Old 05-03-2008, 08:12 AM   #1
96 GSR-T
1996 Acura Integra
My Garage
96 GSR-T's Avatar
Send a message via AIM to 96 GSR-T
Default Weight Removal Experts: How much does my car Weight (Est.)
I do not have access to a scale for another 2 months or so, over the winter I did some extensive lightening to my car, was looking for some educated guesstimates before I actually hit the scales. I guess I am more looking for the total weight of all the stuff I have removed, as I have added heavy things such as a large turbo manifold and turbo, and a large frontmount and I am about to add 35-40lbs of Cromoly for the roll bar. This is a list of what I have removed:
Complete AC System (compressor, evaporator and condensor w/ wiring)
Complete ABS System w/ Wiring
PS System
No Blower Motor
All Sound Deadening Material (easy 40+ pounds alone)
Rear Seats/Brackets/Accessories and Carpet
No Spare Tire/Jack Anything!
No Rear Wiper or Antenna, associated wiring removed
No Front Bumper Beam
Lightweight Battery
SK2 LCA's
No Seatbelts (have harnesses)
Anything additional I can remove w/o sacraficing the saftey of myself or truly removing the streetability of the car? I would like to keep my door beams and interior metal in the quarters so that is out of the question, I dont want to cut metal. I am looking into a Lexan Rear and Quarter Windows, how much weight savings is in those windows?
I am guessing/hoping that w/o me my car lies in the 2450-2500lb area, and I conservative in assuming this? The car is a no leather car but still retains power windows and locks (street car).
96' FBP GSR-585hp/385tq - 00 PY ITR #479 Totaled
05' CGP TSX 6MT-SOLD - 08' WDP TL-S 5AT - Daily
96 GSR-T is offline   Reply With Quote
Old 05-03-2008, 08:22 AM   #2
goota
2000 Acura Integra
goota's Avatar
well considering your car started off weighing about 2680 or so, I think its a stretch to assume youve removed 200 lbs.
why are you removing all that stuff, most likely youre upsetting the weight balance of the car, and probably barely making it any faster.
90 CRX SI
91 4RUNNER 4x4
01 GS-R (SOLD)
goota is offline   Reply With Quote
Old 05-03-2008, 08:28 AM   #3
Dogginator
Daisy... Daisy...
1997 Acura Integra
Dogginator's Avatar
Default Re: Weight Removal Experts: How much does my car Weight (96 GSR-T)
Why haven't you pulled the sunroof motor and glass from your GSR? That is extremely bad weight. You can plug the hole.
404: Care not found.
Dogginator is offline   Reply With Quote
Old 05-03-2008, 08:41 AM   #4
96 GSR-T
1996 Acura Integra
My Garage
96 GSR-T's Avatar
Default Re: Weight Removal Experts: How much does my car Weight (Dogginator)
I wanted to keep it for extra air flow...lol I drive this car and it gets 95-100 deg out here in the summer with 100% humidity How much weight is there? I saw some nice plug kits. I actually have my headliner out now for the bar install, but I really dont want to have to buy an RS or ITR headliner to go back in there.
I didnt build this car to go around turns so weight balance is a non issue to me, and 200lb will definately make a car go faster in the 1/4 mile.
Old 05-03-2008, 08:47 AM   #5
Dogginator
Daisy... Daisy...
1997 Acura Integra
Dogginator's Avatar
The sunroof motor constitutes most of the weight. If I recall correctly, the motor, track, and glass tally to about 40 lbs. You can keep the head liner. Just put a sign above the sunroof cover. LOL
Old 05-03-2008, 10:04 AM   #6
NVR2LOW
NVR2LOW's Avatar
Send a message via AIM to NVR2LOW
Its not going to make that big of a difference lol. You might see maybe a tenth taken off your time, Its not going to be a noticable difference.
1991 EF Hatch [img]http://images.honda-tech.com/set1/smile/emthup.gif[/img]
NVR2LOW is offline   Reply With Quote
Old 05-03-2008, 10:25 AM   #7
90_EX_Civic
1991 Honda Civic
My Garage
90_EX_Civic's Avatar
question is did you want to go to extremes for your weight loss?
90_EX_Civic is offline   Reply With Quote
Old 05-03-2008, 10:30 AM   #8
xRacerX81
xRacerX81's Avatar
Send a message via AIM to xRacerX81
i removed the same stuff you did except for the wiper since mines a sedan heres a link to what each item weighs
http://www.honda-tech.com/zerothread?id=1572161
What Doesn't Kill Me Makes Me Stronger
xRacerX81 is offline   Reply With Quote
Old 05-03-2008, 11:11 AM   #9
96 GSR-T
1996 Acura Integra
My Garage
96 GSR-T's Avatar
Default Re: Weight Removal Experts: How much does my car Weight (90_EX_Civic)
As far as cutting the guts out of the car..... no I want to remove everything I can w/o cutting into the car
I am considering the Sunroof and Lexan the rear quarters and rear window and a CF hatch
Old 05-03-2008, 11:15 AM   #10
96 GSR-T
1996 Acura Integra
My Garage
96 GSR-T's Avatar
Default Re: (xRacerX81)
thx for the link, he has some extra stuff removed like the SRS system, I need to get into that just have not pulled the dash apart yet.
By adding what he has in there that I removed, plus my rear seats and 40lbs of deadening will put me around 2450-2500.
Old 05-03-2008, 11:17 AM   #11
90_EX_Civic
1991 Honda Civic
My Garage
my idea of extreme, acid dip, drill holes into your A pillar, B pillar, and C pillar. then spot weld.
Old 05-03-2008, 11:28 AM   #12
96 GSR-T
1996 Acura Integra
My Garage
96 GSR-T's Avatar
yea I am not doing all that, trying to keep this within reason.
Old 05-03-2008, 11:45 AM   #13
90_EX_Civic
1991 Honda Civic
My Garage
Default Re: (96 GSR-T)
well i did say extreme. plus replace the doors with carbon fiber, and have a steel bar molded into the door to keep that side impact.
88, 96, ac, acura, car, compressor, find, honda, integra, mustang, remove, rs, rsx, weigh, weighs, weight
