> Honda Prelude
Old 05-22-2008, 10:05 AM   #1
Jagan'92
Jagan'92's Avatar
Default Replacing the connecting pipe (thermostat to water pump)
I smelled a coolant leak, and saw a drip per second coming from the water pump area. I was hoping it was the o-ring on the end of the connecting pipe, but it turned out to be the connecting pipe itself.
the end had rusted away and the oring was actually jammed into the water pump impeller. parts cost about 40$ or so, until I broke the 100$ knock sensor when reinstalling.
This can be done from underneath, remove the oil filter and oil cooler for easier access. Cut off the hoses connected to the pipe to make things easier, pull the pipe out from the thermostat area, then clamp the new hoses onto the pipe before feeding the pipe back under the car. remove the oil pressure and kock sensors if you're smart (unlike me).
replacing part nos. 13, 22, 23
take off intake, thermostat, to expose one end of the pipe.
unbolt the pipe and cut off heater hose and oil cooler hose if replacing them(makes it easier to pull, might as well replace all hoses)
pull the connecting pipe out of the water pump
o-ring in the pump:
old pipe vs. new pipe
don't break a 100$ sensor while installing a 40$ part.
Modified by Jagan'92 at 2:50 PM 5/22/2008
The world is indeed comic, but the joke is on mankind
Jagan'92 is offline   Reply With Quote
Old 07-11-2008, 08:52 AM   #2
93preludeh22
93preludeh22's Avatar
Default Re: Replacing the connecting pipe (Jagan'92)
Thanks!
92 Civic CX # 05 Accord 4Dr EX-L 5Spd # 06 Ridgeline RTL # 95 Civic CX JDM h22 (sold) # 02 S2000 (sold) # 02 CR-V EX 5Spd (sold) # 92 Civic HB CX JDM h22 (sold) # 93 Prelude Si JDM h22 (sold) # 04 Civic Si (sold) # 92 Civic 4dr DX (sold)
93preludeh22 is offline   Reply With Quote
Old 06-29-2009, 04:45 PM   #3
cyoung450
Default Re: Replacing the connecting pipe (thermostat to water pump)
Where can I get these parts I am having the same problem on my 87 Accord, and the pipe is all rusted out like yours. I can't find them anywhere. Please help.
Thanks,
cyoung450 is offline   Reply With Quote
Old 06-30-2009, 04:01 AM   #4
PirateMcFred
PirateMcFred's Avatar
Nice write up. Thanks.
Tired of the same ol' BS? Some place better: LINK
Contact me if you have a Rotrex supercharger for sale.
PirateMcFred is offline   Reply With Quote
Old 06-30-2009, 09:13 AM   #5
95greenlude
95greenlude's Avatar
Send a message via AIM to 95greenlude
knock sensors are not $100....any OBD 1 knock will work. you can find them used from $40-60 all day
Jared -'99 Jeep Cherokee Sport
SOLD - 95 Prelude SE
95greenlude is offline   Reply With Quote
Old 06-30-2009, 12:19 PM   #6
DCFIVER
DCFIVER's Avatar
DCFIVER
Thats not rust thats acid. Hence the need for regular coolant flushes with the proper mixture and coolant.
Originally Posted by DfwBB6 View Post
Quote, originally posted by AcidcrakkerThe crow bar wasnt my idea.It was some Mexicans. He was telling me he went to Mechanic school in Mexico.Well after about doing the crow bar for about 10 mins, I figured hes full of ****.
DCFIVER is offline   Reply With Quote
Old 07-21-2009, 03:19 PM   #7
rucap
Hi, Where can I find this water pipe for my accord SEi from 89?
Thank you.
rucap is offline   Reply With Quote
Old 08-14-2009, 01:05 PM   #8
jscortez
hi i was reading your answer on replacing the connecting pipe from the thermostat to water pump. i am currently doing this on a 92 accord and attempting to install my new connecting pipe but am having trouble keep the o rings in place( they keep falling of into the water pump) and am also un able to to remove the the hose that runs from the fire wall to the connecting pipe. any help is greatly appreciated
thanks jim
jscortez is offline   Reply With Quote
Old 10-06-2009, 03:03 PM   #9
freakasis
freakasis's Avatar
anyone know how to put these things back in to the waterpump?
freakasis is offline   Reply With Quote
Old 10-07-2009, 09:53 AM   #10
Apex1972
o-ring in the pump:
the pipe is only 40.00?
BB Squad V.2 #139 http://honda-tech.com/showthread.php?t=2564201
"The Driver's Education teacher some years ago said it was perfectly legal to accelerate as fast as possible on an onramp to merge into traffic! "
Apex1972 is offline   Reply With Quote
Old 10-08-2009, 07:16 AM   #11
freakasis
freakasis's Avatar
yeah. do you know how its held into the waterpump? is it just jammed in there and bolted down?
Old 10-08-2009, 08:23 AM   #12
mafia
mafia's Avatar
Yeah you wiggle it in there, If the motor is off its easy if motor is on have fun.
00-PY ITR
99 GSR 4 door
99 SI
mafia is offline   Reply With Quote
Old 10-08-2009, 03:24 PM   #13
95greenlude
There is a 10mm bolt a couple of inches down the water pipe that holds it in place, but as ^ said, its basically jammed in there...
Old 02-16-2010, 05:49 AM   #14
ELeMeNTs153
ELeMeNTs153's Avatar
BTW, great post man! Anyway, i need to know where you bought that water pipe cuz i cant find it anywhere for some reason. I been searching everywhere online. A part # would help if you still have it?
ELeMeNTs153 is offline   Reply With Quote
Old 05-05-2010, 12:47 PM   #15
thebeast
There is a 10mm bolt a couple of inches down the water pipe that holds it in place, but as ^ said, its basically jammed in there...[/quote]
I could not reach that bolt so I wiggled the pipe back and forth until the bracket broke off. I only pulled the pipe out far enough to replace the o-ring on the water pump side. Only disconnected the heater hose.
Since I don't want to ever get back in the area, before I put on the new o-rings I smeared some RTV sealant on the pipe, then put on the o-rings. Before jamming the pipe on the water pump side I also added a ring of the RTV in the housing then slid the pipe until it stopped. The sealant oozed out perfectly.
On the other end I also smeared some RTV on the thermostat housing. The pipe is wedged between the water pump and the thermostat once everything is in place so that bracket is not needed. Cooling system has been operating flawlessly since. 92 Honda Accord.
thebeast is offline   Reply With Quote
Old 12-04-2010, 10:34 PM   #16
114724554
Hi, eveyone. I break the thermostat housing case when I tried to lock up the bleeder... So i have to install a new thermostat housing case for my h22a. (Anyone knows the part # for h22a?) My main question is how to disconnet and reinstall the water pipe to the thermostat housing? I didnt see any clamps there. Just simply push it out and jammed it back by hands?
114724554 is offline   Reply With Quote
Old 12-05-2010, 08:03 AM   #17
ShoofIsLudin
ShoofIsLudin's Avatar
Send a message via AIM to ShoofIsLudin
i'm pretty sure all the h22 water pipes are the same. And yes it just goes into the thermostat housing. Work/wiggle it into place. Just make sure you have it in far enough.
ShoofIsLudin is offline   Reply With Quote
Old 12-05-2010, 08:39 AM   #18
minilogoguy18
minilogoguy18's Avatar
There is 1 bolt though near the center, but other than that it is just held in by being pressed between the thermostat housing and water pump.
93 BB2 - JDM H22a/T2W4 Euro R transmission
Originally Posted by PirateMcFred View Post
Everyone's ****'s broken and they can't find a Helm Manual to read.
minilogoguy18 is offline   Reply With Quote
Old 12-05-2010, 08:57 PM   #19
114724554
Thanks all.
Old 01-20-2011, 08:56 PM   #20
hifonics
hifonics's Avatar
Send a message via AIM to hifonics
Is it some what the same thing to change the water pipe on a d series?
hifonics is offline   Reply With Quote
Old 01-21-2011, 08:52 AM   #21
nus_dogg
1994 Honda Accord
nus_dogg's Avatar
Similar.
1994 Honda Accord EX - JDM H22A
- 204whp/157wtq
Originally Posted by toycar View Post
Breaking the bank, maybe. Feeling like a boss, likely.
nus_dogg is offline   Reply With Quote
Old 01-21-2011, 02:19 PM   #22
hifonics
hifonics's Avatar
I just did mine right now,hardest part is pulling the pipe out but i had to cut the hose that connects to the pipe on the thermostat side.Does anyone know what that hose is called so i can go pick one up?
Old 01-19-2012, 10:23 PM   #23
GeoPrelude
Hey i need your help please! im desperate to find the water pipe to my 97 honda prelude! i cant find it absolutely anywhere! nobody has it! some places dont even know what i am talking about! its the pipe that connects the water pump and the thermostat housing. i have a leak from there and it makes my car overheat after a while. i found the spot where its leaking from and i showed my auto tech teacher and it is from the pipe. so can you please help me and tell me where i can get the pipe at? i really need it! and soon! please ill appreciate it a lot!thanks!
GeoPrelude is offline   Reply With Quote
Old 01-20-2012, 04:18 AM   #24
BergRacing21
1992 Honda Prelude
BergRacing21's Avatar
Bryan Bergesen bryberg19 bberg21
Honda Dealership, Majestic Honda (honda parts website), junkyard. it's not that hard to find the coolant connecting pipe.
http://www.hondaautomotiveparts.com/...+PUMP+-+SENSOR #11
Bryan/Berg Racing/WOLFEBUILT/Triangle, VA
Prelude F22A1 I/H/E 15.4@83mph F22A4 Turbo Quest to 10's coming soon!
H/F-Series Enthusiast
BergRacing21 is offline   Reply With Quote
2005, 92, civic, connecting, honda, intake, integra, leak, pipe, pipes, replace, replacing, rusted, thermostat, thrmostat, water
