what gas should i put in my car?
Old 06-14-2008, 06:12 PM
lrcrx90's Avatar
Default what gas should i put in my car?
i just purcahsed a 2004 accord lx and was wondering what was the recomended gas for this car 87 89 or 93. i've gotten a bunch of answers and i need a straight one
Old 06-14-2008, 06:54 PM
msedacca's Avatar
Default Re: what gas should i put in my car? (lrcrx90)
I'm guessing 4cyl by the LX, so you don't need anything more than 87. Anything more is a waste of money. You can run 93 and you might see a slight hp gain and slight improved MPG, but outside of that, no real perks.
Old 06-15-2008, 08:40 AM
Cogent Argument Enthusiast
Uncle Ben's's Avatar
Default Re: what gas should i put in my car? (msedacca)
Even the v6 doesn't require anything more than 87. Apparently, if you use premium in the v6, the computer will mess with timing and give an additional 10 hp.
Old 06-15-2008, 03:01 PM
bmxrider945's Avatar
87 all the way, its cheaper
Old 06-16-2008, 01:20 AM
ch0baca's Avatar
Default Re: what gas should i put in my car? (Uncle Ben's)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Uncle Ben’s &raquo;</TD></TR><TR><TD CLASS="quote">Even the v6 doesn't require anything more than 87. Apparently, if you use premium in the v6, the computer will mess with timing and give an additional 10 hp. </TD></TR></TABLE>
BS! r u kidding me??!
Old 06-17-2008, 04:01 PM
msedacca's Avatar
Default Re: what gas should i put in my car? (ch0baca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ch0baca &raquo;</TD></TR><TR><TD CLASS="quote">
BS! r u kidding me??!</TD></TR></TABLE>
Nope not at all, that is not the first time I've heard that. I've never seen concrete data to back it up, but apparently thats what Honda says.
Old 06-17-2008, 06:29 PM
JDM_Acccord's Avatar
100 octane race fuel.
Old 06-17-2008, 08:06 PM
interstate's Avatar
Honda Accords were made to perform optimally on 87 octane gas.
Old 07-10-2008, 11:46 AM
onlyforLIT's Avatar
Default Re: what gas should i put in my car? (interstate)
I've got an 03 EX V6 6-speed Navi coupe.....and I SWEAR it runs faster/better on 91 oct vs 87.....(in CA there is no 93).......
Old 07-11-2008, 08:06 AM
vtec_head's Avatar
Default Re: what gas should i put in my car? (onlyforLIT)
Like the others are saying stick with the lower grade 87 you'll be just fine! Even if the myth is correct about a additional 10hp by using Supreme gas you won't really notice it much and it may even lower your MPG. Then you'll be just kicking yourself!
Old 07-14-2008, 10:12 AM
Frankv6coupe's Avatar
Well I tried 89 octance last year and the car slowed down. My mph in quarter mile dropped. I went back the week later with regular (87) octane and my mph went back up to normal. By the way I drive 2004 accord ex v6 coupe automatic.
Old 07-16-2008, 12:06 PM
vdavenp802's Avatar
Use whatever level your manual suggests, any more and it is a waste. Because, octane is used to control pre-detonation. Knock. That's all. Nothing to do with the amount of horsepower it will generate. Gas is gas at that point. Horsepower is made via compression ratio, which then dictates octane level to contro, pre-detonation.
Any brand will be fine. If you have problems with your gas its the station, not the brand. It all comes out of the same hole it the greound(storage tanks).
All the gains people report are very subjective, since they typically compare two different points in time, when other factors that affect performance are not controlled and not the same. (i.e. ambient temp, tire pressure, barometric pressue, etc., etc.)
Go by the manual, you can't go wrong.
SIXPAK GQ
07-19-2007 04:55 PM
Jxi8s2k
02-03-2006 10:34 PM
spoonef
06-25-2005 06:13 AM
Donniebrosco
11-15-2004 07:35 PM
4DRmafia
09-14-2004 05:14 PM
Quick Reply: what gas should i put in my car?
