| Welcome to Honda-Tech! | ||
#1 |
Hey guys,
I wanted to post this up here cause it moves faster in GDD. xbox 360 hook up to LG 37" lCD using HDMI. Some times a couple hours into playing the screen gets vertical bars, and muti color pink, green, purple. It distorts the image so much i can't play. The only way i have been able to fix it is push the X symbol on the controler and cycle through menu bars until it goes back to normal normally 60sec or less. Some times it comes back though less than 5mins later Anyone have a fix? Should i return it for another? It's only a day old. Thanks |
#2 |
soulnds like you are going to get a rrod soon. lack of cooling maybe?
#3 | |
#4 |
lol **** gets hot and it looks like memory corruption........take a look at the XBL forums and many people report their system starts acting up before it finally RRODS
but hey what do I know............ |
#5 |
are you getting any sound? if so i'd say probably it's just the hdmi cord.
RP |
#6 |
Check your connections. Also try a diff HDMI cable/port on your TV.
If problem persists return it. It's only one day old after all.
1996 ej8 XBL: janarki |
#7 |
Go to your XBOX settings and try changing the color reference setting. Your TV might not be capable of showing extended reference.
#8 | |
#9 |
sound is perfect. Like when it messes up I can still tell im in the game COD4 and i can barely make out stuff. I'll try a different cable and hdmi port on the tv
thanks for the advice guys With COD4 it normally takes like 2hours of playing before the problem occurs With GTA4 it happens always like 15mins into Is GTA4 more graphically intense? Modified by SDT Project EF at 5:23 PM 5/15/2008 |
#10 | |
Looks like I'll exchange it tomorrow hopefully for a new one without any problems. |
| Tags |
| 360, bars, color, colors, fixing, green, lines, multi, pink, problems, purple, running, screen, tv, vertical, xbox |
