flush transmission fluid - can I use non-honda ATF
Old 08-10-2008, 05:59 AM
jfernandez1977's Avatar
Default flush transmission fluid - can I use non-honda ATF
HI,
I'm thinking of flushing the transmission fluid on my honda accord 2000. The manual says that I should use Honda premium Formula Automatic Transmission Fluid (preferred) or DEXRON III ATF (temporary replacement).
I can get ATF from our hardware shop, but it is not Honda premium Formula. Does it matter if I added non-Honda Premium Formula ATF to my car? Thanks for any advice.
JF
Old 08-10-2008, 09:18 AM
He knows where you live!
TheMuffinMan's Avatar
You will notice a difference between the two.
I would go with Honda ATF personally it's not pricey
Old 08-10-2008, 12:41 PM
YeuEmMaiMai's Avatar
using nond ahonda atf = crappy shift quality
Old 08-10-2008, 12:47 PM
guymontag's Avatar
Default Re: flush transmission fluid - can I use non-honda ATF (jfernandez1977)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jfernandez1977 &raquo;</TD></TR><TR><TD CLASS="quote">HI,
JF</TD></TR></TABLE>
If you're going to go with the standard advice and drain/fill/run x3 then you could use generic ATF for the flush process so long as you refill with genuine honda ATF at the end. Remember that each drain/fill cycle only replaces about 50% of the fluid in the transmission, so if you drain and add dexron you have 50% of the old, dirty fluid left and 50% fresh dexron. If you were to do another drain/fill cycle with honda fluid you're at 25% old, dirty fluid and 75% fresh fluid. 25% of the total fluid at this point will be dexron. Make sense? If not, then I'd just use Honda fluid. There is definitely a difference. You can leave behind a little generic dexron in the transmission, but it should mostly be Honda.
Old 08-11-2008, 05:42 AM
Default Re: flush transmission fluid - can I use non-honda ATF (guymontag)
Thanks for all the reply.
I have a couple of other questions,
1) if I need to do drain/refill 3 times, what is the time interval between them? Couple of weeks?
2) how much should I put each time? 2 liters?
thanks.
JF
mcgradiator
08-07-2008 09:06 PM
sharpescalade
06-02-2007 07:37 AM
chardwick
11-04-2006 07:15 AM
Thanks knightsport!
06-08-2005 09:54 AM
playAho
04-02-2003 07:28 PM
Quick Reply: flush transmission fluid - can I use non-honda ATF
