| Welcome to Honda-Tech! | ||
#1 |
| Garage is empty, add now |
OK, the dealer says there is nothing wrong... But my dash, head and interior lights flicker. It is like a strobe light but not bright and seems to be happening all the time or at least a few minutes after driving. Also the SRS light started coming on and the dealer says there are no codes present for the SRS light to indicate a problem. I also had to replace the battery, which had another 4 years of life on it but was now bad. I have no idea what this is. Has anyone heard what might be causing this.
#2 |
did you check the output of the alternator?
#3 |
my dash kinda does the same. kinda like when I had subs but I haven't had them in years and have bought a new alternator and battery. bump for some info
"Tap Snap or Nap" You pick! |
#4 |
Sounds like the alternator is taking a ****, otherwise clean your grounds. Might as well do that latter reguardless, they should be cleaned as often as your oil changes honestly.
#5 |
yea, check your grounds, go to someone who sells batteries and have your charging system checked. wal mart automotive has midtronics battery testers and so does checkers/schucks/kragen
#6 |
HT Black Ops
I've been having the same issue for a long time now.. Although I replaced the alt about 2 years ago so I didn't even consider it in the process of trying to find what was causing this...
[url="http://www.superiorracing.com/"]http://www.superiorracing.com/[/url] Prove how fast you are [url="http://www.saltflats.com/I30%20Club.html"]http://www.saltflats.com/I30%20Club.html[/url] <--there, not on the freeway |
#7 |
Yes, Honda had it for a day and tested it and said it was fine. I also read somewhere that a bad distributor might cause this as well. I just don't want to shell out and replace all these things and still have the problem.
#8 | |
#9 |
1995 Honda Del Sol |
i think its your grounds. alternator would be a slow dimming of everything, untill the eventual ****-taking. sounds like something is loose/damaged/dirty.
95 del sol si jdm d15b sohc VTEC, megan-racing headers, cat back-2.5" magnaflow, CAI, CROWER cam, skunk2 cam gear, BLOX IM, rebuilt head, ground control coilovers/tokica illumina's, jdm rear swaybar 23mm, black asr rear subframe brace, tuned at Church auto. |
| Tags |
| 1999, 2000, 2004, 99, alternator, civic, crv, flicker, flickering, headlights, honda, light, lights, pulsating, srs |
