| Welcome to Honda-Tech! | ||
#1 |
| Garage is empty, add now |
replaced thermostat, new radiator, new rad cap and cooling fan wouldn't come on. So it's rigged to where it comes on when engine is on and runs constantly. I want to make a trip of 220 miles is this possible without the engine overheating or any long term damage being caused?
#2 |
Making your fan run constantly will not harm your engine in any way, it may eat into your gas milage a little cos it has to charge the battery a litle more to compensate for the extra current its using.
-john- http://i78.photobucket.com/alb...g.jpg ItsMeJTO-@-nc.rr.com (remove dashes) It's amazing how much noise a 10mm wrench makes when dropped at 3:00am. |
#3 |
Dont forget the fan switch that makes the fan come on at the proper temp/time. If this is not working your fan will not come on/work properly. Try that and also the relay for the fan. It's on your thermostat.
Looking for a good running D16Y8 |
#4 |
sorry it took so long to get back...thanks for your help I will try the switch next.
| Tags |
| 91, 94, bypass, civic, constantly, cooling, dx, fan, fans, honda, jpeg, relay, runs, switch, workin |
