Old 08-02-2008, 05:58 AM   #1
moo32moo32
Send a message via AIM to moo32moo32
Default 93 ACCORD Fuel Pump Location
93 Honda Accord 4 Door Lx
I need to change Fuel Pump and have checked the Hayes Manual and it states that it is in gas tank. And that I need to remove the gas tank.
I have had people tell me that there is an access panel underneath the back seat. Is there anyone that knows if this is true?
moo32moo32 is offline   Reply With Quote
Old 08-02-2008, 08:00 AM   #2
Mr Yamada
Mr Yamada's Avatar
Default Re: 93 ACCORD Fuel Pump Location (moo32moo32)
The way to find out if you have to drop the tank, is to look for a round access panel behind the rear seat in the trunk floor.
I believe the fuel level sending unit is on the pssenger side and IF there is an access panel on the drivers side it will be for the fuel pump.
Diagnose, Diagnose, and PROVE IT.
Then and only then replace the part.
Mr Yamada is offline   Reply With Quote
Old 08-02-2008, 08:21 AM   #3
MenaceAccord92
MenaceAccord92's Avatar
Send a message via AIM to MenaceAccord92
You must drop the tank to change the fuel pump. There is an access panel, but not big enough to remove the fuel pump. To do that, you must cut/enlarge that hole.
MenaceAccord92 is offline   Reply With Quote
Old 08-02-2008, 09:06 AM   #4
moo32moo32
Default Re: 93 ACCORD Fuel Pump Location (MenaceAccord92)
Any idea what the access panel is for if the pump wont fit through it?
Old 08-02-2008, 07:50 PM   #5
JDM_DC4_Fanatic
1993 Honda Civic
JDM_DC4_Fanatic's Avatar
its so you can unplug the fuel pump and see if its getting power if it ever needs to be serviced.
1993 Milano Red Civic Coupe 5spd swapped
Port and polished Head + IM
9.6:1 CR Building Boost.
JDM_DC4_Fanatic is offline   Reply With Quote
Old 08-11-2008, 12:38 PM   #6
moo32moo32
Default Re: 93 ACCORD Fuel Pump Location (JDM_DC4_Fanatic)
Thanks to all for your comments. I believe I have a Main relay problem, hopefully it is not fuel pump.
1990, 93, access, accord, back, find, fuel, honda, located, location, panel, pump, removal, remove, replacement, seat
