Repost- While driving my Temperature gauge goes down then back up, help
Old 07-19-2002, 02:58 PM
CW-ITR-329's Avatar
Default Repost- While driving my Temperature gauge goes down then back up, help
As the topic says, when I'm driving the temp guage(stock) goes down then back. Also, the car seems to be running a little hot(through the fire wall). Anyone have any ideas on whats wrong? Thanks
Old 07-19-2002, 03:04 PM
I shoot brides
yoshi234's Avatar
Default Re: Repost- While driving my Temperature gauge goes down then back up, help (CW-ITR-329)
are you running stock thermostat?
rad cap not holding pressure?
air in cooling system?
Old 07-19-2002, 03:11 PM
CW-ITR-329's Avatar
Default Re: Repost- While driving my Temperature gauge goes down then back up, help (yoshi234)
1) Yes, I am running the stock thermostat.
2) I will check the radiator cap.
3) I just got done putting the head back on, and maybe air could have got in the radiator. How do I get the air out?
Thanks
Old 07-19-2002, 05:49 PM
CW-ITR-329's Avatar
PLease help
Old 07-19-2002, 08:18 PM
Tweakmeister's Avatar
did you bleed the cooling system a la Helms?
Old 07-19-2002, 08:19 PM
Dropspeed's Avatar
Default Re: Repost- While driving my Temperature gauge goes down then back up, help (Tweakmeister)
Old 07-19-2002, 09:22 PM
CW-ITR-329's Avatar
Default Re: Repost- While driving my Temperature gauge goes down then back up, help (Dropspeed)
With air in the system, will it hurt driving the car for a couple more days? I have to go somewhere early tommorrow morning. Let me know, Ryan
Old 07-20-2002, 03:27 PM
CW-ITR-329's Avatar
ttt
Old 07-20-2002, 03:50 PM
gsr98vtec's Avatar
whats your coolant level like, are you losing coolant. if so your head gasket is not sealing properly. i would think if the temp is not going all the way to hot and the car is not loosing coolant you could drive short distances, but not very far. i wouldnt try it if i were you, you could warp the head or th block from the heat then you are **** out of luck
Dm914
07-21-2017 07:40 AM
panchlow
05-02-2011 05:06 PM
smlanham
Acura TL, RL & ZDX
12-21-2010 08:39 AM
Toe_Knee
04-11-2009 11:55 AM
simplypinoyy
23
08-06-2004 03:06 PM
Quick Reply: Repost- While driving my Temperature gauge goes down then back up, help
