I can push the brake pedal to the floor??
Old 06-17-2008, 02:06 PM
roller3804's Avatar
Default I can push the brake pedal to the floor??
I have seen some streaks of what I believe to be brake fluid on my rims after driving sometime. I looked around the master cylinder to check for leaks and it did not seem like it was leaking.
If I sit in the car I can push the pedal real hard and it will slowly go down really far. I think its because of the calipers leaking.
Anyone have any ideas? I don't think its the master cylinder cause its not leaking.
Old 06-17-2008, 02:25 PM
89pre2.0si's Avatar
Default Re: I can push the brake pedal to the floor?? (roller3804)
Is it having alot of trouble stopping?
From the brake experience I've had it sounds like your in the right direction
Old 06-17-2008, 02:27 PM
codeh22a4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roller3804 &raquo;</TD></TR><TR><TD CLASS="quote">I have seen some streaks of what I believe to be brake fluid on my rims after driving sometime. I looked around the master cylinder to check for leaks and it did not seem like it was leaking.
Anyone have any ideas? I don't think its the master cylinder cause its not leaking.</TD></TR></TABLE>
my 95 sr-v does the same thing plus i have d ABS light on.
Old 06-17-2008, 03:08 PM
roller3804's Avatar
Default Re: I can push the brake pedal to the floor?? (89pre2.0si)
It doesn't stop to bad. But when coming to a stop if I press hard into the pedal it sinks down and doesnt grab much harder. Its almost scary but rarely to bad.
ONE BIG THING I FORGOT TO MENTION IN THE ORIGINAL POST WAS : my fluid reservoir has to be filled up every two days or so depending on how much I drive cause of wherever its leaking from.
Old 06-17-2008, 03:34 PM
vinuneuro's Avatar
The seals in one of your calipers might be bad. Rebuild or get a remanufactured pair.
Old 06-18-2008, 04:56 AM
roller3804's Avatar
anyone else have any ideas?
Old 06-18-2008, 05:00 AM
busyychild's Avatar
have a buddy pump the brakes while you take a look at each individual caliper/brake master cylinder. take off the wheels to make it easier. look for leaking brake fluid. once you have found the culprit, replace it then bleed the system.
its always good to replace things in pairs. so if its a caliper, replace the opposite side as well (unless they are relatively new).
Old 06-18-2008, 09:38 AM
roller3804's Avatar
Yeah that was my next step. I can put on my new front rotors and hawk pads to !
Old 06-18-2008, 02:57 PM
something gnarly
5SpdH22's Avatar
Default Re: (roller3804)
It could be the two copper washers that go on either side of the brake line on each caliper. This would also let air into the system, making your pedal mushy.
Old 06-19-2008, 05:41 AM
prelude_h22vtec's Avatar
its most likely the calipers if you're seeing fluid.
one of the front hoses failed on me too last year. so check that out. the rubber can get all dry rotted after 10-15 years.
Old 06-19-2008, 09:19 AM
roller3804's Avatar
Default Re: (5SpdH22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5SpdH22 &raquo;</TD></TR><TR><TD CLASS="quote">It could be the two copper washers that go on either side of the brake line on each caliper. This would also let air into the system, making your pedal mushy.</TD></TR></TABLE>
oh yeah thats a good call. Ill check that out. Thanks man
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelude_h22vtec &raquo;</TD></TR><TR><TD CLASS="quote">its most likely the calipers if you're seeing fluid.
one of the front hoses failed on me too last year. so check that out. the rubber can get all dry rotted after 10-15 years. </TD></TR></TABLE>
yeah the entire brake system is 14 years old I guess except for the master cylinder. I am sure its about time for a rebuild loL!
Old 06-25-2008, 06:20 PM
95JDMprelude's Avatar
if u dont find a fluid leak anywhere near the calipers then u may have a bad seal int he brake booster and the vacuum hooked to the booster is pulling the fluid into the engine and its just burning it
93b20z
10-18-2008 11:56 AM
msinsky14
05-21-2007 07:31 PM
s10cky
17
12-20-2006 07:19 PM
ILcrxsi1
05-28-2006 01:27 PM
spender1326
04-06-2004 03:28 PM
Quick Reply: I can push the brake pedal to the floor??
