#1 | ||||||
1994 Honda Accord Coupe |
#2 |
H-T Order of Merit
Nice write-up
just a few things... - Do not use a torque wrench to loosen bolts. It can mess up the calibration of the torque wrench. Use a breaker bar or a ratchet with a pipe on it. - As an option to putting oil in the cam areas and that, I use Torco Engine Assembly Lube. General used for assembly of new parts so oil is fine in this situation for an engine and cam that isn't brand new, but I just like to be 100% sure no damage will happen in that first start-up. - I didn't see you mention it though I'm sure you did it, so probably more of a note to others... Be sure to reset your timing and belt tension after put the head and cam/rocker assembly back in. If need be, see my timing belt write-up on how to do this. And I have added this to the FAQ |
#3 |
Good write-up! Did you run into any issues disconnecting the water pipe from the thermostat housing? Do you really have to worry about nicking the head while you are scraping the old gasket off? Are you still gonna have to remove the lower timing cover so you can re-tension the timing and balancer belts? Where do you get the ss clutch line?
Modified by Bird333 at 1:37 PM 7/3/2008 |
#4 | ||||
-Good to know about the torque wrench, I will edit that now. -I only use assembly lube when new too. On my 120,000k motor mobil 1 has yet to let me down. I have never had any issues. -This was kinda my way of getting out of typing up the timing portion last night. I will post more regarding assembly and the timing portion this evening. Quote:
-Never have I had any issues disconnecting waterpipe. -Yes you have to be very meticulous when scraping ANY gasket not to nick the surface. Otherwise you wont get a good seal. - No removing the lower timing cover is not required. I will elaborate on that portion later this evening. However, if you havent done the necessary maint in the timing area, now is the time to do any and everything ! you can refer to the link above (for now) regarding timing. - SS clutch line, any local hydraulic shop can make it for you. Modified by NeKe1point0 at 3:36 PM 7/3/2008
#5 |
DUDE! You have a freaking DeLorean! AWESOME!!!!
94 Accord LX 99 Civic HX |
#6 | ||
YEP ! 19,000 original miles !! ... its for sale ! In process now of taking pics for timing, powersteering, and drive belts.
#7 |
1995 Honda AccordJoin Date: Jun 2007
man what an awesome write up, I think you just wanted to show off your turbo
and DELOREAN! SO NICE. I DON'T KNOW IF YOU EVER LISTEN TO KANYE BUT'GOOD MORNIAN/ LOOK AT THE VALEDICTORIAN/ SCARED OF THE FUTURE/ WHILE I HOP IN A DELOREAN' PEACE |
| Bookmarks |
| Tags |
| accord, belt, cover, engine, f22b2, gasket, guide, head, hondatech, tension, tighten, timing, torque, valve, water |
