NEED HELP with obdII codes
ok.... my car is obd2 and it throws a check engine of 54 but i think thats for the obd1 cars and mine is obd2... can anyone tell me whats the code for obd2 and what it means.. thans.. by the way its a sohc vtec .. and stock ecu.. thanx
H-T White Ops
I might as well add this info to the thread for others.
These are both for '96-'00 Civics (these match to the MIL flash code of 54):
P1336
Detection Item: Crankshaft Speed Fluctuation Sensor Intermittent Interruption
Probable Causes: CKF sensor
P1337
Detection Item: Crankshaft Speed Fluctuation Sensor No Signal
Probable Causes: CKF sensor; CKF sensor circuit; ECM/PCM
P1336
P1337
Re: (darksolguy)
i see alot of the time for this code is that the crank sensor wire slips out of th e timing cover clip and rubs the alternator belt and ruins the wire. replace the crank sensor and your problem should be fixed.
Re: (abusedhusband)
i barely changed the sensor b4 i swapped in the motor.. but the plug from the engine harnes got cut and i lost the plug so i used a diff plug with diff colors and i didnt knoe what wire went where.. the colors are white brown and black in what order do they go... right now i have them white black brown
Re: NEED HELP with obdII codes (darksolguy)
cnydc2
07-23-2009 12:44 PM
civic, code, codes, crankshaft, darksolguy, fluctuation, honda, integra, intermittent, interruption, mil, obd2, obdi, obdii, p1336, sensor, trick
