Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda Prelude
Old 07-09-2008, 12:33 PM   #1
HAZARD_1310
HAZARD_1310's Avatar
Default car shuts off after i accelerate
I got a 99' prelude, it started today first the would turn on cause of the battery was low so they gave me charge and turned on so I drove about 2 block and the car turned off, so then i got another battery drove back home when I reached a stop the cars idle was going way to low so i accelerated to keep the car from turning off......What can it be? When i turn the car on the idle stays steady like normal then if i accelerate it goes sraight down and off.........help thanks in advance Click the image to open in full size.
HAZARD_1310 is offline   Reply With Quote
Old 07-09-2008, 01:03 PM   #2
dagle
dagle's Avatar
iTrader Rating: (1)
Send a message via AIM to dagle
Default Re: car shuts off after i accelerate (HAZARD_1310)
alternator?
To Mislead and Misinform...
dagle is offline   Reply With Quote
Old 07-09-2008, 01:59 PM   #3
andrewdoessucks131
andrewdoessucks131's Avatar
what is the situation., its starts but you can drive a good distance my friend says it may be the fuel injectors or fuel pump, how long has it been sitting and what where the conditions
also check the fuel filter
andrewdoessucks131 is offline   Reply With Quote
Old 07-09-2008, 02:15 PM   #4
HAZARD_1310
Default Re: (andrewdoessucks131)
I dont think its the alternator because the car stays on even after diconnecting the battery and from what I know the car should turn off, if the alternator wasn't workin........
well it turns on and it idles normal and steady but as soon as u accelerate and let go the idle goes straight down and turns off instead of staying at 800-900rpm, so for it not to turn off u gatta keep accelerating.
it was just over night and the condition of the car is good...If it was the fuel pump , injectors or the fuel filter wouldn't u feel a lag or somethin when u accelerated? Click the image to open in full size.
Old 07-09-2008, 03:16 PM   #5
HAZARD_1310
Default Re: (HAZARD_1310)
help!! I need it for work...... Click the image to open in full size. Click the image to open in full size.
Old 07-09-2008, 04:13 PM   #6
h23siaws
h23siaws's Avatar
bad gas.....
fuel filter....
h23siaws is offline   Reply With Quote
Old 07-09-2008, 08:00 PM   #7
russlan44
russlan44's Avatar
Default Re: (h23siaws)
could be ignition switch cuz there was a recall on it. and if it starts shuting more and more often it could be it.
russlan44 is offline   Reply With Quote
Old 07-09-2008, 10:08 PM   #8
HAZARD_1310
Default Re: (russlan44)
I have been using the same type of gas I've been using since I got the car.... and if it was the filter wouln't I feel hesetation from the the engine under acceleration...
I've explained when does the car shuts off it doesn't do it unless I let it shut off i have to keep accelerating...any other ideas or advice..thanks
Old 07-09-2008, 11:10 PM   #9
TruNinja619
TruNinja619's Avatar
Send a message via AIM to TruNinja619
that recall is in regards to the engine still running even when you have the keys out of the ignition.
Try this: With the car warm'd up, disconnect the vacuum line that goes to the EGR valve, drive around, and see if it still stalls on you when you come to a stop. I just want to eliminate a possible stuck open EGR valve.
TruNinja619 is offline   Reply With Quote
Old 07-10-2008, 02:23 PM   #10
HAZARD_1310
Default Re: (TruNinja619)
I'll try that today..thanks....could it be the aicv?
Old 01-15-2010, 11:57 AM   #11
eghatchallday
yea man i kno wat you mean my car has the same problom it shuts off when i accelerate but my check engin light is showing because my car was rob and i ot it bak and i put bal all the moter parts dat was missing witch was scrwes belt and spark plug wire and i dont kno what it could be i need help too asap
eghatchallday is offline   Reply With Quote
Old 01-16-2010, 10:27 AM   #12
l.u.d.e.51
1994 Honda Prelude
try tightening the alternator pulley and maybe a new fuel filter
l.u.d.e.51 is offline   Reply With Quote
Old 03-22-2010, 08:00 AM   #13
aceltic15
TRIAL USER
i have the exact same problem that my car idles fine and warms up but as soon as its warm and i hit the gas the rpms go up and then down to 0 and dies. i have a 1994 honda accord lx and i just recently got thermostat changed and a couple other things and then started noticing this problem. When my car is cold or hasn't been driven in awhile it starts up fine and seems fine because its idling higher. I also had the iacv cleaned out while everything else was getting fixed. my mechanic seems to think thats its still something with the iacv. i have looked up tons of things online as well. i am not getting a cel and it seems like my hoses are fine. the one thing i did notice what when i disconnected the hose from my head that goes to the intake manifold the car doesn't shut off when warm. But then i took it on a 2 hour drive and it started to shut off again. The iacv seems like the most probable but it could also be in the throttle body or the throttle position sensor. there were things also saying that it could be the egr valve. its not the alternator and doubtful that it would be the fuel filter because i had all my filters changed out.
aceltic15 is offline   Reply With Quote
Old 05-09-2012, 05:27 AM   #14
Angela King
I have a 95 honda accord lx and it shut off this morning. It will start up and then cut off again. My oil light and battery light came on. Do anybody know what could be wrong with it??
Angela King is offline   Reply With Quote
Old 05-09-2012, 09:49 PM   #15
holmesnmanny
We need a lot more information than that. The oil light and battery light will come on if the car dies. When those lights come on when the car is running is when you need to worry. If the oil light ever comes on when you're driving you need to immediately pull over and park as if you have low oil it can be a matter of seconds before the engine is destroyed.
91 Accord w/ H22A swap: Newest update on CARB cert...... Passed smog at the REF...Offically CARB certified !!!
holmesnmanny is offline   Reply With Quote
Old 05-10-2012, 06:30 PM   #16
preludeNApower
preludeNApower's Avatar
my car will sometimes have the same conditions in hot conditions, seems to stall out on me when i shift to neutral. I adjusted the idle and it has so far solved the problem... however no really hot days since adjustment. I actually removed the idle adjusting screw completely and idle is only at 800rpm
preludeNApower is offline   Reply With Quote
Old 05-10-2012, 08:02 PM   #17
typemismatch
Honda owns me
typemismatch's Avatar
TPS sensor?
1992 Prelude S - 469hp/340tq@15psi - 12.46@117mph
2007 Civic Si - FG2 - almost stock (DD)
92 EG H2B - build thread http://www.honda-tech.com/showthread.php?t=2944704
typemismatch is offline   Reply With Quote
Old 05-10-2012, 10:24 PM   #18
holmesnmanny
I don't think you actually removed the idle adjusting screw cause if you back it off too much even without taking it off it will cause a huge vacuum leak and the idle will bounce. You must be referring to something else.
Old 05-14-2012, 01:22 PM   #19
preludeNApower
Negative ghost rider, removed adjusting screw (flat head brass lookin screw top left of tb next to vacuum ports) no vacuum leak idle around 800.
Old 11-18-2012, 01:55 AM   #20
erka
1999 honda torneo... same problem help help help when i accelerate it just shakes little bit and turns off.......
erka is offline   Reply With Quote
Old 11-23-2012, 07:55 PM   #21
Tszyu1
[quote=TruNinja619;34589214]
Not entirely true. My 97 SH was shutting off intermittently while driving; replaced the ignition switch when it became more frequent. Problem solved. Also, Honda America said that it had already been replaced under recall. I am the second owner. And I bought it in 2000, before the recall was issued. I know that switch was never replaced. I have all repair receipts, and I have used the same independent mechanic since 2002.
What is concerning to me is this. Even if I am totally wrong about the switch being replaced, Honda seems willing to perform a safety recall only once...
1997 Nordic Mist Type SH*Injen 2pc. CAI*Mugen header*Thermal R&D exhaust*Euro-R blue valve cover*JR plug wires*ACT streetlite flywheel/Stg 1 clutch*Neuspeed front STB *Black leather interior*Valentine 1*El Cheapo Mugen-style front bumper*JDM fogs*Seibon hood*
Tszyu1 is offline   Reply With Quote
1994, accelerate, accelerating, be, car, civic, completely, dies, honda, off, shuts, shutting, truck, turn, turns
