Go Back   Honda-Tech > Honda and Acura Technical Forums > Audio / Security / Video
Old 07-28-2008, 05:13 PM   #1
Taylor1321
Default Installed New Radio - Dash Lights Don't Work
Hi! I'm new to this and I just recently installed my pioneer deh 4800MP radio and i did cut the wires from the original radio and connected them to the pioneer. It works perfectly. I noticed the other night that my dash wasnt coming on. When i installed the radio i noticed that two wires, red and red/black, were'nt needed. I'm assuming that this is my problem?
Any help would be much appreciated
Thanks!
Taylor1321 is offline   Reply With Quote
Old 07-28-2008, 05:14 PM   #2
TheMuffinMan
He knows where you live!
TheMuffinMan's Avatar
iTrader Rating: (1)
Do your corner lights come on?
Small lights fuse, under hood.
Why did you not just buy the $10 adapter?
2004 NFR S2000
Originally Posted by slomofo
I think TheMuffinMan is Chuck Norris. Seriously, you can't find the TheMuffinMan,TheMuffinMan finds you.
TheMuffinMan is offline   Reply With Quote
Old 07-28-2008, 05:18 PM   #3
Taylor1321
all the lights on the inside work. they work during the day, it's just when i turn my head lights on they go off. and i wasnt aware of the $10 adapter, like i said i'm new to this.
Old 07-28-2008, 05:31 PM   #4
nissmoser
Default Re: (Taylor1321)
Did you cover the orange wires? If not and they shorted out, then it probably blew a fuse.
nissmoser is offline   Reply With Quote
Old 07-28-2008, 05:36 PM   #5
TheMuffinMan
iTrader Rating: (1)
corner lights, the exterior corner lights
2004 NFR S2000
Old 07-28-2008, 05:45 PM   #6
Taylor1321
it doesnt have oragne wires, but i did cover the extra wires. the only other wire that was left on my radio was the blue wire which is for the remote. and yes the exterior corner lights do work. maybe its a fuse under the hood?
Old 07-28-2008, 05:46 PM   #7
TheMuffinMan
iTrader Rating: (1)
It's not the small lights fuse if the corner lights work, you probably severed the dimming light circuit which controls the radio dimming and dash/etc
2004 NFR S2000
Old 07-28-2008, 05:50 PM   #8
Taylor1321
so what should i do? do i have to buy a whole thing or is there anyway to bypass it?
Old 07-28-2008, 06:01 PM   #9
TheMuffinMan
iTrader Rating: (1)
I don't know the circuit offhand.
Just look at the radio install guides (Accord FAQ) and see what those wires go to.
I'm going to wager it's part of the dimming circuit.
2004 NFR S2000
Old 07-28-2008, 06:24 PM   #10
Taylor1321
i think it has to do with the multiplexer? im not really sure what that means or how much they cost. and im also not sure about the dimmer circuit either.
Old 07-29-2008, 04:47 AM   #11
JDM_DC4_Fanatic
1993 Honda Civic
JDM_DC4_Fanatic's Avatar
have you tried something as simple as making sure the dimmer switch was plugged back in when you reinstalled the dash bezel? This more then likely has nothing to do with the radio, as the dash lights still work even with the radio unplugged. So, there are 3 things that happened. 1) you blew a fuse 2) you cut a wrong wire somewhere (not likly) and 3) you forgot to plug the dimmer switch back in.
Start with the basics. make sure everything is reconnected properly, then go back and make sure you didnt nick or cut any incorrect wires. The red/black wire from the radio harness is for the illumination of the RADIO only, not the whole dash, so it doesnt matter if its not connected. Plus, it serves no purpose on an after market deck as they do not come with dimmer control.
1993 Milano Red Civic Coupe 5spd swapped
Port and polished Head + IM
9.6:1 CR Building Boost.
JDM_DC4_Fanatic is offline   Reply With Quote
Old 07-29-2008, 10:03 PM   #12
bseriescrxsi
1995 Dodge Neon
My Garage
bseriescrxsi's Avatar
Send a message via AIM to bseriescrxsi
it would be orange coming off the adapter if you had gotten it i think its brown on the factory harness(not sure, consult a manual) but it wouldnt hurt to check the underhood fuses though like muffin said if your exterior corner lights work it cant be the small light
selling a bunch of parts for 90-93 accords and 96 accords in the FS thread...check it out
bseriescrxsi is offline   Reply With Quote
Old 07-30-2008, 05:18 AM   #13
fcm
Old Fart
fcm's Avatar
Default Re: Installed New Radio - Dash Lights Don't Work (Taylor1321)
MM&Y of car would help.
The unused red lead is dash light ground from "Dash Light Brightness Controller", the dash lights are dimmed by controlling the amount of ground they get.
The unused red/black is dash light power, [hot when park/head light switch is on].
Test for power on this lead with the head light switch on.
Both these leads need to be capped off if not used, as you say you have.
As already mentioned by JDM_DC4_Fanatic check the fuse for dash lights, make sure "Dash Light Brightness Controller", [dimmer control] is plugged in. Click the image to open in full size. 94
RIP Zack 2001-2013, my best friend.
fcm is offline   Reply With Quote
Old 07-30-2008, 11:00 AM   #14
Taylor1321
it's a 2000 accord lx
2000, 95, accord, dash, dodge, dont, extra, honda, installed, light, lights, mitsubishi, neon, radio, wires, work, zx2
