OEM Radiator - TOYO vs. DENSO
Old 09-10-2008, 07:57 PM
EG8AI's Avatar
Default OEM Radiator - TOYO vs. DENSO
I cracked my radiator today. Planning on buying one from the dealership. Anybody know the difference between the radiator (toyo) and radiator (denso)? Denso is a bit more expensive maybe due to the material it's made out of? Just want to clarify and figure out what's the difference before I buy, unless anyone else has suggestions! Thanks.
Old 09-10-2008, 08:47 PM
turbojdmhatch's Avatar
Default Re: OEM Radiator - TOYO vs. DENSO (EG8AI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG8AI &raquo;</TD></TR><TR><TD CLASS="quote">TOYO vs. DENSO</TD></TR></TABLE>
toyo makes tires.....koyo makes radiators
Old 09-10-2008, 09:30 PM
EG8AI's Avatar
Default Re: OEM Radiator - TOYO vs. DENSO (turbojdmhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbojdmhatch &raquo;</TD></TR><TR><TD CLASS="quote">
toyo makes tires.....koyo makes radiators</TD></TR></TABLE>
sorry sir. but i said OEM not aftermarket. koyo makes AFTERMARKET radiators smart guy. they aren't from the original manufacturer. if you go to a honda part website, there is clearly TWO different radiators--TOYO and DENSO. please be less ignorant next time you post something.
ADD to the solution, not the problem.
Old 09-11-2008, 12:20 AM
steeltoe's Avatar
yes I'm in the same situation and found out for ya!
the fan mounting points are different..make sure you get the right one. got it from here:
http://www.hondacarforum.com/h....html
this confirms it:
http://www.hondacivicwagon.com...iator
this is very interesting:
while you're at it take a look at this too, just found out about it and am thinking of trying it.
http://www.evanscooling.com/main1.htm
Modified by steeltoe at 1:45 AM 9/11/2008
Old 09-11-2008, 06:40 AM
EG8AI's Avatar
Default Re: OEM Radiator - TOYO vs. DENSO (steeltoe)
thanks! :D. hopefully changing the hoses and thermostat along with it!
Old 09-11-2008, 06:49 AM
speedfreek128's Avatar
you can order a Koyo oem replacement radiator for around $100 just look around online....i bought mine from importrp.com
Old 09-11-2008, 07:21 AM
boondox_saint's Avatar
I am planning on grabbing an all aluminum one from ebay for $80, I have read good stuff so far about them.
http://cgi.ebay.com/ebaymotors...ZWDVW
Old 09-11-2008, 10:05 PM
steeltoe's Avatar
you can also add this coolant filter and have a bullet proof system:
install:
http://neptune.spacebears.com/....html
in the link above there's an email link for musselman in texas, called the guy and he doesn't sell it anymore..just ebay has it.
sold on ebay:
http://stores.ebay.com/FasterJ...QtZkm
just make sure you order the right size if you buy one.
Modified by steeltoe at 11:37 AM 9/15/2008
Modified by steeltoe at 11:45 AM 9/15/2008
Old 09-11-2008, 10:41 PM
EG8AI's Avatar
thanks for the info bro! ima call up the dealership when i have time to see their take on this question.
Old 09-11-2008, 10:50 PM
riceburnerryan's Avatar
that filter thing is pretty cool... could you DIY possibly? just curious... maybe having a shop make a T similar to that one
Old 09-12-2008, 12:05 PM
EG8AI's Avatar
Default Re: (riceburnerryan)
well to figure out which radiator you have, just look at the fan blades. using the pictures provided by honda, you can see how each fan is shaped differently. mine turned out to be a toyo, which was like +$50 more . heh oem stuff is expensive!
Old 09-12-2008, 07:17 PM
steeltoe's Avatar
Default Re: (EG8AI)
thx...dealer radiators are very durable
that filter is very easy to install and simple but very effective...for being a piece of plastic and a few other pieces $65 is kind of pricey but unless you can whip something together quickly that's just as effective and ease of use then you'll be waisting more time than what that filter is worth I think. a trip to home depot may help me put something together but if I can't find anything there then I'm sure gonna order one for their asking price.
new radiator + evans coolant + coolant filter = radiator that should theoretically last the life of the car, unless of course you smash it up..lol
Mikej425
06-18-2008 03:45 PM
Selkie
11-09-2007 09:58 AM
spotscivic
06-21-2007 04:49 AM
.dave
07-27-2006 06:25 AM
sp0017
10-01-2003 12:24 PM
Quick Reply: OEM Radiator - TOYO vs. DENSO
