| Welcome to Honda-Tech! | ||
#1 |
Will the Honda s2000 ap1 wheels fit on the 05 rsx with no rubbing issue? I know for sure 4 front ap1 wheels will fit but not sure of the rear. Please help me out. Thanks
#2 |
No, I'm pretty sure only the fronts fits.
2000 lifted 4runner Sr5 1993 Miata wēk´sôs ĭn'dustrēz |
#3 |
So the rears will rub tremendously?
#4 |
I'm not sure if its to do with the hub's of the offset, I just know that I have read that only the fronts fits.
#5 |
Thanks! Any other recommendations ?
#6 |
just a thought, but I know that on ep3's that fitting 225's requires rolling the rears but not the fronts, so maybe you could switch the ap1 wheels and use the rears on the front and vice versa, even run a staggered a set-up to allow our rear to rotate more, thats what im doing, just not with ap1 wheels, just getting rota's or sportmax and running 225's up front and 215's in the back, what exactly is the offset and rim width on the ap1 wheels?
#7 |
I've always wanted to see ap1's on a dc5. Are they 16's?
99 GSR Turbo For Sale - http://honda-tech.com/zerothread?id=1784241 |
#8 |
![]() I think you need to run spacers to make them stick out more.
2002 Acura RSX Type S Nighthawk Black Pearl | Stock is Beauty | Ownership: 11/16/2007 - Current | |
#9 | |
16X6.5 +55 front 16X7.5 +65 rear
AP1-GF4-EJ6-ED6 |
#10 |
jesus thats one hell of an offset, I didn't know they were that positive, you could always get extended studs and run spacers......there is a member on ephatch.com that is using this set-up and it looks awesome, ill go get it here shortly
#11 |
#12 |
how about AP2? heres the spec
17" x 7.0", +55 offset 17" x 8.5", +65 offset
AP1-GF4-EJ6-ED6 |
#13 |
im running 06 type s brake setup with no spacers. zero problems what so ever. they do stick in a little bit, but nothing to slot car-ish.
John 3:18 |
#14 |
| Garage is empty, add now |
25mm Spacers will put you flush. 25mm spacers flush out my itr's on my type-s.
"Driving slow cars since 2000" 02 Acura RSX TypeS- slower than poo poo |
#15 |
sweet..im put them on and see how it goes.
#16 |
man that **** looks gooood
2002 Honda Civic Si Greddy Turbo'd 1989 BMW 328ci SR20DET Powered 1972 Honda CB350 Supersport 1971 Mercedes Benz 300sel 6.3 Monster 1989 Dodge Colt/Mitsubishi Mirage Turbo 4g63 Turbo'd -- goodbye, you will be missed http://images.honda-tech.com/set1/smile/emsad.gif http://www.thetunersource.com |
#17 |
Now you guys running ap1 wheels, are you just using 2 sets of fronts? because ive heard that u cant use the rears..
#18 |
got it. 4 fronts all around.
John 3:18 |
#19 |
how heavy are the the AP1 wheels?
FOR SALE: 2005 RSX Type S NBP http://www.hondamarketplace.com/show...5#post44897265 |
#20 |
2000 Honda S2000 |
I vote on the stock rims look better on the car.... With the money and time you spent looking for a set of the AP1 wheels you could have some rotas...
#01 AP SQUAD |
#21 |
wow, those look good
team danger |
#22 | |
AP1 USDM cast 16's front 17.5 lbs rear 18.6 lbs AP1 JDM BBS forge 16's front 13.3 lbs rear 14.3 lbs AP2 USDM cast 17's front 17.6 lbs rear 20.5 lbs
AP1-GF4-EJ6-ED6 |
#23 |
what do the jdm bbs look like?
#24 |
Yeah i opted for the stock look. Not into performance, just yet. K20a3 =
John 3:18 |
#25 | |
AP1-GF4-EJ6-ED6 |
| Tags |
| ap1, civic, ep3, fit, fitment, make, rim, rims, rsx, s2000, sale, spacers, staggered, wheel, wheels |
