> Honda CRX / EF Civic (1988-1991)
Old 07-30-2008, 11:15 AM   #1
jdmd15crx
jdmd15crx's Avatar
Send a message via AIM to jdmd15crx
Default OBD1 Trouble Codes
Just thought these might help somebody out bc ive seen alot of questions concerning them.
OBD1 Trouble Codes:
Code 0 and 11 Electronic Control Module (ECM)
Code1 Heated oxygen sensor A
Code 2 Oxygen content B
Code 3 and 5 Manifold Absolute Pressure
Code 4 Crank position sensor
Code 6 Engine coolant temperature
Code 7 Throttle position sensor
Code 8 Top dead center sensor
Code 9 No.1 cylinder position sensor
Code 10 Intake air temperature sensor
Code 12 Exhaust recirculation system
Code 13 Barometric pressure sensor
Code 14 Idle air control valve or bad ECM
Code 15 Ignition output signal
Code 16 Fuel Injector
Code 17 Vehicle speed sensor
Code 19 A/T lock-up control solenoid
Code 20 Electric load detector
Code 21 V-TEC control solenoid
Code 22 V-TEC pressure solenoid
Code 23 Knock sensor
Code 30 A/T FI signal A
Code 30 A/T FI signal B
Code 41 Heated oxygen sensor heater
Code 43 Fuel supply system
Code 45 Fuel supply metering
Code 48 Heated oxygen sensor
Code 61 Front heated oxygen sensor
Code 63 Rear heated oxygen sensor
Code 65 Rear heated oxygen sensor heater
Code 67 Catalytic converter system
Code 70 Automatic transaxle
Code 71 Misfire detected cylinder 1
Code 72 Misfire detected cylinder 2
Code 73 Misfire detected cylinder 3
Code 74 Misfire detected cylinder 4
Code 75 Misfire detected cylinder 5
Code 76 Misfire detected cylinder 6
Code 80 Exhaust recirculation system
Code 86 Coolant temperature
Code 92 Evaporative emission control system
jdmd15crx
(__/)
(o.O )
(> < ) This is Bunny. Copy Bunny into your signature to help him on his way to world domination!
jdmd15crx is offline   Reply With Quote
Old 02-20-2012, 04:27 PM   #2
SiTR
SiTR's Avatar
Default Re: OBD1 Trouble Codes
Ecu codes
SiTR is offline   Reply With Quote
Old 03-11-2012, 06:53 AM   #3
Muhammad Tallal
i have honda Civic 2002. if we remove the batery terminal for some time and then put it back on the engine check light goes off as it should but when we start the engine the light again come up after 5 seconds. i retrieved the codes. i am having code 30 and code 75&70 are the codes i am getting from engine check light diagnostics. and the code 30 i mentioned above is from the D light of my automatic light indicators, any one please help me resolving this issue. is there any oe who can help me please \
Regards,
Honda civic user.
Muhammad Tallal is offline   Reply With Quote
10, 21, 67, 90, 92, accord, check, code, codes, engine, honda, hondaobd1, obd, obd1, odb, trouble
