check engine o2 sensor
from time to time my check engine light comes on then goes off. Checked the code and its for the o2 sensor upstream. Whats the location of this? I see 2 on the cat. Is it one of those 2? Do I need a special tool to remove it or just a deep socket? Got 70k on my ride do I need to replace or clean it?
Re: check engine o2 sensor (johnclaunch)
Thanks for the info. Never changed o2 before. No mods down there yet at all. Everything stock except for a stiffy. Engine light is off at the moment. I Lost the paper that I wrote the code on last time I stopped at the auto shop . It said o2 upstream was bad.
i had this same problem with my ep3. i was just driving to work and the check engine light came on. i scanned it and it was a p1166 and a p1167. its just the o2 sensor. how much do they go for and it is easy to install one?
Re: (johnclaunch)
I've got a 1166/1167 following a clutch install.
Others have suggested a wire got pulled out from the sensor. I've looked, and pushed wires in, everything looks ok, but still get the codes.
Is replacing the O2 sensor a "guaranteed" fix? Is is possible a wire was pulled between the O2 connector and the ECU? I think that would be almost impossible to "push back in".
Surje.motorsports
Re: (pcorad)
Re: (pcorad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pcorad »</TD></TR><TR><TD CLASS="quote">I've got a 1166/1167 following a clutch install.
Is replacing the O2 sensor a "guaranteed" fix? Is is possible a wire was pulled between the O2 connector and the ECU? I think that would be almost impossible to "push back in".</TD></TR></TABLE>
Have you cleared the code to see if it comes back or will it not clear at all?
wootcivic
11-29-2004 10:01 AM
