#1 | |||||
[ARC Magic][Bride][Mugen][Spoon][Koni/Eibach][Hasport][Earls] Build Up - Full Tuck/B20-V/Paint/Restore/Buy Stuff Thread |
#2 |
So I'll start with pics of the bay from day 1:
Car was brought into it's new home for the next little while, and will start getting stripped: ![]() ![]() The bay: ![]() ![]() ![]() Some pretty bad rust all over the bay that will be deleted soon (the car has spent most of it's life in Manitoba, Canada...what do you expect?): ![]() ![]() ![]() ![]() ![]() The hood latch lever actually broke off, so I'll have to be getting a new one: ![]() ![]() ![]() ![]() ![]() Overall 'horrible' condition of the bay and it's surroundings: ![]() ![]() Removed the intake air chamber box: ![]() ![]() Battery tray was simply rotten (had a leaky battery when I first got the car): ![]() ![]() Pulled out the washer fluid resevoir, need to get it modified (shortened) to make it seem invisable in the bay ![]() ![]() Cruise will stay, but won't be seen...here is a before:
#3 |
Also, here are the pics of the motor which I picked up off a friend who decided to upgrade to a C5 rather than play with the whole B20/Vtec conversion:
![]() My GF and my buddy had to make a pose ![]() ![]() Brought the motor back in my old beater...the toyota matrix ![]() ![]() The overall condition of this motor was excellent, and it had very low low mileage: ![]() ![]() ![]() So I grabbed a bunch of parts for the swap: ![]() ![]() So I decided to paint the motor "battleship grey" at the time, and it turned out sorta like this: ![]() ![]() ![]() ![]() ![]() (will post more updates tomorrow when I get home from work)
#4 |
Great build!
I dunno what to say about these "Domani" conversions though. I dont hate em and I dont like em, they just look wierd in a good way. It looks fresh with those ITR's though! |
#5 |
good luck mayne
| MissShift | FS: EG nose mask http://hondamarketplace.com/showthre...6#post38796416 |
#6 | |
Sweet Title
european whippin' it |
#7 |
Very nice man you better get that car done.One of our cars has to get done this summer
JDOGG IS THE WORST JDOGG IS THE WORST DONT GO TO HIM infinitwheels.com OG EM1 CREW |
#8 | |||
It's actually an Acura EL, like sixfiveoh said. I am from Canada, and we sell them here. I actually own two ![]() I've been down to the states once and I had a lot of people at gas stations ask my why I have accord parts on my civic ![]() Thanks for the compliment, the ITR's are daily/beater rims. Car is getting a set of MF10's in white. Quote:
#9 |
Ok, so I got my photobucket working again...
Ok, so here is how my bay looked like before I cleaned it. Note: this was after I sprayed it with degreaser :S ![]() Leaking batteries suck ![]() ![]() ![]() ![]() ![]() Rust under the brackets: ![]() ![]() This is how the car looked after cleaning the entire bay with a green scrub pad and Comet Bleach: ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Note: All the A/C lines were still in the car because at this point, I was thinking of running A/C...
#10 |
Placed an Order with ANPluming.com and Summit.com and wirecare.com to get these goodies:
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() And here is a quick sketch of the brake system: ![]() Basically, the shopping list consists of: -Remote Battery Terminals -Clutch line, fuel line and brake lines in stainless steel hard and soft line. I will be running a mild steel line inside the cabin as well for the OEM fittings, but will run stainless all around the cabin Also, that sketch got a bit altered. I decided to run a 98-01 spec ITR 1", so the banjo won't be necessary as I did have a 94-97 GSR 1" MC before. Turns out these can't fit an EK chassis, and barely clears with a banjo.
#11 |
SO I had the A/C professionally contained and I had the lines removed. I cleaned the engine bay this time with Mineral spirits and a cloth, and after the bleach, it turned out like this:
![]() ![]() Getting more and more stripped each day... ![]() ![]() I had the two holes drilled out on the firewall for the inlet/outlet brake line holes for the MC here: ![]() inside: ![]() Gutted the inside further, taking out the dash so it would be easier to run all the lines: ![]() ![]() ![]() ![]() ![]() Few patches that were a bit uneven and that still need further sanding, nothing a little wire wheel can't fix :![]() ![]() ![]() These studs have to go: ![]() ![]() Going to have to replace the bolts and tow hooks eventually as well: ![]()
#12 |
good progress! in for more!
If you drive a green/tan DC4 with a license plate something along that lines of 3---614 that was originally from San Francisco,CA, please contact me because I may have your original window sticker in hand. |
#13 | |
Man that bay was in a state! GL.
EK sedan from NZ |
#14 |
Did you figure out the catch can situation and great progress on the car
#15 |
Cant wait to see this car at IA. |
#16 |
Hell yeah buddy, you got your hands full!!!!!!!!!!!!!!!!!!!!!! See THIS and YOU at IA
Mugen mf8s,ek9 cluster,takata 5pt harness for sale. pm me for details Function>Form flickr Dont shop at zerolift in cini OHIO ![]()
#17 |
Nice goin Arthur, those still my old mirrors?
99 1.6 El |
#18 |
hope to see this at IA!
vouches~ patrickdc4130, botlebruiser, jdmscg, RMXmitch, Speed Kills, AllMotaEF9, Brok dck, slammed civic si,gaseb, pornstarcivic, JERKSiRcoupe, manoy, RARE_EG2, 88civic, gene, Teawins21, b16rex_02, Chain Driven, kabaroo, DxHatchback |
#19 |
build is looking good
#20 | ||||||||
I'll be updating this thread so far daily...as I have a lot of pics. Each pic is like 3 megs each, and I have to downsize so it's taking me a while. I'm actually done painting the bay, will be painting the subframe tomorrow. We also got 90% of the motor put together, just waiting on some parts to come in. Harness should be done by this weekend as well for it
![]() Quote:
I gotta work quick tho...there is still a lot left to do. Quote:
#21 |
OK, another update as promised!!!
So a few weeks ago, I was in a delema...The flaring tool that my buddy had could not flare any of my SS lines. He flared and flared till he was blue in the face, and it just didn't happen. He was certain I needed to go with mild steel lines. I did some research and asked some guys in the Tucked/Engine Bay thread, and everyone seemed to recommend the Ridgid flare tool. So I grabbed one off toolup.com. Cost me $100 plus shipping and taxes...so it came out to around $214 or so since shipping was close to $90 (yeah, sucks living in canada for that alone) The day I got it: ![]() ![]() ![]() ![]() Needless to say, it worked...and dayum did it put a smile on my buddies face. He went nuts and started flaring up a bunch of lines for the fun of it. Not only does this tool produce perfect flares with nearly any metal, but just like a torque wrench, it stops once the flare is perfect, and clicks and pops up. I love it. ![]() ![]() ![]() ![]() ![]() Positioning the master cylinder and Brake booster, I realized that the line will directly hit the shock tower...So I sold it and got a 98-01 ITR, which looks like the stock EK, but it's a 1" ![]() The first line that was made: ![]() Looks soooo sexy. And the stainless steel will never rust Oh, and the stock rubber lines and fittings will go. Earls all the way Prepped the firewall for a light shave: ![]() and here is me and my trusty angle grinder that I got for xmas from my gf's sister ![]() ![]() ![]() ![]() I got a bit too excited: ![]() Seeing how much fun it was, my buddy had to try it as well: ![]() ![]() ![]() I ended up shaving every stud that was used for brake lines, or the OEM proportioning valve mounts since the new 4040 DA proportioning valve will now be sitting somewhere around my cup holder. ![]() ![]() ![]() I forgot to take pics, but I took some glaze and lightly filled the holes and imperfections. I also filled in those two bolt holes for the bracket that held the clutch line. Also shaved the studs that held the clutch line. I know glaze is not recommended in the engine bay since it cracks, but I'm only using it on the firewall and there is very very little flex in that area, so I feel pretty confident about it not cracking. Modified by Fresh'86 at 4:46 PM 7/9/2008
#22 |
Sweet Title
Nice dude, working quick!
#23 |
A few notes:
The brake lines and fuel lines were all thanks to Chase. I would like to thank him for all the help he's given me over IM, including the advice on getting the Ridgid. I find people take his help for granted, it's not everyday a business owner comes in and shares his ideas and gives out the ideas he has that can make him money. I would also like to thank Easy_E. The guy has come a long way in helping my build my car, and for all the small querks that bugged me, he threw in some great advice. Not only that, but I found his thread to be very inspirational and kept me on the anal side when building my car Like him, I want everything to look and run perfect.And thanks a lot to all the guys in the tucked/shaved/custom bay theory/discussion thread. I've learned a lot there, and taken a lot of the ideas I have for my car. I find it pointless taking all the credit to myself, because if it wasn't for these guys. I'd probably just have stuck to a B18B swap and a turbo and not even touched the bay.
#24 |
Props! proyect coming along pretty good! good tools , good parts, great proyect... keep us updated...!!
Btw love the tons of pics!!
hybrids ftw PL510 datsun with a F20c1 guts |
#25 |
Alright, so I'll try and keep this up to date as best as I can...
I got an LSD ITR tranny a few months ago: ![]() ![]() ![]() ![]() ![]() And not until two weeks ago did I start cleaning it. I decided to keep it OEMish, so me and my buddy sanded off all the nasty junk off it: ![]() ![]() Pic of my buddy working: ![]() A lot of people like the shiney new look, a lot of people hate it. We'll see how it looks once it's all together I guess. I had that battleship grey paint chip as it sat over winter int he garage on the motor. I figured if it chips from extreme temperatures, it's bound to crack from driving. So I'll keep it just shiney/bare for now. Did an upgrade on the clutch/flywheel as well. Went with the 7.5lb Fidanza Fly wheel (I believe OEM is 12/13lbs?). Either way, it looks so friggen awesome: ![]() ![]() ![]() Stage 1 Gravy Competition Clutch. I was highly advised to stay away from the Exedy, due to many many warranty issues. I stuck with a Stage 1 as it's good for 270whp: ![]() ![]() ![]() ![]() ![]() And lastly, a few months ago I picked up a Ported and Polished head that was also decked, and had the dowels machined for a LS/B20-Vtec swap off a friend who decided to buy a bike instead of building a car: ![]() ![]() The head came in pretty good condition since it was at the machine shop and has never been installed. I decided it needed more work anyway So I cleaned it up with a wirewheel and drill:Cam Gears before: ![]() After/Before: ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Took apart the VTEC solenoid, and preparing to polish it, and clean up: ![]() ![]() Half way done, here are more head shots: ![]() ![]() ![]()
| Bookmarks |
| Tags |
| 90, anpluming, battery, battleship, cabin, civic, da, firewall, grey, honda, leaking, paint, proportioning, remote, terminals, valve |
