| Welcome to Honda-Tech! | ||
#1 |
What distributor does a JDM D15B use? its a 95 engine in a 92 CX. I'm not getting spark and I'm thinking this is my problem. I have replaced plugs, cap, wires, and rotor button. The cap and button are the only parts that were Z6. The spark plugs were a different part number than the Z6 and wires from a Z6 didn't fit.
I thought that the D15B and Z6 heads were identical, but I must be wrong. What US parts are equivalent. |
#2 |
i'm not sure which us part you could use.. prob z6 if you have a tach
but... try replacing the igniter before the distributor. It's the small greyish thing you see wires connected to when you pull the cap off.
Cars: 1995 Civic cx - D15 | 2000 Civic cx - B18C1 - 15PSI - SOLD|03 Lexus IS300 Bikes: 2004 Ruckus - 49cc Brown Camo | 1982 v45 Magna - 750cc |
#3 |
1994 Honda Civic |
92-95 jdm d15bs use a z6 head/dist
#4 |
It's the same as the Z6/Z1/ZC. Having the wrong distributor wouldn't cause a no-spark condition. It causes the timing to be retarded even when adjusted to the max.
My motor doesn't exist. It's 10PM. Do you know where your Honda is? http://www.civic-eg.com/causeforalarm |
#5 |
1995 Honda Del Sol |
uses the z6 dizzy. im using my old z6 dizzy on my jdm d15b.
95 del sol si jdm d15b sohc VTEC, megan-racing headers, cat back-2.5" magnaflow, CAI, CROWER cam, skunk2 cam gear, BLOX IM, rebuilt head, ground control coilovers/tokica illumina's, jdm rear swaybar 23mm, black asr rear subframe brace, tuned at Church auto. |
#6 |
you surew its not get spark or is it not geting fuel bc you can use a z6 dizzy
86 hatch (sold) camo 87 si (sold) 95 dx hatch (sold)wrangler (DD) |
#7 |
plugs stink of fuel. no spark whatsoever. Check engine light stays on. I ran it on my cx ecu for a few days. Changed to the D15B ECU and so spark since. Tried old ECU and still no spark....
| Tags |
| 9295, cap, d15, d15b, distributor, dizzy, honda, jdm, number, part, plugs, rotor, spark, vtec, z6 |
