> Welding/Fabrication
Old 06-16-2008, 04:29 PM   #1
david@didrace.com
david@didrace.com's Avatar
Send a message via AIM to david@didrace.com
Default How to Make a Stripper Pole
If any of the pictures don't load, hit 'Refresh' on your browser. Our web server sucks ass.
So we were having a group of 25 or so local Corvette club owners come by the shop last Saturday for an open house. We had them by last year and already dyno'd most of their cars so we had to think of some sort of entertainment. It took us about 10 seconds to decide that we needed strippers, lots of them.
Step one -
Order an inordinate amount of strippers to come to the shop. Done.
Step two -
Design stripper pole. From the weekend before while doing my preemptive research up at a couple strip clubs in Wisconsin I noted that having a polished metallic pole is a must. It also must be sturdy and hold up to 125lbs flinging around on it with over 1G over force at times.
So I hopped onto McMaster.Com to find the items I needed. Searching the term 'stainless tube' I came up with the pole material that I needed. 2" OD High Polish Type 304L Stainless Steel Tubing w/ a 1.87" ID leaving a .065" wall, six feet long for $87.68. I also ordered up a 3' length of the same material as the pole was to be roughly 8.5' tall.
I already had 1 7/8" 16ga 304 Stainless Steel tube for some exhaust I recently made.
All I needed was a base and top. Searching 'stainless fitting' I found #45605K656 which would be perfect to slip the ends of the 2" OD stainless into. McMaster Carr has a place within 20 miles of me so I called the next morning and picked up the materials from will-call. Total of roughly $185.
Here's the sketch of the bases -
I press fit a 5" length of the 1 7/8" OD tube halfway into the 2" OD 3' long tube and welded the two together. I then pressed the 6' length of 2" OD tube over the 2.5" of the 1 7/8" tube that was sticking out of the 3' section and fully welded the tubes together and made sure to have enough weld to grind down to a smooth surface with no low spots.
I then cut the 9' section to length and welded 6"x6" plates onto the bases. Drilled four 1/2" holes on each plate 1" away from each corner. Took out the hammer drill and drilled holes for the concrete anchor studs. I slipped the top and bottom plates onto the pole and slipped the assembly into position and bolted down the base plate. We then leveled the pole and attached the upper plate into the ceiling with lag bolts.
Here's the results, sorry some of the pictures are blurry... too many Monster Energy Drinks -
We needed a rug so we bought this sweet ass one the day of the event. $130 but so worth it.
And one of the 7, yes seven strippers we had there on Saturday. This girl took a Makita like a champ.
David @ DIDRace.Com
Modified by david@didrace.com at 6:38 PM 6/16/2008
Originally Posted by NYLuder
The roach was real and the vacuum is real. I have hoover vacuum from bby.
- 1996 Honda Civic Ex - B20, SC60 @ 20psi, Tuned on E85
david@didrace.com is offline Report Post   Reply With Quote
Old 06-16-2008, 04:40 PM   #2
snowseeker
snowseeker's Avatar
Default Re: How to Make a Stripper Pole (david@didrace.com)
Most poles have bearings at the top and bottom for spin action.
I'm a crx kind of guy.
snowseeker is offline Report Post   Reply With Quote
Old 06-16-2008, 04:49 PM   #3
JRSC01GS-R
2001 Acura Integra
My Garage
JRSC01GS-R's Avatar
Send a message via AIM to JRSC01GS-R
Default Re: How to Make a Stripper Pole (snowseeker)
sounds like a good time indeed
01 GSR Coupe rip
01 ITR 10.97@133.9
450hp @20lbs on 91
JRSC01GS-R is offline Report Post   Reply With Quote
Old 06-16-2008, 04:56 PM   #4
JDMCRX
JDMCRX's Avatar
Send a message via ICQ to JDMCRX
Default Re: How to Make a Stripper Pole (JRSC01GS-R)
Lol nice take it like a champ girl
1999 Acura 1.6EL turbo D16Y8 300whp 2002 Suzuki Grand Vitara with H27 1995 Honda Civic SI Build thred http://honda-tech.com/showthread.php?t=23987711994 Honda Accord Wagon Build thread http://honda-tech.com/showthread.php...9#post36883659
JDMCRX is offline Report Post   Reply With Quote
Old 06-16-2008, 05:10 PM   #5
SD_Lurker
HT White Ops
SD_Lurker's Avatar
Send a message via AIM to SD_Lurker
SD_Lurker is offline Report Post   Reply With Quote
Old 06-16-2008, 05:16 PM   #6
david@didrace.com
Default Re: How to Make a Stripper Pole (SD_Lurker)
Didn't have any complaints.
Old 06-16-2008, 05:23 PM   #7
weiRtech
weiRtech's Avatar
fewer pictures of the pole, and more of strippers.
my RWD CRX2000 build thread
weiRtech is offline Report Post   Reply With Quote
Old 06-16-2008, 05:58 PM   #8
Dazed and Confused
Dazed and Confused's Avatar
"Design stripper pole. From the weekend before while doing my preemptive research up at a couple strip clubs in Wisconsin I noted that having a polished metallic pole is a must. It also must be sturdy and hold up to 125lbs flinging around on it with over 1G over force at times."
Hilarious. I never thought I would see someone design and engineer a stripper pole on HT. I thought there would be more pics of the ladies tho
Dazed and Confused is offline Report Post   Reply With Quote
Old 06-16-2008, 06:14 PM   #9
bigsyke
bigsyke's Avatar
I had 3 in my old house, Ex wife was a stripper. I saw this I thought it was raining, but really it was my eyes watering.
Security > Form
Keep your car
"Official bring NOFX back #02
If yOu AiNt, TaLkIn BoUt MoNeY
YoU AiTt TaLkIn BoUt ShIt http://is.rely.net/1-92-30008-l-au16...EFX98SjN8A.gif
bigsyke is offline Report Post   Reply With Quote
Old 06-16-2008, 06:51 PM   #10
dave@passenger
If you clean the scale off of the mild steel it will weld real nice and not toast your gas lense.
Where are the stripper pics?
dave@passenger is offline Report Post   Reply With Quote
Old 06-16-2008, 07:08 PM   #11
integraturbo96
integraturbo96's Avatar
nice, I like that
integraturbo96 is offline Report Post   Reply With Quote
Old 06-16-2008, 08:26 PM   #12
88ED8
88ED8's Avatar
Send a message via AIM to 88ED8 Send a message via MSN to 88ED8
Default Re: (bigsyke)
Any pics?
FS: MINT condition RC 750cc Injectors (saturated) $220 shipped http://hondamarketplace.com/showthread.php?t=2673240
88ED8 is online now Report Post   Reply With Quote
Old 06-16-2008, 08:41 PM   #13
9295EJ-t
9295EJ-t's Avatar
should have left the tube unwelded.. that way the girls can spin easier... lol
there is a strip club near by, it has a spinning joint.. pretty fun watchin naked chicks spin around poles really fast!
Welder/Fabricator @ MaseEngineering
www.maseengineering.com
9295EJ-t is offline Report Post   Reply With Quote
Old 06-16-2008, 10:38 PM   #14
Finest
Finest's Avatar
No pics of stripper ON the pole? You're no good to me.
BTW, which clubs up here did you visit?
Finest is offline Report Post   Reply With Quote
Old 06-16-2008, 11:15 PM   #15
bigsyke
bigsyke's Avatar
Default Re: (88ED8)
Originally Posted by 88ED8
Any pics?
A ton. litterally 2000lbs+ of pictures. Iv been an enthusiast since 21. Then the sweet baby Jesus showed me the light
I wish I had some pics of my fireman pole I did. She wanted a 2 story setup like they have at deja vu. It was cool untill we had to sell the house. Best GF I've ever had. So much fun
Security > Form
Keep your car
Old 06-17-2008, 12:05 AM   #16
BbqEazyE
BbqEazyE's Avatar
haha that is probably the best post ive seen ina while. Nice pole man Thats also a pretty nice setup w/ the garage!!!
BbqEazyE is offline Report Post   Reply With Quote
Old 06-17-2008, 06:09 AM   #17
littlemissy
littlemissy's Avatar
Location: Far away, A.. LA/VA/DC/MD sometimes FL sometimes.. up your butt
Default Re: (BbqEazyE)
You're saying that I didn't have to spend $350 bucks to get my mynx pole?! (although, mines removable)
Very nice thread. Love the pole you've made, are you planning on keeping it up? haha
I.. Look like a woman, Think like a man, Act like a lady & Work like a dog
WTB: Racing Hart 3 piece C2 18' 5x114 w/ all dishes + caps PLEASE PM ME!
littlemissy is offline Report Post   Reply With Quote
Old 06-17-2008, 07:58 AM   #18
Top Ramen
Top Ramen's Avatar
Default Re: (littlemissy)
That's the stripper's responsibility. . . .
"Until I see a lawsuit, I just don't see how I have a customer service problem" - Javier Gutierrez (JG Engine Dynamics) .
Top Ramen is offline Report Post   Reply With Quote
Old 06-17-2008, 08:01 AM   #19
ROTARY
ROTARY's Avatar
Default Re: (Top Ramen)
^ lol
ROTARY is offline Report Post   Reply With Quote
Old 06-17-2008, 08:02 AM   #20
b20turbojason
b20turbojason's Avatar
Send a message via AIM to b20turbojason
Very nice work. Perhaps any pics of the pole in use.
[b]EK SQUAD[b]
TEAM IKON
b20turbojason is offline Report Post   Reply With Quote
Old 06-17-2008, 08:17 AM   #21
Kusai.Nihonjin.Desu
Kusai.Nihonjin.Desu's Avatar
Send a message via ICQ to Kusai.Nihonjin.Desu Send a message via AIM to Kusai.Nihonjin.Desu
If you can come up with a design where we don't have to tear up holes in the ceiling or the floor, I will buy it.
Kusai.Nihonjin.Desu is offline Report Post   Reply With Quote
Old 06-17-2008, 09:03 AM   #22
david@didrace.com
Default Re: How to Make a Stripper Pole (b20turbojason)
Probably NSFW but no nudity - http://www.didrace.com/gallery...9.jpg
The rest of the girls didn't want their pictures taken, little did they know we have 15 high resolution security cameras.
Old 06-17-2008, 09:22 AM   #23
snootworks
snootworks's Avatar
AWESOME! I've been grumbling about setting up a clandestine peeler operation at our shop for ages!
Hopefully your initiative in making it happen will be just the encouragement I need to get the rest of the gang on board. "Well OTHER shops are doing it now, so WTF?!"
Hehehe.
snootworks is offline Report Post   Reply With Quote
Old 06-17-2008, 07:32 PM   #24
2fast4u831
I'm really 2slow
1994 Honda Civic
2fast4u831's Avatar
Send a message via AIM to 2fast4u831
Default Re: How to Make a Stripper Pole (snootworks)
This thread is full of WIN!!
HAHAHA. fo sho!!
H2B squad member #09 my project
think fast, neukin , Turbogixxer , DVS
2fast4u831 is offline Report Post   Reply With Quote
Old 06-17-2008, 08:57 PM   #25
alpha
alpha's Avatar
Send a message via AIM to alpha
David. I have to ask. Do you have any job openings
Nice work, lol
alpha is offline Report Post   Reply With Quote
Bookmarks
build, girls, light, make, making, nude, nudity, nudityst, photo, photography, pole, poles, setup, strip, stripper
