Gas pedal loose... how do i fix?
Old 05-04-2008, 04:05 PM
VietCloud7's Avatar
Default Gas pedal loose... how do i fix?
there's about an inch of play on my gas pedal... how do i tighten it?
Old 05-05-2008, 05:27 AM
SpazMan's Avatar
Default Re: Gas pedal loose... how do i fix? (VietCloud7)
Don't know how much help I'll be, but I fixed this on my Volvo... the throttle cable has a threaded screw on the end, and you can tighten or loosen it to lengthen/shorten the cable slightly (to shorten the cable, turn counterclockwise, I think). While the car's off, have a friend tap the gas pedal so you can find the throttle cable.
Ari
Old 05-05-2008, 04:59 PM
hondadude's Avatar
The throttle cable needs to have a little bit of slack in it to be sure the throttle plate closes all the way.
If not the TPS mis-reads and the ECU changes timing.
Old 05-06-2008, 11:56 AM
VietCloud7's Avatar
Default Re: Gas pedal loose... how do i fix? (hondadude)
well it's not like your typical loose gas pedal... even when i'm not on the pedal, it's like about an inch above the normal position. I'm not sure if thats a good description but thats the best way to explain it.
Old 05-06-2008, 04:46 PM
SpazMan's Avatar
I had the same issue. I had to press like 3/4-inch before the gas would kick in. This, in my case, was a stuck throttle body in addition to an over-loose gas pedal. But on Hondas, the TB doesn't foul like Volvos.
Ari
truxvi3tz
03-31-2010 02:26 PM
Yeung
06-03-2004 09:12 PM
midorigreen.
03-16-2003 07:40 AM
Cat
09-30-2002 06:48 AM
sa21199
01-04-2002 03:25 PM
Quick Reply: Gas pedal loose... how do i fix?
