fix up the half *** job the old owner did at wiring his map sensor it was just wires twisted together and electrical taped. I took the wires apart but I came to find out the wires are different colors on each end. So I in a very dumb move tried every combonation of wires to get it working. I now have it wired correctly. But it still idles like crap. I changed my plugs thought I fouled em witch they were. Changed my ecu to a spare I have same model. At it still idles really bad I checked vacuum lines and what not at the idle control screw I ajusted to no results. It hesistates in first gear till 2k and then takes off like normal and drives fine in the other gears. When I let off the clutch in nuetral it drops to 100rpmish and just bounces under a grand till you put it back in gear.
Re: h23 maf (Hawkze_2.3)
Yes I know this now. One last question I bought a firewall mounted map on ebay but mine is a intake mani mointed one does that really matter?
