toyota help needed, 95 previa, egr insufficient flow wont go away,
Old 08-15-2008, 06:14 AM
97grnrs's Avatar
Default toyota help needed, 95 previa, egr insufficient flow wont go away,
i got this car at work been back many times, 95 previa supercharged, so far ive replaced the entire egr system except the vacuum switching valve which i tested to alldata spec and it seems to work fine. replaced the egr itself, vacuum solenoid, temp sensor and blew air through the tubes that go into the motor, the light stays out for a day and comes back on , i did vacuum tests while car is running and the egr is functionin if i apply vacuum the idle will die down so it has to be working, but the insufficient flow code keeps coming back, po401 or somehting, next step is the ecu but its alot and if it comes back after that im screwed,, anyone have any idea???
Old 08-15-2008, 06:50 AM
pornfreaktommie's Avatar
Default Re: toyota help needed, 95 previa, egr insufficient flow wont go away, (97grnrs)
PO401 : Insufficient EGR Flow
The Exhaust Gas Re circulation (EGR) system is designed to reintroduce exhaust gas into the combustion chambers, thereby lowering combustion temperatures and reducing the formation of Oxides of Nitrogen (NOx).
The amount of exhaust gas that is reintroduced into the combustion cycle is determined by several factors, such as: engine speed, engine vacuum, exhaust system back pressure, coolant temperature, throttle position. All EGR valves are vacuum operated. The EGR vacuum diagram for your particular vehicle is displayed on the Vehicle Emission Control Information (VECI) label.
The EGR system is Differential Pressure Feedback EGR (DPFE) system, controlled by the Powertrain Control Module (PCM) and composed of the following components: DPFE sensor (also referred to as the back pressure transducer), EGR Vacuum Regulator (EVR) solenoid, EGR valve, and assorted hoses. The P0401 code means that OBD detected an insufficient amount of EGR.
Symptoms
There may be drive-ability issues such as pinging ( pre-ignition knock , similar to cheap gas) when the vehicles engine is under heavy load or the vehicle is climbing a steep grade. There may also be other symptoms.
Causes
A code P0401 most likely means one or more of the following has happened:
The DPF (differential pressure) sensor is faulty and needs to be replaced
There is a blockage in the EGR (most likely carbon buildup)
The EGR valve is faulty
The EGR valve may not be opening due to a lack of vacuum
Possible Solutions
In fixing this code, it is quite common for people to just replace the EGR valve only to have the OBD code return. The EGR valve is not always the cause. If you replace all 3 components the like is all but guaranteed to go away . Or you can test each component .
Use a vacuum pump and pull the EGR valve open while monitoring engine RPM's. There should be a noticeable difference in RPM's with the EGR open
Clean out the EGR valve to remove deposits
Replace the DPF sensor
Replace the EGR valve
COMPONENT TESTING
DPFE Sensor
Disconnect the pressure hoses at the DPFE sensor.
Connect a hand vacuum pump to the downstream pickup marked REF on the sensor.
Using a multi meter, back probe the SIG RTN circuit at the DPFE connector.
With the ignition ON, signal voltage should be 0.20–0.70 volts.
Apply 8–9 in. Hg of vacuum to the sensor. Voltage should be greater than 4 volts.
Quickly release the vacuum from the sensor. Voltage should drop to less than 1 volt in 3 seconds.
If the sensor does not respond as specified, check the power and ground circuits.
If power and ground circuits are functional, the sensor is faulty.
EGR Valve Control Solenoid
Remove the EVR solenoid.
Attempt to lightly blow air into the EVR solenoid.
If air blows through the solenoid, replace the solenoid with a new one.
If air does not pass freely through the solenoid, continue with the test.
Apply battery voltage (approximately 12 volts) and a ground to the EVR solenoid electrical terminals. Attempt to lightly blow air, once again, through the solenoid.
If air does not pass through the solenoid, replace the solenoid with a new one.
If air does not flow through the solenoid, the solenoid is OK.
If the solenoid is functional but the problem still exists, check the power and ground circuits.
EGR Valve
Install a tachometer on the engine, following the manufacturer's instructions.
Detach the engine wiring harness connector from the Idle Air Control (IAC) solenoid.
Disconnect and plug the vacuum supply hose from the EGR valve.
Start the engine, then apply the parking brake, block the rear wheels and position the transmission in Neutral.
Observe and note the idle speed.
NOTE: If the engine will not idle with the IAC solenoid disconnected, provide an air bypass to the engine by slightly opening the throttle plate or by creating an intake vacuum leak. Do not allow the idle speed to exceed typical idle rpm.
Using a hand-held vacuum pump, slowly apply 5–10 in. Hg (17–34 kPa) of vacuum to the EGR valve nipple.
1. If the idle speed drops more than 100 rpm with the vacuum applied and returns to normal after the vacuum is removed, the EGR valve is OK.
2. If the idle speed does not drop more than 100 rpm with the vacuum applied and return to normal after the vacuum is removed, inspect the EGR valve for a blockage; clean it if a blockage is found. Replace the EGR valve if no blockage is found, or if cleaning the valve does not remedy the malfunction.
Old 08-15-2008, 07:31 AM
97grnrs's Avatar
Default Re: toyota help needed, 95 previa, egr insufficient flow wont go away, (pornfreaktommie)
tried all that and everything was replaced, the idle does drop when i apply vac to egr,, im wondering if the ecu aint sending the signal to the egr vacuum switch or the wire maybe broken?
Old 08-15-2008, 07:02 PM
stumpyf4's Avatar
Back probe the VSV and make sure you are getting power to the VSV. It's duty cycle controlled so you may want to put a bulb on it and make sure the bulb is flashing when it's purging. If it's on solid or doesn't come on at all you'll have to trace the wire... first check at the ECU then trace the wire harness.
Old 08-16-2008, 09:21 AM
97grnrs's Avatar
Default Re: toyota help needed, 95 previa, egr insufficient flow wont go away, (stumpyf4)
thats prob what ill do to test it. prob is i cant actuate it with the scanner ill have to wait till it normally supposed to open.. and being that the motor is under the van its gonna be hard to do..
Old 08-17-2008, 03:16 AM
stumpyf4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97grnrs &raquo;</TD></TR><TR><TD CLASS="quote">thats prob what ill do to test it. prob is i cant actuate it with the scanner ill have to wait till it normally supposed to open.. and being that the motor is under the van its gonna be hard to do.. </TD></TR></TABLE>
There are a few way to "skin a cat", unplug the VSV and install a bulb with some long wires. Run the wires into the cabin... roadtest and check it.
lordbobb
18
01-09-2010 10:52 AM
monsterb18b
17
09-14-2009 10:55 AM
JJexpress
12-22-2008 03:55 PM
Philbert
07-10-2004 05:44 PM
kingrobby
01-11-2004 03:07 PM
Quick Reply: toyota help needed, 95 previa, egr insufficient flow wont go away,
