> Honda CRX / EF Civic (1988-1991)
Old 09-02-2008, 10:12 AM   #1
crxH4
crxH4's Avatar
Default obd-0 to 0bd-1
Hey guys,
I need to convert to OBD1. I am running a stock D16A and i know i have to change to a 4 wire 02 sensor but i dont know what type of distributor i need. I have read so many different suggestions but they all contradict each other. I is hust a obd0 D16A non-vtec head. Which obd1 dizzy would fit. The reason i am going to go to obd1 is to run a Hondata.
Any help?
crxH4 is offline   Reply With Quote
Old 09-02-2008, 10:33 AM   #2
crx_si-r
crx_si-r's Avatar
Send a message via AIM to crx_si-r
Default Re: obd-0 to 0bd-1 (crxH4)
the distributor that you need is a TD-41U or TD-42U.
TD-41U found on DX, LX civics from 92-95
TD-42U found on EX, Si civics from 92-95
it all depends on what your set up is going to be. if your stayin non vtec you can use a TD-41U but it might not bolt up to your current motor. i know when i did a mini me i had to modify the ears to bolt up to my old D16A6 bottom and D16Z6 head.
CJ's Tuck Harnesses
CRX LOG
crx_si-r is offline   Reply With Quote
Old 09-02-2008, 10:51 AM   #3
crxH4
crxH4's Avatar
Default Re: obd-0 to 0bd-1 (crx_si-r)
thanks for the info!
i am going to keep the engine stock with the D16A head.
anyone got one of those distributors laying around or know where i can get one.
Old 09-03-2008, 07:38 PM   #4
crxH4
crxH4's Avatar
another questions,
The Td-41U says it is for the 1.5L . Is it ok to run on the 1.6L. or what about the TD42U that is for Vtec engines. Is that ok to have even if im not running vtec
Old 09-04-2008, 10:23 AM   #5
crxH4
crxH4's Avatar
any takers
Old 09-04-2008, 01:41 PM   #6
hammergunner
1989 Honda Civic
hammergunner's Avatar
if the motor has a distro already just rewire it for obd0, this is assuming you have a si or hf car
the other two wires black and blue, wire right up the the new distro black and blue wires
If you want to rock her use the Shocker!
hammergunner is offline   Reply With Quote
41u, 42u, determine, distributor, dizzy, integra, ls, mini, modify, obd, obd0, obd1, obd2, obdo, rewire, running, td, td42u, vtec
