| Welcome to Honda-Tech! | ||
#1 |
so my timing belt is pretty loose after replacing it, the water pump, and tensioner. there is almost and inch and an eight of deflection on the exhaust side. obviously that side will have the most slack cuz its the longest part without being on another pulley or whatever. i was reading the manual on how to adjust it, i just wanna make sure im understanding what they're saying. heres what it says
obviously take the vc off 1. set no.1 to TDC 2. roate the crankshaft 5-6 revolutions to set belt 3. then set no. 1 to tdc again 4. loosen adjustment bolt(tensioner) 1/2 turn 5. this is whre im slightly confused..it says rotate the crankshaft counterclockwise 3 teeth on the camshaft pulley. so im assuming i just rotate the crank til i count 3 teeth go by on one of the cams? 6. tighten bolt and done
DB SQUAD #26 Rides: 2005 toyota tacoma, 1996 acura integra gsr db8, 1985 shadow bobber, 2004 suzuki volusia |
#2 |
You're correct, as you turn the crank slightly the cams add tension to the belt since they're trying to pushing open some valves.
Since your belt has been running for a while I would just do steps 3-6. It's pretty obvious if you do it right, belt will be nice and tight. Suggestion, don't drive the car until you retension the belt.
Great Vendor Experiences: LSD Motorsports, Lightning Motorsport, Innes Performance Group, VS Racing. '... A bigger dyno # than the next guy doesn't mean you have a bigger dick.' Clean Rice |
#3 |
Sometimes this method doesnt work as it didnt work for me so I had to do the coat hanger technique.
Take a metal coat hanger and make one end into a fish hook. Loosen the tensioner and then hook it with the coat hanger and pull up on it till you get enough tension, then tighten it. |
#4 |
youre supposed to leave the tensioner bolt loose when you do the 5-6 rotations . Bring it back to tdc then tighten it then rotate it three teeth ccw, then you loosen it and youll see the slack tighten from the tensioner. then you tighten the tensioner bolt to 45 ft/lbs.
#5 | |
Quote from the manual for tensioning the belt (1998 Integra page 6-9) 1) Remove the cylinder head cover. 2) Set the No. 1 piston at TDC 3) Rotate the crankshaft five to six revolutions to set the belt. 4) Set the No. 1 piston at TDC 5) Loosen the adjusting bolt 1/2 turn (180deg) only. 6) Rotate the crankshaft counterclockwise 3-teeth on the camshaft pulley. 7) Tighten the adjusting bolt to the specified torque. 8) After adjusting, retorque the crankshaft pulley bolt to 177Nm.
#6 | |
yeah thats what i was thinking, i figured i'd wait to see what other people said first
#7 |
i meant have it tight. hands didnt write what brain meant.
#8 |
what way am i supposed to rotate the tensioner bolt to loosen it up? ive been trying for a long time to loosen up the belt to get in back onto the pulleys... but the more i do it the more the bolt gets rounded.
#9 |
common rule. "lefty loosely" "righty tighty".
f/s: turbo and misc stuff: http://hondamarketplace.com/showthread.php?t=2901115 |
#10 |
Hi!
When we turn the crank pulley 3 teeth on the cam pulley, the belt gets more tensioned or less tensioned? To understand better my question, imagine we would only loosen the adjuster bolt, and tightened it, the belt would be with more or with less tension that when rotating the cam 3 teeth?
http://ps10.homeip.net |
#11 |
Hi...
I have found the timming belt a quite loose. retightening as adivised in workshop manual created a grind sound in some of the pulleys... or water pump then i did the same rotating only one teeth and the wierd sound decreased to bare nothing. i mean... Retightening a belt that has 50k (km) on it... didnt work as expected so i had to draw back and now even though the belt when cold vibrated a little it works straight when normal temperature... i supose that this is water pump bearings going away... 160 k needing a new one can you give any advise about this? Thanks PS: boas skhell tudo bem? lol tuga do catano.
#12 | |
quando rodas a cambota... a correia estica de um lado.. e do outro o tensor acança para a posição normal e é fixo ai ao aparafusar a porca. mas isso é valido para correias novas apenas... n podes fazer os 3 dentes com uma correia usada. suponho.. pelo menos foi o que fiz é normal que haja algum barulho durante primeira semana. ate que ela estique um pouco para o tamanho e tensao normal. (english) hi... when you turn the crankshaft the belt stretches in one side while in the other the tensioner pulley advances reduces it slack and when you tighten the bolt, it stays in the proper position. thing is ------- that it is valid to new belts only.. old betls... cant do the 3 teeth must be less i guess... that what i did. it is natural that some noise pulley might be heardable in the first week or so a until it streaches a bit to normal state. |
#13 | |
ehehehWell, I always thought that the procedure of setting the right amount of tension would apply to a old belt, after all, timing belts are not supposed to stretch over the time... Any way, your experience with this is very helpfull, thank you so much, that thing of rotating it only one tooth is a good idea, the problem is if it got with less tension than it should...
#14 |
How do I get to the tensioner bolt? Do I have to remove the entire timing belt cover? My friends told me I could do it without removing all that but I can't figure out how.
PS: I have a 94' LS
94 4Runner-sold> 98 GSR-dead> 94 LS-sold> 97 GSR(K20A2)-sold> 02 S2000-current dd |
#15 | |
its been a while since i did this, but i believe there is a plug in the timing cover you can pop out and gain access to the bolt. just dont over loosen it or you might be screwed.
| Tags |
| 1985, 99, adjuster, adjustment, belt, f4i, integra, loosen, prelude, skip, teeth, tension, tighten, timing, tooth |
