Go Back   Honda-Tech > Honda and Acura Technical Forums > Forced Induction
Old 08-05-2008, 01:08 PM   #1
suckerpunch
suckerpunch's Avatar
Default PLX wideband incorrect readings
I think my plx m300 is not operating correctly.
When I first bought the unit from a HT sponsor, if I would shut my car off, the gauge would go from 14.7 ish up to 20 ish then read "lean" then read "air"
Lately, the gauge when the car is shut off or under decel, it won't read higher then 18.59. Even with the car completeley shut off for 3 minutes after running it won't read leaner then 18.59
is there a way to calibrate this thing? I thought it was self calibrating but unfortuneately I can't find my instructions at the moment so I thought I would ask.
Oh yea wanted to add that the gauge and sensor are about 1.5 years old or so if that and maybe 8k miles or so. Its being used on a turbo car with nitrous from time to time and 100 octane unleaded from time to time.
thanks
suckerpunch is offline   Reply With Quote
Old 08-05-2008, 01:11 PM   #2
GetawayInMoscow
Send a message via AIM to GetawayInMoscow
Default Re: PLX wideband incorrect readings (suckerpunch)
Do you run race gas a lot? If so I'm sure the sensor took a ****.
Just go get a sensor for a VW 1.8T, should be like $80
GetawayInMoscow is offline   Reply With Quote
Old 08-05-2008, 01:45 PM   #3
suckerpunch
Default Re: PLX wideband incorrect readings (GetawayInMoscow)
Maybe and I mean maybe once a month but that was at the beginning. if I do know its not even a full tank like maybe 3-5 gallons on average. Even so its unleaded. I can't see 100 unleaded messing up the sensor.
So you agree it sounds like a bad sensor?
Old 08-05-2008, 01:49 PM   #4
GetawayInMoscow
Yes I have seen that happen with PLX units when a sensor goes bad.
Old 08-05-2008, 01:53 PM   #5
suckerpunch
ok cool. REason I am asking is because the gauge will read low 12's under boost and then it rises up to high 12's and 13's yet the car still runs perfect, no breaking up or detonation and plugs look fine.
Now I might still be having fuel delivery problems but I want to make sure my gauge is reading correctly before I start replacing a fuel pump or injectors or what not.
Old 08-05-2008, 02:09 PM   #6
champLSinteg
champLSinteg's Avatar
Send a message via AIM to champLSinteg
http://www.amazon.com/gp/product/B000BZI4ZW
thats where I got mine.
My PLX started doing the same thing. Under boost it would not go lower than 12.6 and no leaner than 18. after a week it was mid 13's under boost and it would not go any higher than 16.
425whp@15psi - t3/t4 60 trim 3in exhaust 91oct. 474whp@20psi open downpipe 112oct.
11.5@128mph with a 1.99 60ft
DNR Performance : Six Sigma Racing
champLSinteg is offline   Reply With Quote
Old 08-06-2008, 06:15 PM   #7
suckerpunch
Default Re: PLX wideband incorrect readings (champLSinteg)
awesome thanks for posting that link. Much cheaper then any other place I have seen it.
From what I am reading it appears mine has the same problems as some others here. I am hoping it was the sensor the whole time and not a fuel system problem.
Old 08-06-2008, 06:54 PM   #8
base-op.1320
base-op.1320's Avatar
It's says 3 used and new starting at $50 - don't buy a used sensor - and my sensor after one year wouldn't go richer than 12's either, new sensor and it works perfect
2008 - 96 civic hatch ls/vtec stock sleeves - 11.2@126mph
E85 Live green - go on the last yellow
base-op.1320 is offline   Reply With Quote
Old 08-06-2008, 11:14 PM   #9
champLSinteg
Default Re: PLX wideband incorrect readings (base-op.1320)
Amazon.com does not sell used sensors! $50.98 is the lowest and Amazon is selling them.
Old 08-07-2008, 02:19 AM   #10
ralph11sec
ralph11sec's Avatar
i changed three times already in the past 2 years Click the image to open in full size. and we had the same readings bro. its a bad sensor. Click the image to open in full size. i got mine from plx, it was 79 i think.
i run on ebay chip
ralph11sec is offline   Reply With Quote
Old 08-07-2008, 05:54 AM   #11
glagola1
glagola1's Avatar
How close are you guys running the sensor to the turbo? In the instructions, it says you should mount it at least 24" away from the head/turbo as temps of 1500F can kill it.
glagola1 is offline   Reply With Quote
Old 08-07-2008, 09:18 AM   #12
agturbo
agturbo's Avatar
Alexei-Guinitaran hondoctors
Send a message via AIM to agturbo
have you checked your wiring such as your grounds & 12 volt power - ive had some similiar problems and cleaned up the wiring and it worked fine, assuming your sensor is good
(http://www.hondoctors.com)(www.serviontuning.com)
9.59@152.45 -1995 Integra -Race Car
9.87@145.66 -1992 Civic Hatch -Street Car
agturbo is offline   Reply With Quote
Old 08-07-2008, 10:05 AM   #13
PHDZINE
PHDZINE's Avatar
Default Re: (agturbo)
How to check a wideband sensors accuracy....
-Pull Wideband sensor out
-Blow into the sensor...it should register maximum (Lean)
-Get a lighter...light lighter up and blow flame out
-Point the lighter at the sensor and let the sensor smell the butane...it should register full minimum (rich).
If you do this procedure and it reads anywhere in between minimum and maximum, the sensor is bad or going bad.
9.71 @158.03 MPH and 9.63 @159.01 MPH
Injen Technology-Camp1320-Drive Shaft-ShopCompetition Clutch -CompTurbo
PHDZINE is offline   Reply With Quote
Old 08-07-2008, 06:23 PM   #14
JDMCRX
JDMCRX's Avatar
iTrader Rating: (2)
Send a message via ICQ to JDMCRX
Default Re: (PHDZINE)
Nice.
Yeah mine started doing the same switched the O2 and its fine now
1999 Acura 1.6EL turbo D16Y8 300whp 2002 Suzuki Grand Vitara with H27 1995 Honda Civic SI Build thred http://honda-tech.com/showthread.php?t=23987711994 Honda Accord Wagon Build thread http://honda-tech.com/showthread.php...9#post36883659
JDMCRX is offline   Reply With Quote
Old 08-08-2008, 02:05 PM   #15
suckerpunch
Default Re: (JDMCRX)
I am unsure of the eact distance as there are a few turns in my downpipe, but the wideband is mounted a fair distance away from the turbo. I do remember reading not to mount it too close as it could burn it up so I was as carefull as I could. Its probably close to 2 feet though.
I will also check my grounds for the unit too. New unit is ordered should be here by wed or thur so we shall see what happens.
thanks for the help guys. Glad to see I am not the only one this has happened to.
Old 08-08-2008, 02:17 PM   #16
SovXietday
SovXietday's Avatar
Send a message via AIM to SovXietday
Default Re: (suckerpunch)
Sensors go bad periodically, nothing you can really do about it. If your car seems to be killing sensors quickly I'd look into something else though.
Originally Posted by wantboost View Post
New guy came in thinking he was hot ****
Denied
SovXietday is offline   Reply With Quote
Old 08-08-2008, 02:32 PM   #17
base-op.1320
Default Re: (glagola1)
If my exhaust was 24" long I would Click the image to open in full size.
Old 08-08-2008, 08:08 PM   #18
KeyserSoze
KeyserSoze's Avatar
Send a message via AIM to KeyserSoze
Default Re: (base-op.1320)
LOL, ownt!! Actually not really. I think you may be a bit mixed up......
24" = 24 inches
24' = 24 feet
Well, unless you mean your exhaust is < 2ft........ Click the image to open in full size.
Originally Posted by VtecbOi
why need vtec when you have turbo. the whole point of turbo is to not run vtec. why have vtec when you can run vtec all the time. which in term no vtec. why would you wanna run the low lope and then the high lope. just run high all the time. unless you wanna save gas then that's another story... plus you won't have to worry about the switch over point, specialy when you have the turbo.
Vouches:xtremecivichb,dfoxengr,SHystrdyGSRtdy,a132 0addict,BodyKits NW
doublej http://images.honda-tech.com/set1/smile/emsmile.gif
RIP Earl
KeyserSoze is offline   Reply With Quote
Old 08-08-2008, 08:17 PM   #19
KeyserSoze
KeyserSoze's Avatar
Default Re: (KeyserSoze)
Seriously though, I really wonder how accurate that 24" rule is as there are a LOT of turbo people who have the wideband bung much closer than that and have not had problems.
I'll have to try the lighter trick mentioned earlier just to see..........
RIP Earl
accuracy, amazpn, downpipe, gas, gauge, high, life, m300, open, plx, race, reads, shutting, troubleshooting, wideband
