Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda Accord & Crosstour (2003 - Current)
Old 05-19-2008, 05:16 AM   #1
4timeHondaowner
4timeHondaowner's Avatar
Default 2003 Accord sunroof just stopped working?
Yesterday I pushed the tilt button to open the sunroof and it opened just fine. When I tried to close it nothing happened. Then I tried to open the entire sunroof and same thing...nothing. All I heard when I pressed the button on the dashboard was a click (like something was trying to work but nothing was happening). After several attempts the sunroof finally closed. Does anyone know what this problem could be and can it be repaired relatively easily or should I take it to the dealership? Is it a switch problem? Motor problem? Wiring? Any help would be great. Thank you.
4timeHondaowner is offline   Reply With Quote
Old 06-18-2008, 02:55 PM   #2
vapor40
vapor40's Avatar
Default Re: 2003 Accord sunroof just stopped working? (4timeHondaowner)
There is a tsb for the limit switch.... may be the problem. I would take it to a good shop or you can pull the rear part of the headliner and replace it yourself. (not fun)
vapor40 is offline   Reply With Quote
2003, accord, bulletin, honda, integra, limit, moonroof, open, service, sticking, stopped, sunroof, switch, tsb, working
