Old 04-24-2008, 09:25 PM   #1
Pinche Caro
Pinche Caro's Avatar
Send a message via AIM to Pinche Caro
Default 97 Accord Head bolts TORQUE specs?
I need head torque specs for a 97 accord 4cyl. f22b. and also the for the rocker arms. I tried searching and couldnt find anything.
Pinche Caro is offline   Reply With Quote
Old 04-25-2008, 04:52 AM   #2
TouringAccord
H-T Order of Merit
TouringAccord's Avatar
Default Re: 97 Accord Head bolts TORQUE specs? (Pinche Caro)
when standing in front of the car looking at the engine, the torque sequence is as follows.
Head bolts...
8---6---2---4---10
9---3---1---5---7
you torque them in three steps
1 - 29lbs-ft
2 - 51lbs-ft
3 - 72lbs-ft
as for the rocker arm assembly bolts, the torque sequence is different between the F22B1 and F22B2 but the torque specs are the same...
8mm bolts = 16lbs-ft
6mm bolts = 9lbs-ft
TouringAccord is offline   Reply With Quote
Old 04-25-2008, 02:37 PM   #3
Pinche Caro
Default Re: 97 Accord Head bolts TORQUE specs? (TouringAccord)
Thanks! U the man Click the image to open in full size.
Old 04-25-2008, 06:17 PM   #4
oem_certified_accord
oem_certified_accord's Avatar
rocker arm bolts are 10mm and 12mm's TA Click the image to open in full size.
CD Squad
WhiteOnRice, gen5accstilez, TheMuffinMan, integrated civic
oem_certified_accord is offline   Reply With Quote
Old 04-26-2008, 07:59 AM   #5
TouringAccord
H-T Order of Merit
Default Re: 97 Accord Head bolts TORQUE specs? (oem_certified_accord)
yes and no. I was referring to the thread size and you would be referring to the head size... if I'm not mistaken.
Old 04-26-2008, 10:05 AM   #6
lol what? Click the image to open in full size.
head bolts = 14mm, rocker arm assembly bolts = 10mm backside, 12mm frontside & midrow.
unless your mean the vtec monster head, then that would make me feel dumb Click the image to open in full size.
CD Squad
Old 04-26-2008, 10:58 AM   #7
Pinche Caro
i think he means the size of the thread of the bolt.
Old 04-26-2008, 01:25 PM   #8
ahhhh thread PITCH and size. gotcha Click the image to open in full size.
edit:
right over my head, didn't see you said thread size lol.
CD Squad
Old 09-03-2011, 07:48 AM   #9
lethalaccord
what happen if you break one of the rocker arm bolt, the 10 mm backside bolt? please someone chime in.
lethalaccord is offline   Reply With Quote
Old 09-03-2011, 09:16 AM   #10
Lost Again
You'll need a new one, and get the old one out.
My child arrived just the other day; he came to the world in the usual way
I can explian it to you, I CANNOT understand it for you
Lost Again is offline   Reply With Quote
Old 09-03-2011, 10:37 AM   #11
lethalaccord
dang, i was afraid of that. how long do you think i can go with this problem? i will need some time to save up money and get a new head. rather than a new head, i might just get me a new motor cause this engine has 340,000 miles.
Old 09-03-2011, 11:06 AM   #12
Lost Again
Depends on you budget???
Me, I'd pull the rocker assy and see about getting the old one out.
Old 09-03-2011, 11:14 AM   #13
lethalaccord
i was thinking about that but the 10mm bolt is too small. what do you think can get that broken bolt out?
Old 09-03-2011, 04:10 PM   #14
lethalaccord
got it fixed. took it apart and used a magnet and twist that broken bolt out. now gotta do my valves again bc its ticking pretty loud. ahha
Old 09-04-2011, 04:58 PM   #15
newhondagirl
1996 Honda Accord
newhondagirl's Avatar
what was your main goal here??? to replace the head gasket??? did you use a new clean head? i also had a broken bolt on the rocker a few days ago...bout died for a min...lol but it was cake to get out just used some needlenose pliers. i had it off to replace the o rings on the bottom but....my main problem is i have a BHG and will be doing a head job on my car in the next couple weeks. i would love any help on this as i will be doing it myself and i have never done anything like this before...
newhondagirl is offline   Reply With Quote
Old 09-05-2011, 05:35 AM   #16
lethalaccord
Im new to the accord scene so the goal was just to replace the o rings on the bottom of the rocker arms, which i never knew cause i've always had an civic or s2000.
check the FAQ thread. there should be something on how to remove BHG.
Old 01-07-2013, 05:55 PM   #17
jmuldo
What about the engine cover? What is the torque specification? I need to do my valve cover gaskets, I am leaking oil into my spark plugs.
jmuldo is offline   Reply With Quote
Old 01-08-2013, 03:58 AM   #18
TouringAccord
H-T Order of Merit
7.2 lbs-ft
Old 01-08-2013, 04:50 PM   #19
jmuldo
Sweet I appreciate it man, is there a specific order I would have to tight the bolts?
Old 01-09-2013, 04:15 AM   #20
TouringAccord
H-T Order of Merit
no problem
uh, it's been a while and I don't have my manual handy... but iirc start in the middle and work outward alternating sides as you go.
97, accord, bolt, bolts, civic, f22b1, f22b2, head, honda, rockers, sequence, spec, specifications, specs, torque
Similar Threads
1995 Accord Torque Specs 456eec Honda Accord (1990 - 2002) 4 01-03-2014 07:47 PM
97 civic with oil leak - which torque specs to tighten the head? 1.5? or 1.6? Walaxvw Honda Civic/Del Sol (1992 - 2000) 19 08-02-2013 10:19 AM
92' VX Hatch Torque Specs. TORTUGA Honda Civic/Del Sol (1992 - 2000) 0 01-02-2013 11:50 AM
04 Accord Axle Nut torque spec? End3rx Honda Accord & Crosstour (2003 - Current) 3 12-31-2012 04:40 AM
j30a1 head bolt torque? Thepowderblue Honda Accord (1990 - 2002) 2 10-21-2012 11:45 PM
