why is my car overheating when it was fine this morning all of a sudden?!
Old 08-28-2008, 01:00 PM
nickle80's Avatar
Default why is my car overheating when it was fine this morning all of a sudden?!
car just started overheating. gotta new radiator and thermostat put in not too long ago. don't know what seems to be the prob but can someone give any kind of suggestions? i have a budget and cant pay too much to fix this car. please help!!!!
Old 08-28-2008, 01:21 PM
LatinEM2's Avatar
You might have air in your cooling system so bleed it.
Old 08-28-2008, 01:50 PM
nickle80's Avatar
Default Re: (LatinEM2)
thanks foe a response but how do you do that and what does that mean? sorry not much knowledge about cars.
Old 08-28-2008, 02:04 PM
nsrkeeper's Avatar
Default Re: (nickle80)
you know how you flush your radiator, it has that plastic valve at the bottom, just bleed it. (open it up and let the air come out then close it quick) . this should work if not maybe latinEM2 might have a better answer.
Old 08-28-2008, 02:25 PM
Sanji
toyomatt84's Avatar
Default Re: (nsrkeeper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsrkeeper &raquo;</TD></TR><TR><TD CLASS="quote">you know how you flush your radiator, it has that plastic valve at the bottom, just bleed it. (open it up and let the air come out then close it quick) . this should work if not maybe latinEM2 might have a better answer. </TD></TR></TABLE>
Opening that plastic valve won't release any air at all. Air doesn't submerge in coolant, it rises to the upper most portion of the coolant level. That's why when you burp a coolant system, you usually leave the filler cap to the radiator off.
Old 08-28-2008, 02:28 PM
nsrkeeper's Avatar
Default Re: (toyomatt84)
hey matt would you then explain how to do the bleed correctly. i would appreciated thanx.
Old 08-28-2008, 02:36 PM
Sanji
toyomatt84's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsrkeeper &raquo;</TD></TR><TR><TD CLASS="quote">hey matt would you then explain how to do the bleed correctly. i would appreciated thanx. </TD></TR></TABLE>
https://honda-tech.com/zerothread/2370896
Or you could just use this well written tutorial:
http://www.civicforums.com/for....html
scoobyghost
03-28-2007 05:18 PM
cilvia
15
02-16-2007 09:47 AM
-Championship-
11-26-2006 07:14 PM
drift2004
08-03-2005 10:17 PM
DFW
10
01-22-2005 05:04 PM
Quick Reply: why is my car overheating when it was fine this morning all of a sudden?!
